April 24, 2022 at 4:45 pm
cameronl99
SubscriberHello,
I have acquired a CAD model of an urban area and would like to simulate RF propagation in that model using HFSS SBR+. The model is currently in a SpaceClaim project and I have tried exporting it as .DXF and STP. files and in both cases the models were empty when I opened them up in soldworks. Unfortunately, it seems as if my Ansys Electronics Desktop Student 2021 install can only import .DXF and. STP files. I have tried exporting the SpaceClaim project as an .STL but my electronics desktop install refused to take that file as an input.
Can someone provide a recommendation as to what I should do in order to simulate RF propagation in a large urban environment using Ansys software?
Best,
Cameron
May 5, 2022 at 6:55 amPraneeth
Forum Moderator
Please note that the student version of AEDT is not capable of simulating large structures like urban areas.
Kindly use the regular version for doing this simulation.
Also in regular version you can connect to the SpacelCaim model from the AEDT user interface.
All the very best Praneeth.
May 5, 2022 at 1:21 pmcameronl99
Thank you for your help :)
Is there a student/research discount for AEDT? I could not find this information on your website, nor could I find information on the regular pricing.
Best Cameron
May 5, 2022 at 1:57 pmPraneeth
Forum Moderator
Please go through the following link - Engineering Simulation Software | Ansys Products, select the required product and click on "Contact US".
Provide the required details and submit. Our concerned team will definitely contact you shortly.
May 5, 2022 at 2:59 pmcameronl99
SubscriberI have done this and I am still waiting on a response. If you could elevate my request I'd very much appreciate it :)
September 7, 2022 at 11:16 am
Praneeth
Forum ModeratorHi Cameron,
Did someone contact you on this yet?
Best regards,
Praneeth.
Viewing 4 reply threads- The topic ‘Simulating RF Propagation in Urban Areas’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3155
1688
1478
