March 28, 2021 at 6:14 pm
wchayeb18
SubscriberHello,
I am trying to create an array of two rotated rectangles, a column with angle 1 rotated rectangles and the other with angle2
March 30, 2021 at 10:08 pmGuilin Sun
Ansys EmployeeThis is an interesting device. As you know, objects need a center location (x,y,z). as long as you can give the correct locations of the objects at different angles, you will be able to place them correctly. For a simple test, please just use one rectangle, same size, same rotation angle, and try to set it into the spiral curve. Once it works, I believe you will know how does it work, and can apply this to the actual component with more rectangles. nViewing 1 reply thread- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1279
1096
457
