May 5, 2022 at 3:24 pm
rg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
HelloÂ
It would be very useful to be able to create the joints for each side without disabling the function all the time.
This is a big limitation.Â
regards
May 5, 2022 at 3:33 pm
Devendra Badgujar
Ansys EmployeeHi Roberto
Let me look into this and get back to you.Â
Regards.
May 6, 2022 at 8:52 am
Devendra Badgujar
Thanks for bringing this to our notice. I was also able to replicate the behavior on my end.
Let me check with the development team and get back to you with more information on this.
Regards.
May 6, 2022 at 8:54 am
rg
SubscriberHello Devendra Badgujar
No problem, I'll be waiting for your information after you speak to the development team
Regards
May 9, 2022 at 3:44 pm
rg
I enclose another problem where the command does not work.
It seems that a small radius is always needed, if I create some radii in the sharp corners it works otherwise not
May 9, 2022 at 3:54 pm
Devendra Badgujar
Ansys EmployeeRobertoÂ
I will update this information with the development team. I have filed a bug for the issue and will let you know what we find.Â
Regards.
May 16, 2022 at 9:27 am
Devendra Badgujar
I have an update from the development team, the Bug (638508) for the above issues will be fixed in 2023 R1 release.
Regards.
May 17, 2022 at 6:40 am
rg
Thank you very much for the information, thank you to the developer team
Best Regards
May 17, 2022 at 6:52 am
rg
Is it possible to ask the team if they can also use the command on cylindrical geometries? type pipes
Regards
May 17, 2022 at 7:07 am
Devendra Badgujar
Let me check and get back to you.
3812
2593
1849
1244
600
