Simulating thin coating layers on the surface of a polymer material
    • AliMosayyebi
      I am trying to simulate a thin layer of coating (~100um) around a small cylinder (ID 1.5mm, OD 2.5mm, Height 10mm). I would like to look into the desolvability of the coating and its impact on particle deposition. Is there a way that ANSYS can do it?
      Tnx
Viewing 0 reply threads
