Ansys Products
Ansys Products
Simulating a car crash using MPP restart method
    • 日凯 林
      I used MPP in LSDYNA to perform pre-loading on my frame and then performed a car collision using a restart file. However, the car did not collide with the frame and instead disintegrated in its own place, as shown in the figure. This issue did not occur when I used SMP for simulation. What could be the reason for this?
    • Jim Day
      Please specify the type of restart (simple, small, or full as described in the RESTART section of the User's Manual) and state the version of LS-DYNA you're running.
      • 日凯 林
        The version of LS-DYNA being used is R13, and a full restart is being performed.
    • Jim Day
      Are you restarting from d3dump (SMP) or d3full (MPP) data that was written at the end of a dynamic relaxation analysis? If so, I suggest that instead of attempting a full restart (which even if done correctly may exhibit a lack of robustness), you use the drdisp.sif data written at the end of the dynamic relaxation and IDRFLG=2 in *CONTROL_DYNAMIC_RELAXATION to initialize to a prescribed geometry. I invite others with automotive experience to contribute their suggestions/comments.
