Sheet metal cutting analysis on Ansys Workbench
    • ozkantekin90
      hello
      I am trying to make a cutting analysis a simple analysis, whatever i select the values in animation i couldn't see plactic deformation, the cutting edge is just end its motion by the time contact the sheet metal i think i did miss something  while i make mathematical model , Can somebody help me with this thaks
      özkan
    • peteroznewman
      Hello özkan,
      I can try to help. What material model did you use for the part you want to cut? You must include a material failure model. Most materials in the Explicit Dynamics library include that. It will be easy to help you if you save an Archive of your model. That means close Mechanical, and in Workbench, File, Archive... and save a .wbpz file.  You can attach that file to your post if it is < 120 MB.  If the archive is too large, right click on Model and select Clear Generated Data, which will clear the mesh. Save the project, then do File, Archive... again and the file size will be smaller.
      Attached is an ANSYS 18.2 archive of a very coarse and simple cutting model that runs in 15 minutes on my 4 core laptop.
    • ozkantekin90
      Hello Peter
      Thanks for your reply, I use Ansys 15.0 i think you can run it on your laptop. Also i will try to upgrade my sofware and open the project that you sent me
    • peteroznewman
      You can download either 19.0 or 18.2 and be able to open that archive.
      Here is a version with a flatter cutter.
    • ozkantekin90
      how can you determine the contact types actually i need to improve my analysis skills on Ansys especially explicit dynamics ?
    • peteroznewman
      The model I attached only has Body Interaction and no additional Contact definitions.
    • ozkantekin90
      yes when i open the file that sent me i saw him. i have sent you the file that i have made, also  the file that you attached can't found the solution file althought i restored the archive. a warning sign is on the Explicit Dynamics tab.
    • peteroznewman
      You have to click on the Solution, and Clear Generated Data, then Solve and wait. If you click on the Solution Information folder, you will see the progress. When it finishes, you will have results.
      If I include results in the archive, the file size will be too large.
    • peteroznewman
      I opened your model, the first observation is that you have only 1 element through the thickness of the plate you want to cut and there is a gap between the plate and the tool.
      You can see that in my model, I have 20 elements through the thickness of the part that is being cut and the tool is touching the plate.
      If your goal is to make an animation of the cutting, it will be best if you take this geometry and scale it up 1000 times. The reason for this is that the solver calculates a time step based on the dimension of the smallest element. If you check the size of my plate, it is 1000 mm thick!  But it solves in about 15 minutes. If my plate was 1 mm thick like your model, it would take 15,000 minutes or 250 hours or 10.4 days to solve.
    • ozkantekin90
      i see i still have a lot of thing that i need to learn, thanks for your valuable informations, Also i will not use contacts like yours, in this case do i need to clamp the sheet on two side of the sheet ? thank you
    • peteroznewman
      Yes you have to have contact on both sides of the sheet, which you can see in my model. But I am not clamping. I picked the back edge of the plate and added a fixed support.
      Also, instead of a displacement to move the tool, I used velocity with an equation that is number*time.  That means that at t=0, v=0 and the velocity ramps up over time. Your ramped displacement creates a constant velocity so that the tool makes an impact with the plate which can cause the solution to fail due to energy error.
    • ozkantekin90
      Hello Peter
       Thanks for your help, Also i need to know how easy to cut a sheet as shearing (like scissoring) compared to usual cut as you have shown in the video above, how can i observe it on the ansys ?
    • peteroznewman
      Hello özkan,
      The cutting2 model was shearing the width all at once.  You can angle the blade to shear it from one side to the other like scissoring.
    • SaharPzd
      Hi Peteroznewman,
          I am trying do a simulation with a similar concept where I am simulating a surgical staple being inserted into a block of bone. I used a lot of the techniques you mentioned above and I was able to simulate most of it except it seems like the staple does not cut into the bone but instead just deflects off of it. I had to create a new material on my own to simulate bone. The values I had were the tensile strength, yield strength, young's modulus, shear, poisson ratio, mass density, and compressive strength. Is there anything else I need to model failure?
Viewing 13 reply threads
