February 9, 2022 at 2:08 pm
contact
Dear Support Team
three issues came up during generating a sheet metal part:
1. If I set the corner relief at two tabs to triangle and the junction to full overlapp, the sheet metal part can no longer be unfolded (see: sheet-metal_01 + 02). Set to no overlapp the sheet metal part is unfoldable.
2. if I set a second corner to corner relief as triangle this is created correctly. (see: sheet-metal_03), as soon as the junction here is also set to full overlapp, the corner relief appears differently than the first (see: sheet-metal_04).
3. when i want to change the direction of the tab overlap (during the operations as explained before) it does not work.
Is there any explanation for this and how can it be fixed?
Thank you and best regards
Alex
February 9, 2022 at 2:13 pm
Subashni Ravichandran
Ansys EmployeeHello Alexander Faller
Let me look into this.
February 14, 2022 at 5:10 pm
contact
SubscriberHello Subashni
Have you had a chance to discuss the problem with the corner relief and the overlapp?
I am very curious about your answer and suggestions.best regards
Alex
March 11, 2022 at 8:46 am
I have filed a bug for this issue.
3778
2587
1831
1244
598
