Discovery Import
Discovery Import
Simulation
    • mikael
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Here is the first problem from the new customer. We dont get any result from the simulation. Can you see whats wrong?
      BR, Mikael
    • Subashni Ravichandran
      Hello Tormod
      Thanks for share the file. Let me look into it and get back to you.
      Hello  Tormod
      I see that any of the Bonded contacts are overlapping with the Fixed and Hinged joints created.
      Please remove the bonded contact (set to prevented contact) at the joint locations to avoid this error.
      You can use the red icon in bonded contact to change it to prevented contact at these locations.
    • mikael
      Hi, This is a new customer He has some more questions regarding this. Is it possible to have a web session with him so we can answer his questions?
      BR, Mikael
      The solution was provided over call.
      The overlapping boundary conditions of contacts and  joints caused the issue
Viewing 4 reply threads
