June 17, 2023 at 12:39 am
June 20, 2023 at 1:56 am
Mike Rife
Ansys EmployeeHi
Mechanical APDL no longer supports pre-processing of LS-Dyna models. Plus the element types that support layering in MAPDL differ in how the data is stored versus the LS-Dyna shell element. Lastly back when MAPDL did support pre/solve/post of LS-Dyna models composites were not supported. So you would usually create the k file in MAPDL then use LS PrePost to finish off the set up. I'd recommend using Workbench LS-Dyna. For very complex layerings WB ACP supports WB LS-Dyna.
Mike
June 21, 2023 at 2:25 pm
Mike Rife
Ansys EmployeeI should have been clearer on MAPDL supporting composites for LS-Dyna solver - MAT22 (composite damage) was supported. But not composites in the sense of section lay-ups as the ls-dyna shell did not use sections (it uses real constants).
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- About Bilinear Isotropic Hardening Plastic Model !
7658
4470
2957
1433
1322
