Discovery Import
Discovery Import
Sheet metal
    • rg
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello
      1) It is not possible to create a BOM with only unfolded sheets.
      You always need an overview of the whole, otherwise the bill won't create it
      Is it possible to create a BOM with unfolded views only?
      2)When I export the sheet data data is missing: thickness, holes, number of bends, etc.
    • Naresh Patre
      Hello Roberto
       BOM works only on components and the unfolded part doesn't have any component so the BOM doesn't show up any information. If you create a component for the unfolded bodies, this will update the BOM to show the component data.
      Some properties like area, perimeter are applicable to unfolded component. This is mentioned in help document.
