February 18, 2023 at 12:33 pm
Eng.Iman
SubscriberI need help for simulating pin diode for my reconfigrable antenna.
I used lumped RLC when I start the simulation it shows warning that I have boundary overlapped
How could I connect the pin diode and make it connected to the antenna body without overlapping?
February 21, 2023 at 4:49 am
Chinmay T
Ansys EmployeeHello,This is just a warning message, so you can proceed to analyze the model.Please share the screenshots of the model and how you assigned the boundary condition.Thanks,Chinmay-
March 13, 2023 at 1:27 pm
Eng.Iman
SubscriberThanks, the issue is solved.
- Maxwell, HFSS or Q3D?
- Error
3648
2512
1743
1226
578
