November 23, 2020 at 8:43 pm
kitzo2
SubscriberI have some simple questions concerning drawing a pretty simple 3D design.
I am unsure how to rotate shapes perfectly onto surfaces that are on an angle from the origin. --> if you look at the attached picture you will see that the Tx ferrite core bars (purple) are made up of two rectangles put together. I am confused on how to attach these two rectangles perfectly other then plotting it form the origin which seems near impossible. Sorry for the inconvenience. Thank you!
November 24, 2020 at 1:18 ampeteroznewman
SubscribernOne of those Tx core bars lies along a coordinate axis, so when you sketch the outline of that, it is easy to align the two rectangles.nAfter you have created that solid, then you use the Pattern feature to rotate 7 copies to have 8 spokes around the circle.nViewing 1 reply thread- The topic ‘Simple drawing tool questions’ is closed to new replies.
Trending discussions- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
