Significance of pseudo time step in Ansys Fluent
    • cfd_learner
      What is the significance/understanding of the pseudo auto time step in Ansys Fluent?
      For Ex: 0.1, 1.0, 10 what will happen with these time scale factors in context to accuracy and convergence?
      Regards.
    • vinayak chauhan
      pseudo time-stepping also known as pseudo-transient continuation, is the technique of solving the steady-state solution of time-evolving partial differential equations by setting an initial guess(t') and using a time-stepper to evolve the solution forward.
      using this t' we get a new value and then setting it as an initial value we do the same calculation.
    • cfd_learner
      what is its effect on the accuracy if either use a time scale factor of 0.1, 1.0 or 10?
    • vinayak chauhan
      hi,
      When you reduce the size of element, you are recommended to reduce the time step correspondingly. Hence you need to scale it down or up based on your mesh details for better results. Also time steps judge the number of iterations for convergence.
Viewing 3 reply threads
