November 7, 2017 at 4:54 pm
momidor
SubscriberHi,
I'm wonder whether is possible to obtain SIF ( stress intensification factor ) from the model somehow ?
Regards
November 7, 2017 at 9:36 pm
SubscriberHi Mom,
If you have a crack in your geometry, you can perform a Fracture Analysis on it.
There is a whole section of the online help about how to do that.
From your other post, I got the impression that the flaw in your solid model is more of a void than a crack. In that case, the Pre-Meshed Crack might work. That is where you use a named selection for the nodes that are on the crack front.
You insert a Fracture into the model and a Fracture Tool in the Solution branch and request the SIFS result.
Today I was playing with geometry to represent the air around an airfoil, so I re-purposed the geometry, assigned Structural Steel material property and defined a pre-meshed crack at the trailing edge. The bottom of the block is fixed and the top has an applied upward force. Here is the SIFS result from the Fracture Analysis.
I found a YouTube video that shows some of these operations in ANSYS 14.5
Cheers,
Peter -
November 8, 2017 at 6:14 pm
momidor
SubscriberHi Peter,
Thanks a lot ! Look ideal but the obstacle is I don't have "Fracture" button under the command bar "Model"
Regards
Mom
November 9, 2017 at 1:27 am
SubscriberHi Mom,
A very simple way to think about this is to have two models: one with and one without the void.
It is simple to delete the 6 faces of the void in DesignModeler to end up with a smooth surface.
With the void, I got 643 MPa while without the void, I got 207 MPa, so you could estimate a stress concentration factor of 3.1
Hope this helps. Others may want to comment.
Cheers,
2110
1337
1112
461
