September 20, 2018 at 10:27 am
September 21, 2018 at 9:06 pm
mli
Ansys EmployeePlease provide more details of your questions.
September 24, 2018 at 9:28 am
September 24, 2018 at 9:48 am
Ansys EmployeeYes, that's possible. Have a read through of the Moving Mesh section of the Fluent manual, I think you're looking at rigid body motion and remeshing. Note, the inner diameter cannot become zero as you must maintain the same topology.
You will probably need a full tet mesh, and I'd suggest refining the mesh.
September 24, 2018 at 9:49 am
Ansys EmployeeIt may also be possible to use layering in 2d axi-symmetric which would be much quicker depending on the rest of the model.
September 24, 2018 at 2:58 pm
ft19
Subscriberthanks a lot for the answer but can you explain to me what I need to set inside the dynamic mesh and the boundary condition? Because my setting doesn't work and displays "not found zones face" or " negative volume" and I cannot understand why!
thank you so much!
2684
2122
1349
1136
461
