February 23, 2023 at 3:23 pm
Yannik Danner
SubscriberHello,
i have a hopefully simple question for using UDF.
I try to implement a new coalescence kernel for PBM.
This contains the turbulent energy dissipation rate epsilon.
I am using:eps = C_D(cell, tm);
turbulence model is RNG k-epsilon.
I get a SIGSEGV
The fl process could not be started.I know its about epsilon because error does not occur when using eps = const.
what do i have to consider?
Thank you. -
February 23, 2023 at 4:46 pm
Ansys Employeehttps://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_models_popbal.html%23x1-520006.2.1 Which multiphase turbulence option is picked (mixture, by phase)?
February 23, 2023 at 7:19 pm
Yannik Danner
SubscriberI am using the "dispersed" option
February 24, 2023 at 8:52 am
Yannik Danner
SubscriberUpdate: I tried using:
eps = C_D(cell, tp);
with Thread *tp as primary liquid phase.
No error occurs.(because "dispersed" option only uses primary phase dissipation rate)
Theory Guide for Prince&Blanch Aggregation Kernel says it is using dissipation rate for liquid phase as well.
Is this approach appropriate?
February 24, 2023 at 11:34 am
Ansys EmployeeProbably, bear in mind as you change the turbulence option that it may alter where the C_D data is kept. Mixture and Dispersed probably retain the mixture level but per phase may not.
3930
2649
1865
1272
610
