April 28, 2022 at 4:17 pm
robin888
SubscriberMay 20, 2022 at 12:29 amNavya C
Ansys EmployeeHi @robin888 You can change the excitation as current in the external circuit and then keep it constant for a constant load purpose or set it as per the load condition.
Then make the speed a variable to change the speed instead of the load settings under motion setup.
Run parametric with speed.
Regards Navya
May 20, 2022 at 3:01 amrobin888
Bldc needs square wave current ideally. So how to set this kind of waveform in current excitation? I tried to use pwl function but I don't know how to vary it for each phase and also how to assign it properly. It would be very helpful if you could explain how to assign current excitation correctly for bldc motor. This is where my confusion exists. Thanks in advance.
Viewing 2 reply threads- The topic ‘Simulate BLDC motor at constant load and varying speed using Maxwell’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3155
1688
1478
