March 8, 2021 at 1:33 pm
Atgeirr
SubscriberHello there everyone,nI'm trying to simulate an exhaust system for a motorcycle as complete as possible. As of right now I've successfully simulated to flow within the pipes and the heat transfer into the metal. However while driving a motorcycle the airflow traveling over the exhaust pipe will also cool the pipes down quite a lot. I would like to include this within my simulations but I honestly have no idea how to implement this. Best case scenario is that I could sim both internal and external in one go within Fluent but I doubt that's possible.nFrom my (rather limited) understanding K-w SST is not usable for external flow and it is the viscous model that has given me the best results for internal flow. Which made me think that the only solution is the connect the results from my internal sims to a new external sim. However there are a lot of smart people on this forum so I was hoping someone knows if it's possible to do both the internal and external flow at the same time within Fluent. nThank youn -
March 9, 2021 at 3:45 am
Keyur Kanade
Ansys EmployeeYou can do internal plus external in one session. This would require you to include internal and external domain in single session. Mesh them in single session. Please note that this will increase the mesh count. If you want to use kw sst, please make sure that you have defined inflation correctly. Please use last ratio method and then use first height of 1/10th of surface mesh size. This will help you to get good y+ value. You can find similar many discussions on this forum. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
March 9, 2021 at 12:39 pm
Atgeirr
SubscriberThank you for your answer Kkanade.nKnowing it's possible to sim both internal and external will save me a lot of time at work. Even though that might seem counter-intuitive.nHowever I have a follow-up question:nI was taught to calculate my first layer height based on the desired Y+ of the viscous model (in this case 1March 10, 2021 at 3:52 amKeyur Kanade
Ansys Employee1/10th size usually gives y+ close to 1. nViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
