August 5, 2023 at 2:43 pm
SAURAV GAUTAM
Subscriberis it possible to simulate a dopped silicon structure in FDTD to get change in absorption due to dopping in FDTD?
or it can only be modeled in CHARGE?
Please share link if there is any example available
thank you
August 6, 2023 at 12:18 am
Devika Padmakumar Nair
Ansys EmployeeHello, As far as I know, there is no direct way to perform doping to materials in FDTD. In FDTD, you can look for your doped material permittivity then import that data to FDTD.
I would sugget to use CHARGE.
Thanks.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7776
4504
2971
1449
1322
