December 10, 2022 at 7:13 pm
javat33489
SubscriberI am a young engineer. And I often face the limitation of the power of my PC and calculations. Please tell me this question. I have a rubber ring that I'm trying to squeeze. I know the material and I digitized it. The ring cannot be made symmetrical or axially symmetrical, because the cutouts are not symmetrical. It has to be counted in its entirety. With a good grid, at least 1 mm, this is 500k elements. My PC cannot do this. Maybe there are life hacks to simplify the calculation yet?
December 11, 2022 at 1:56 am
Mike Rife
Ansys EmployeeHi javat33489
Define compressibility for the material so that mixed uP elements are not needed, and an iterative solver (PCG) can be used. Mike
December 11, 2022 at 5:18 pm
javat33489
SubscriberI know about the direct solver.
It is possible here in more detail?
December 11, 2022 at 5:31 pm
Mike Rife
Ansys Employeejavat33489
What kind of details?
December 11, 2022 at 6:43 pm
javat33489
SubscriberDefine compressibility for the material so that mixed uP elements are not needed What do you mean? Please describe in more detail?
December 11, 2022 at 7:10 pm
SubscriberWhat material model are you using for your rubber? What material constants are you using for that model?
December 11, 2022 at 7:23 pm
javat33489
SubscriberI am using Ogden 1 order.
Constants built using curve fitting.
December 11, 2022 at 9:05 pm
SubscriberPlease reply with a screen shot of the material constants.
December 12, 2022 at 12:19 am
Mike Rife
Ansys EmployeeThe 1st order Ogden has 1 incompressibility term. If this is not defined then the material is incompressible and mixed uP elements are used. For incompressible hyperelastic materials the mixed uP elements enforce the uP via Lagrange multipliers. Iterative solvers like PCG have a hard time solving when stiffness matrix has Lagrange Multipliers (or cannot solve it at all). So the sparse solver must be used. Or define some compressibility for the material and then don't use the mixed uP formulation (this is done automatically in WB Mechanical). The PCG solver uses about an order of magnitude less RAM than the sparse (direct) solver does. So in a hardware limited situation, we try to use an iterative solver if possible.
Mike
December 12, 2022 at 6:17 pm
javat33489
SubscriberThank you all is clear. Tell me, can I experimentally substitute small incompressibility values? Start for example with 1E-8 and gradually increase
December 15, 2022 at 5:16 pm
javat33489
SubscriberTell me, can I experimentally substitute small incompressibility values? Start for example with 1E-8 and gradually increase
December 15, 2022 at 5:26 pm
Mike Rife
Why not? Have you tried running a test?
December 15, 2022 at 7:42 pm
javat33489
SubscriberYes, I tried with the incompressibility parameter 1E-8, the result is much better, the rubber began to compress. The calculation is on my PC. The iterative solver + enabled incompressibility 1E-8 helped me. Decides of course long but faster than it was. Should I gradually decrease the incompressibility parameter or is 1E-8 small enough?
December 15, 2022 at 8:05 pm
Mike Rife
Deciding what to do from here depends on 1) the intent of the analysis and 2) whether a more accurate incompressibility is required for that intent and 3) if you have enough information to make a better choice of incompressibility.
2066
1279
1096
457
