Simplified Stirling engine simulation
    • rshukla786
      how to simulate the piston cylinder arrangement of gamma type stirling engine in ansys fluent.
      Can the six dof solver can be used for this purpose??
      how to provide the effect of connecting rod and flywheel without drawing them.
    • José Mantovani
      Hello rshukla786.  Here in the Chapter 11 of Fluent Theory Guide have some informations about mesh process. I also linked the Fluent Theory Guide site.
      https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/wb_icom/icom_mesh_comb.html
      https://www.sharcnet.ca/Software/Ansys/16.2.3/en-us/help/flu_th/flu_th.html
      I hope helped you per hour .
      Mantovani.
    • rshukla786
      thnx @ Jose Mantovani but stirling engine doesn't involve with combustion its different from IC engine. Beacuse of heating and cooling of gas periodic motion is there in Stirling engine. Inertia of flywheel plays the major role in this motion.
    • Raef.Kobeissi
      Something very simplistic but might help you:
    • rshukla786
      in my case I can't give manual profile motion to piston as it is caused by the fluid thrust. so please how to analyse the motion due to fluid thrust.
Viewing 4 reply threads
