February 28, 2022 at 5:51 pm
Soraya
SubscriberHello,
I want to simulate the mixing of two fluids (CO2 and water) inside the eductor. The high-pressure SC-CO2 (1250 psi, 35°C) passed through the designed Joule-Thomson nozzle to expand inside the eductor as -78°C and emerge as a cryogenic fluid and mix with water which suctioned to the eductor (Bernoulli's principle).
Firstly, I used Pressure-based solver and I got error and divergence plot. Then, I used Density-based solver and step by step increased the pressure to reach to desired one. I am using the real gas Peng Robinson for density of CO2. I'm getting convergence plot now; however, the temperature contour is kind of odd (it shows -104 degree C). It seems the joule-Thompson effect is not captured. How can I make sure that the phase change happening and J-T effect is activated?
In Density-based solver the option of multi-phase flow is OFF and only "wet steam" is ON. How can I define the second fluid (water) into the system?
Looking forward to hearing from you. Thanks,
March 1, 2022 at 11:57 amRob
Ansys EmployeeI don't think you do with the density based solver - it's for single phase for the most part. Chances are it's also very transient.
2656
2120
1349
1118
461
