November 22, 2019 at 11:11 am
rg
SubscriberHi all,
this email to inform you about a tremendous BUG in sheet-metal that is blocking for the manufacturing depts.
As you can see in the video attached if I select the opposite faces to calculate the flatten view works well in the flatten (3D) but is completely wrong (overturned) in the drawing
This wrong behaviour makes disasters in manufacturing dept.! The drawing is wrong and they cut the pieces overturned.
Subashni Naresh Patre
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
November 22, 2019 at 9:44 pm
Brian Bueno
Ansys EmployeeRoberto
This has been reported in the past. I have to check what the status is. I believe at one point a defect may have been filed.
December 4, 2019 at 8:48 am
rg
SubscriberBrian Bueno Can you give me the BUG number?
November 26, 2019 at 9:48 am
rg
SubscriberBrian Bueno Hi Brian
I await your news to find out if you will solve the problem
Best Regards
December 9, 2019 at 8:50 pm
Brian Bueno
The development team is aware of this and there are discussions on how best to address the issue.
Here was the explanation of the behavior from the development team:
Bend annotations (angle and up/down bend lines) are local properties of an unfolded part.
These properties (lines/text entities in SpaceClaim) depend on the viewing direction of the “unfolded part” and not the global x/y/z reference frame
In a drawing with standard views (elevation/plan and side view), the viewing directions are fixed with respect to the global x/y/z frame.
Hence local unfolded entities (lines/text entities) from the unfolded part may/may not represent their semantic meaning as created using unfolded part’s reference frame.
December 10, 2019 at 2:12 pm
rg
SubscriberBrian Bueno I sent you an email as privat message. Please check your emails!!!
3850
2629
1853
1246
600
