Show scale of contour in Fluent
    • luist
      Someone could indicate me which is the TUI command line to show the scale of contour's?
      I have run a case with .jou file and the images of contour's give me the countur scale like the image below:
    • RK
      Hello, nYou mean you are able to see just the colormap without the text? May I please know which version you are using? Thanks! n
    • luist
      Yes, exactly.nI use the 2019R2, but if it is possible i need kwon the command to 2020R2 either.nThank you rahkumarn
    • RK
      Use the TUI command : /preferences/graphics/colormap-settings/text-behavior Automaticn
    • luist
      rahkumar, Thank you for the answer.nBut in 2019R2 version there is no preferences command, can you tell on this version where i can find this command?.n
Viewing 4 reply threads
