October 3, 2017 at 7:43 am
Carlo_M
SubscriberI am wondering how Ansys evaluates the stress intensity factor in workbench for a pre-meshed crack.
Is this by a domain integral or a contour integral?
October 4, 2017 at 12:56 am
pgl
Ansys EmployeeWorkbench uses the Contour Integration approach (CINT). Contours are numbered radially outward, and there's no limit on the number of contours.
Both an Interaction Integral Method and Displacement Extrapolation Method are available in Mechanical APDL (see here) and you can insert a CINT,TYPE, SIFS based command snippet into your Workbench Mechanical simulation to specify the method directly if you don't wish to use the ANSYS Workbenches automated crack procedure. etc.
2120
1347
1118
461
