May 19, 2023 at 1:49 pm
Shiva2810
SubscriberHello everyone
I am trying to perform co-simulation between Simplore and Simulink. Simplorer for PM Motor+Invertrer and Simulink for the control part. When I use the fractional model of the motor everything is fine and the results are as I expected. However, by connecting the whole motor model, I face a problem with the results. I attached a picture of the whole system and output current.
Could you please write a comment if you solved this issue earlier?
Thanks
May 30, 2023 at 11:22 am
phuonganhlovely.me
Subscriberi got same problem here
have u solve the problem? can u share with us ?
please contact with me by this email : Deleted (Rob). Please keep the conversations on here so others can learn from the outcome.
May 30, 2023 at 2:06 pm
Shiva2810
SubscriberHello.
I found that the Maxwell model is the problem here. Because I made the full model using MotorCAD, if you can make it using RMXprt then you will not face this issue.
May 31, 2023 at 2:39 am
May 31, 2023 at 4:57 pm
phuonganhlovely.me
Subscribercan you contact with me by mail: my name +@gmail.com
thanks
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5242
3299
2469
