Showing User Parameter updates…
    • pgl
      The user parameters can not be printed at each iteration. You can get the status of such parameters after the LoadStep or Substep. For this also, you can use *STATUS, parameter_name to get its update. If you want to track any particular result value then you can use NHIST command for result tracking during the solution. You can also use the OUTPR command for controlling the solution printout.
    • nselvara
      Can we show User Parameter update on each iteration?
