February 28, 2022 at 3:40 pm
mha75
SubscriberHi,
I would like to simulate four square-shaped electrodes in a non-uniform electrical field (through AC conduction). I would like to also add varying current frequencies to mimic a system where frequencies can induce different dielectric responses in particles suspended in a conductive medium. Can this be done in 3D Maxwell?
March 4, 2022 at 7:53 pmDeyu Li
Ansys Employeeyou can use a dataset as the varying current excitation, that dataset could be any shape of waveform.
March 5, 2022 at 2:21 pmmha75
Subscriberthank you for your response. I haven't tried that yet. I will attempt to do so.
- Maxwell, HFSS or Q3D?
- Error
2600
2088
1319
1108
459
