March 4, 2022 at 11:51 am
JamesMcIlree
SubscriberHi, I need to simulate cracks in different regions of a steel sheet. Example: top left, top right, bottom left, bottom right etc. However, these cracks need to be randomized so that each steel sheet with a crack is different to the rest.
How would I go about creating these cracks? And is there a script I can use to create an arbitrary number of these sheets, say a thousand or so?
Thank you.
March 16, 2022 at 5:06 pmAshish Khemka
Please see if the following link helps you:
how to create a crack on a 3D surface body in ANSYS workbench? ÔÇö Ansys Learning Forum
Regards Ashish Khemka
2564
2068
1289
1106
459
