May 2, 2022 at 7:12 pm
luis.serra5
SubscriberHi! I am currently doing my thesis where I have to simulate an impact in a guardrail post. I tried to simulate this problem with solid bodies and shell bodies. When I did the simulation with solid bodies, everything worked fine but when I tried to simulate the problem with Shells, a body got separate from the main structure, what was not supposed to happen. I used Bonded Contact between the bodies. Can you help me solve this issue? Thank You.
May 4, 2022 at 10:13 pmChris Quan
Ansys EmployeeWhen solid body to solid body is bonded, their distance is probably very small and less than the Maximum Offset.
When one of the solid body is simplified to become a surface body, their distance from the surface body (for example, mid-surface of the original solid body) to the solid body may not be small. It is at least half of the shell thickness if mid-surface is used to represent the shell body.
You need to increase the Maximum Offset in the Definition of the Bonded Contact from 1E-4 mm to a value that is larger than the distance between the surface body and the solid body. This will ensure that both bodies can be bonded together.
May 5, 2022 at 1:39 pmluis.serra5
SubscriberThank you! Your suggestion really helped my model to converge.
Trending discussions- Explicit dynamics ERRORS
- turning simulation
- explicit dynamics
- Monte Carlo Simulation
- Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
8806
4658
3151
1680
1470
