February 3, 2021 at 8:16 am
rg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsFebruary 3, 2021 at 10:30 amNaresh Patre
Ansys EmployeeHello Roberto
I went through the video to understand the issues. Regarding the first one, extended joint is applied first and then the 2D triangular relief is being created. I think this wont work because the relief faces are not separate but overlapping each other.
Regarding the 2nd issue (It is not possible to unfold a sheet with triangular relief and extended joint) I think this is a bug.Â
I have submitted BUG 403403 and mentioned both the issues. I will let you know once they get fixed by the development team.
3812
2607
1853
1244
600
