Simulating a compliant mechanism
    • edoardo
      Hello everyone,
      My latest assignment consists in simulating the loading condition for a flexible pivot:
      while I successfully simulated the loading in tension, I'm struggling with the compression case, which is something like this:
      so i fixed the yellow sleeve, and applied a remote force on the green sleeve (both sleeves are rigid bodies)
      here i hide the green sleeve, to show the fixed support on the end of the flexible elements (which are bonded to the sleeves). I then applied a remote force on the yellow sleeve.
      When I try to solve, I get something like this:
      This is what I get after already trying to solve the bisection issue by increasing the initial substeps with a factor of 5 from 100 to 500, and after increasing the mesh refinement where the Newton-Raphson residual told me to. Now I'm out of ideas.
      Here is the model if anyone wants to take a look at it:
      https://drive.google.com/file/d/1NsHx6BeRY8W1aO4cWu81bKvwD_S8hhSu/view
      Thanks in advance for the suggestions
      Edoardo
    • Aniket
      Ansys employees are not allowed to download anything from the student portal. What error do you get in the solver output file?
      -Aniket
    • edoardo
      hello Aniket,
      I found a way to solve my issues.
