December 18, 2018 at 11:57 am
gkeee
SubscriberI drew antenna with lumped port exitation, and solution 10 GHz(interpolating 1-10 GHz) . After the simulation starts, it stops with error "as simulation completed with execution error on server"
When the simulation is in "HFSS starting" , it stops.
Is it about unnecessary Ram?
December 19, 2018 at 9:31 am
Ansys EmployeeNot sure: I'll ask one of the HFSS users to have a look. When you do try this can you check if you have free RAM?
I can't view the images (ANSYS rules) so please repost in the text.
December 19, 2018 at 1:57 pm
dloricch
Ansys EmployeeThis is a general error message. I suggest you to check your simulation profile where probably you will find further details on the failure.
Try to define under the same setup another frequency sweep in the same frequency band and to run it.
December 25, 2018 at 5:21 pm
gkeee
SubscriberThis error message is shown at Hfss 19.2 , ? tried at 19.1, it has solved. Do have any idea about this?
Thank you.
December 26, 2018 at 6:32 pm
tsiriaks
Ansys EmployeeFrom AnsysEM 19.2 GUI, if you 'open examples' and try one of ANSYS sample HFSS projects, do you get the same issue in 19.2 ?
Thanks,
Win
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
459
