January 31, 2023 at 3:46 pm
Phillip Wolstenholme
SubscriberHello,
I was wondering if anybody could help me please. I have done a design optimisation on a part, and would like to open up the stress results of the original design alongside the results from the 'topologically' optimsed results. I believe you can do this through using the multi-view view port. I have read a post about making two new independant static simulations and setting the to 'beta' version in order to read results from mesh file (https://forum.ansys.com/forums/topic/viewing-results-of-different-analysis-systems-in-split-screen/), but cannot figure this out. Please would anybody be able to point me in the right direction? I have been able to open up the results of both simulations, and just placed each window next to each other, but would like to be able to use 'two vertical view' viewport option.
Thank you very much,
Kind regards,
Phillip
February 2, 2023 at 1:05 pm
Aniket
Ansys EmployeeWhat issue are you facing with the process Saumadeep has mentioned in the previous post?
-Aniket
February 5, 2023 at 11:29 pm
SubscriberI can't read the results from the original simulation and the optimised simulation into two new independant (but linked together up to the 'model' stage') static structural projects. I set the beta options in order to read mesh results, but the 'read results' from mesh file is greyed out in both of my new independant projects.
Thank you very much if you could help in any way,
Phillip
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5242
3297
2469
