April 12, 2022 at 9:23 am
rg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hello
When in SpaceClaim you work in sheet metal, if there are several unfolded in the components, the software slows down a lot it is not possible to work with it, I am attaching an example video.
So with all sheet metal files, it's not a file problem , or characteristics of the pcBest Regards
April 12, 2022 at 9:59 am
Devendra Badgujar
Ansys EmployeeHello Roberto
I will look into this and get back to you.
Regards.
April 12, 2022 at 10:07 am
Devendra Badgujar
Ansys EmployeeRoberto
Please can you share any such file which has this issue, I will try it at my end and will see if there is any possible workaround to improve this.
April 12, 2022 at 10:13 am
rg
SubscriberHello Devendra Badgujar
I sent you the file, thanks for your cooperation
Regards
April 13, 2022 at 7:53 am
Devendra Badgujar
I was able to replicate this on my end. I will check with the development team on this and will get back to you once I hear back from them.
If you are working on a specific component, you can right-click the component in the structure tree and select Open Component. This will open the component in a new window so you can work on it.
This will speed up the geometry creation/editing process. At the moment this seems to be the possible way to improve the working for such cases.Regards.
April 13, 2022 at 8:01 am
rg
Okay the advice you gave me but this can only be a temporary method to be used momentarily, this problem must be corrected
Best Regards
April 13, 2022 at 9:45 am
Devendra Badgujar
Yes I agree. I will file a bug with the development team to correct this problem.
Regards.
April 13, 2022 at 10:01 am
Devendra Badgujar
This is the bug number 626641
3744
2573
1793
1236
594
