SIGSEGV-The fluent process could not be started.
    • Naiara
      I have a case defined with EDC model, then I change it to FGM model. I create Flamelet table, and after that, I crease PDF table. But as soon as PFD table is created successfully the following message appear in TUI and FLUENT stop working, do you know what I can to to solve it? Thank you!!!
      "Node 0: Process 12929: Received signal SIGSEGV.
    • DrAmine
      might be to lot of reasons. I hope you were able to run your case.
      A.
