November 14, 2023 at 12:52 pm
November 14, 2023 at 2:21 pm
Federico Alzamora Previtali
Ansys EmployeeThis message tells you that there are currently 2489 cells where the Temperature is 1 K. I would suggest you look at your solution and inspect why you are getting this temperature. Look at your mesh quality for example. Are you resolving the boundary layer sufficiently?
November 23, 2023 at 2:35 am
Manuel Pacherres
SubscriberHola Federico, disculpa la demora.
Mejoré mi mallado y coloqué capas límites. Ahora ya no tengo ese mensaje en la consola.
Muchas gracias por la ayuda.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- obtaining pressure distribution by making points in ansys
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
8808
4658
3155
1688
1478
