January 28, 2023 at 4:37 am
Muhd Zafir Firdaus
SubscriberHi, I am planning to simulate a simple TEC module in thermal electric ansys simulation to analyse the peltier cooling effect. From the image, you can see my boundary conditions set onto the diagram. However, when I input a reasonable current, it seems that both junction temperatures only changes very little, about 0.7 degree celcius on both sides. I conducted real-life experiments using a peltier module with similar parameters and got reasonable results. It seems like my simulation does not output the correct values. May I know if I am missing something in my simulation? Please let me know if you need more information. thank you.
February 3, 2023 at 6:57 am
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- pcb
- problems facing during solution
- Still facing the same issue
- Simulation of a single pillar of a peltier cooler
- Ansys Sherlock Mechanical Shock and Vibration Analysis Error
- Extraction of parameters of mosfet
- Simulation of MoS2 with Au Nanoparticles
- Simulation For Solar Module
- Apache Timing Engine error message
5290
3311
2471
