Discovery Import
Discovery Import
Showing all materials after loading a material library in Discovery AIM
    • DrAmine
      Dear AIM-Users,
      When I add a material library and want to select a material from that library, I need to use the search functionality. Is there a way to directly view all materials available in the added library?
      Amine
    • Gaurav Sharma
      Hi Amine
      The ability to view the entire AIM material library is not available in 2019 R3 (or in 2020 R1) and searching by a string is the only available method currently. You may open the xml corresponding to the new library to get the name by which the material is defined/saved in the library and use the same name to search it on AIM window.
      Thanks & Regards,
      Gaurav
    • DrAmine
      Thanks Gaurav.
    • DrAmine
      If I have a custom library file (created within AIM and exported as *.h5 file) can be merged with the original library I assume all materials in that library will become visible. Is my assumption correct and do you you know if it is possible to merge these *.h5 files?
Viewing 3 reply threads
