September 14, 2020 at 2:05 pm
aljarah.ahmad94
SubscriberHello I am using Ansys Aim / magnetic solver to calculate the force exerted by permanent magnet . The default simulation shows (Geometry / physics / Results). The simulation worked fine and i got all the results I need. The problem is that the (show mesh) button on the upper right of the screen is not working (screenshot is attached) , I can't see the mesh that was generated to get these results or edit it, can you please help with that. Regards
September 15, 2020 at 5:05 am
Naresh Patre
Ansys EmployeeHello Ahmad
I don't think it is possible to view the mesh generated in electromagnetics simulation. You can view the mesh in other simulations like fluids, structural.
September 15, 2020 at 8:47 am
aljarah.ahmad94
SubscriberNaresh Patre
Thanks for your reply.
Is it possible to conduct a mesh sensitivity test in that case ? I tried to define the mesh manually and prepare the physics after that, but it keeps giving me that physics requires attention, the message is " connect the electromagnetic physics task to a geometry task" and it refuses to run.
Do you know how to solve that or any other way to conduct the mesh sensitivity test for electromagnetic problems ?
Many thanks.
September 15, 2020 at 9:58 am
September 15, 2020 at 5:04 pm
aljarah.ahmad94
Many Thanks
3930
2649
1865
1272
610
