July 7, 2022 at 9:54 am
kamalkrishna
SubscriberHow to know shock analysis simulation i did is correct,one thing i know to check by directional accerlation (it has to decay with time).How to consider limiting stresses in shock analysis?recently i came to know to use BR 3021 manual.But i am not finding it in internet.
July 21, 2022 at 3:23 pm
Chandra Sekaran
Ansys EmployeeIn the transient analysis the time step size should be small enough. The recommendation is 20 points per cycle at the highest frequency of interest. In the solver output, a response eigen value is printed out for each time step along with number of points per cycle. You can review this and make sure it is 10 or more. This is one thing you can do to make sure you are resolving all the frequencies.
- The topic ‘Shock analysis’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
