June 28, 2019 at 8:06 am
rg
SubscriberHi, I would like to request information to speed up work times.
There is a way that when I go to unfolded a piece in sheet metal in automatic the levels are all turned on and the solid is not purple in color as of defaul but white.
White interests me because the machine reads white step files
Regards -
June 28, 2019 at 10:17 am
Subashni Ravichandran
Ansys EmployeeHello Roberto
I'm not sure if I understand your query correctly.
But if it is about changing the colour of the solids by using the colour assigned to the layer, you can select the solids and from Display> Style, you can toggle the colour and select 'Remove Colour override'.
Is this what you were looking for? If not, could you please explain your query in more detail, maybe with a screenshot or video?
June 28, 2019 at 10:33 am
rg
SubscriberSubashni
Hi I have attached a video.
It can be done that when I go to use the command unfold the piece opens with the white color and with all the levels already active (photo).If this is not possible it is not a problem and just to know if there is the possibility of some SpaceClaim settings
Thanks
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
July 2, 2019 at 12:09 pm
Unfortunately, there is no provision to keep the layers on or change the colour.
We will share your idea/input with the product development team, thank you for your feedback
July 2, 2019 at 2:53 pm
rg
SubscriberSubashni Hi, no problem, thanks for letting me know
July 3, 2019 at 8:08 am
rg
SubscriberSubashni ossibility to add an option to save the files explained in dxf / dwg with the white outline keeping the fold lines or other lines present in other colors.
Now it is not possible to do this because it saves everything in white keeping the save in black and white option active.
While disabled, the option saves the outline in gray.
This is important because the dxf in the color cutting / folding machine reads where to cut.
If you could already export the file with the white outline from spacecliam keeping the other lines colored, you would save time and money because the machines immediately read all the dataADDED TO IDEAS THANK YOU
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
3744
2573
1821
1236
594
