Ansys Products
Ansys Products
Simplorer simulated voltage 5X larger than calculation
    • Lawrence Ho
      Hi all,
      This should be a very simple question, but as a layman of electronics I found myself stuck badly.
      I am trying to verfify the simulated voltage of the Tx (big coil at the bottom) with hand calculation.
      From Maxwell, the self-inductance of the Tx coil is 3.18e-4H.
      The source applied is Alternating Current 4A, with frequency 6.8MHz (6.8e6 Hz).
      Then simulation was completed with result below.
      However according to the followng formulas:
      1). I = Vrms/Z, where Z=r+Lf,
      Vrms should equal: 4*(3.18e-4 * 6.8e6) =  8649.6V, assuming zero internal resistance r.
      2). Vrms= Vpeak * 0.7071
      so Vpeak = 8649.6/0.7071 = 12232.4V !
      Can someone here rescue me please?
    • DELI
      Hi, what type of winding is used in Maxwell excitation. solid or stranded winding? For solid winding type, resistance will be considered.
