Simulating a hammer
    • dillly96
      Hello all;
      I am trying to simulate a hammer hitting an object to see how the face and handle would be affected however I seem to get the following errors.
      The titanium alloy is the closed one that gets results but still the same error.
    • 1shan
      Have you turned Large Deflection "On" (Under analysis settings)? Use auto time stepping with 1000 initial and minimum substeps. Also try using a finer mesh.
      Regards Ishan.
    • dillly96
      Good morning a have Large Deflection On and auto time stepping with 1000 initial and minimum substeps
      I have also used a finer mesh but still get the same errors shown in the images
    • dillly96
      Hello, all I still am having these errors what might be causing this?
Viewing 3 reply threads
