November 1, 2018 at 12:20 pm
prashant
Subscriberi have made a simple geometry of 2 rectangles 50x25 mm2 mounted on each other ,bottom one is fillled with water and the top one is filled with air only diffussion is taking place,i am able to calculate heat flux across interface.as in post processinf it is generating contour of temprature and heat flux but i m not able to trace value of temperature at particular point.
November 1, 2018 at 12:36 pm
November 2, 2018 at 4:24 am
November 7, 2018 at 10:55 am
Karthik R
AdministratorHello Prashant,
Apologies for my delayed response.
Do you have a coupled wall condition at the interface?
what is the heat transfer rate at the wall and its shadow? Please share the screenshot of the flux report. Please do not use any surface integral to do this.
Looking forward to hearing from you.
Best Regards,
karthik
November 9, 2018 at 4:04 am
prashant
SubscriberIn design modular i have made two rectangles and after defining them surface i have made both the rectangles as one part so no interface is there in meshing.as well as i had not defined any boundary conditions on interface and applied all the conditions as shown in previous post.
Waiting for your response egerly
2524
2066
1279
1096
457
