3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Sheet Metal Error
    • Roberto
      Hello
      I need to urgently create the joints in these sheets.
      I need to urgently create the joints in these sheets Devendra Badgujar .
      I don't understand why they are not created and why the file does not convert to sheet metal
      Regards
    • Devendra Badgujar
      Forum Moderator
      Hello Roberto
      Let me check and get back to you.
      Regards.
    • Roberto
      Hello Devendra Badgujar
      Thank you very much for your help
      Regards
    • Devendra Badgujar
      Forum Moderator
      Hello Roberto
      I was able to reproduce this at my end. I have created a Bug ( 706427 ) for this issue ad will update you as I get more information on this.
      Regards.
    • Roberto
      The customer will have to make about twenty of these pieces, it is very inconvenient to make the joints one at a time, I hope that the problem will be solved in the next version.
      is it possible to make an upgrade? to make sure that the joints are also created between components of equal thickness? it would be very convenient
      Regards
      • Devendra Badgujar
        Forum Moderator
         Roberto
        Thanks for your feedback on this. Will let you as I get more information on this.
        For your upgrade, I will create an Enhancement request to be added.
        Regards.
    • Roberto
      I sent you another file, with another problem
      Regards
      • Devendra Badgujar
        Forum Moderator
        Roberto
        I checked the file and it looks like you trying to create that from Sheetmetal tab and not Design tab, so it is creating a flange and not plate.
        Try creating the same from Design Tab.
        Regards.
    • Devendra Badgujar
      Forum Moderator
      Hello Roberto
      Bug no (706427) for this issue should be fixed in 2023 R1.
      Thank you.
    • Roberto
      Hello Devendra Badgujar thank you very much!
Viewing 7 reply threads
