Simulation crash without error
    • Alberto
      I'm trying to solve a dynamic mesh problem, but when i'm about t=0.09s fluent close itself and display no error messages.
      How can i understand the problem? otherwise it is no longer possible to continue computation
      Anything in the transcript (.trn) file? Did you hit any time limits on the cluster, or use solution steering?
    • Alberto
      How can i find this file? I don't know if it is a question of time limits because fluent closes automatically without dispaly anything
      It should be in the working folder. Fluent rarely "disappears" without some error somewhere, but if the cluster run duration limits are reached it will: we see that here when running tests on the short duration queue.
    • Alberto
      Maybe this is the error, it look likes memory error message..any suggestion on how to handle and continue simulation?
      Error [cortex] [time 3/31/23 12:8:36] Cortex received a fatal signal (SEGMENTATION VIOLATION).
      OK. Segmentation error tends to suggest the solver had a problem, and with moving mesh that could be diveregence or the remeshing did something odd. What else does the last section of the .trn say? Specifically the last couple of time step residual blocks.
    • Alberto
      This is an error on a different simulation, which is still running, so does not compromise it. I don't find any file in my working folder so i can't tell you more. It is possibile that this is due to the fact that i'm trying to simulate the falling of a seed in a 3D domain, and when it start to rotates it create some problem?
      That sounds like the remeshing had a problem, check you're not moving too quickly as the seed begins to tumble. Ie you may need a smaller time step.
    • Alberto
      ok, but i’m using 1e-05 as timestep which is too small, i have a mesh with 110k elements (unstructured tetrahedral) with refinement around the seed body. As remeshing method i’m  using the unified which works good when i perform a 1DOF simulation allowing the seed to translate uniquely along vertical direction. For what concern the smoothing i’ve choose diffusion with 2 as diffusion factor.
      Time step is a function of speed and cell size. If the seed tumbles can the rotational speed mean the time step becomes too big?
    • Alberto
      I'll try to set 5e-06 as dt. How about diffusion and unified remeshing? they're the good choice for this type of problem?
      Pass, I don't tend to use moving mesh. Check the example videos in Help. The two tutorials are for overset, which is an alternative method.
    • Alberto
      Can you link or provide some materials about overset mesh ? what i found is not complete and i can’t understand the method.
      Many thanks for the help given up to now
      Only what's on the Help system, I can't share anything from the Learning Hub.
    • Alberto
      I've found these two files:
      cortex error which says: " Error [cortex] [time 4/17/23 17:36:40] Cortex received a fatal signal (SEGMENTATION VIOLATION). "
      fluent-999999-error which states: " Error [node 999999] [time 4/17/23 17:36:36] Abnormal Exit! "
      In addittion I can't continue the computation it seems like it is finisched but it was only at 12% and it took 2 days.
      How does your set up compare with the examples? The above isn't overly diagnostic. Is there not a transcript file (.trn) which has something? Ideally post the few lines above the error & the error as it's the trigger that's most likely to help.
    • Alberto
      I dont find this .trn file inside any folder. The above messages are all error files fluent returns to me.
      And you're running stand alone? Ie no Workbench? I can't diagnose anything from what we have so far.
    • Alberto
      I've found this .trn file inside ansys file which i link here: https://drive.google.com/file/d/1pIVsTqoAOqPVjHmTXwL1q0f5pDjn9y4a/view?usp=share_link
      many thanks in advance
      I'm not permitted to open that: it's one of the rules to allow staff to answer questions on here. Please post the last few iteration lines and first some error messages.
    • Alberto
      Updating solution at time levels N and N-1.
      6DOF angular solver has not converged
      6DOF angular solver has not converged done.
      Updating mesh at time level N... done.
        iter  continuity  x-velocity  y-velocity  z-velocity           k       omega    intermit     retheta     time/iter
       100799  8.6132e-04  5.0025e-06  5.4756e-06  5.9177e-06  1.2778e-06  4.6477e-06  2.9313e-08  4.3843e-08  0:00:11   12
       100800  3.4947e-03  5.8489e-05  5.9952e-05  6.6332e-05  3.0098e-05  9.6385e-05  2.6096e-07  8.8221e-07  0:00:13   11
       100801  1.8936e-03  1.7863e-05  1.8692e-05  2.0957e-05  6.0513e-06  1.9697e-05  8.0019e-08  1.9280e-07  0:00:11   10
       100802  9.5855e-04  5.5207e-06  5.8881e-06  6.6502e-06  1.2177e-06  5.1505e-06  3.5600e-08  4.4790e-08  0:00:08    9
      !100802 solution is converged
        step  flow-time   flow-time          cl          cd
       32950  2.6360e-01  2.6360e-01 -1.3622e-02  1.5761e-02
      Flow time = 0.2636000000000984s, time step = 32950
      267050 more time steps
       100802  9.5855e-04  5.5207e-06  5.8881e-06  6.6502e-06  1.2177e-06  5.1505e-06  3.5600e-08  4.4790e-08  0:00:11   12
       100803  3.9090e-03  6.8440e-05  7.9123e-05  8.3832e-05  3.0006e-05  9.5593e-05  2.7165e-07  8.8165e-07  0:00:10   11
       100804  2.0903e-03  2.0539e-05  2.3673e-05  2.4854e-05  6.0327e-06  1.9680e-05  8.0529e-08  1.9295e-07  0:00:09   10
       100805  1.0492e-03  5.9002e-06  6.7989e-06  7.0504e-06  1.2142e-06  4.8732e-06  3.4632e-08  4.5152e-08  0:00:09    9
      Done.
      Registering ReportDefFiles, ("C:\Users\Alberto\Desktop\sim_ansys\simulazione_\coarse_mesh_falling_seed_files\dp0\FFF-2\Fluent\.\\cd-rfile.out" "C:\Users\Alberto\Desktop\sim_ansys\simulazione_\coarse_mesh_falling_seed_files\dp0\FFF-2\Fluent\.\\cl-rfile.out")
      Writing "| gzip -2cf > SolutionMonitor.gz"...
      Writing temporary file C:\\Users\\Alberto\\AppData\\Local\\Temp\\flntgz-53842 ...
      Done.
      Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\sim_ansys\simulazione_\coarse_mesh_falling_seed_files\dp0\FFF-2\Fluent\FFF-2-4-32951.cas.h5" in NODE0 mode and compression level 1 ...
            402421 cells,     1 zone  ...
            812558 faces,     3 zones ...
             71584 nodes,     1 zone  ...
        Done.
        Writing boundary layer flags ...
        Done.
      Done.
      Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\sim_ansys\simulazione_\coarse_mesh_falling_seed_files\dp0\FFF-2\Fluent\FFF-2-4-32951.dat.h5" in NODE0 mode and compression level 1 ...
        Writing results.
      Done.
      Performance Timer for 9874 iterations on 30 compute nodes
        Average wall-clock time per iteration:                1.395 sec
        Global reductions per iteration:                        585 ops
        Global reductions time per iteration:                 0.000 sec (0.0%)
        Message count per iteration:                         250192 messages
        Data transfer per iteration:                        210.863 MB
        LE solves per iteration:                                 15 solves
        LE wall-clock time per iteration:                     0.258 sec (18.5%)
        LE global solves per iteration:                          11 solves
        LE global wall-clock time per iteration:              0.003 sec (0.2%)
        LE global matrix maximum size:                          744
        AMG cycles per iteration:                            18.872 cycles
        Relaxation sweeps per iteration:                       1368 sweeps
        Relaxation exchanges per iteration:                       0 exchanges
        LE early protections (stall) per iteration:           0.000 times
        LE early protections (divergence) per iteration:      0.000 times
        Total SVARS touched:                                    433
        Time-step updates per iteration:                       0.28 updates
        Time-step wall-clock time per iteration:              0.850 sec (60.9%)
        Total wall-clock time:                            13775.651 sec
      There's nothing there other than a solver complaint about the 6DOF convergence. Lift & drag coefficients are small, but the 6DOF model should use the forces: I assume they're sensible?
    • Alberto
      yes, it should use the forces from fluid to compute motion. what can i do about 6 dof angular convergence?  I've insert the inertia tensor (which is symmetric non diagonal) due to non symmetry in my geometry. I've set the material in a wrong way maybe, becouse i've changed from aluminion to wood-maple, but aluminium still be there
      I suspect your problem is linked to the motion, so check the forces just before the model fails. Also, how fast is the object rotating? Ie is it trying to flip? That could mean it's moving too quickly for the solver, which then diverges.
    • Alberto
      yes, it tumble and flip, it rotates at 160 rad/s. I'm able to capture the motion, i.e. i can visualize the solid body which falls while it translate and rotates but when it approach the walls simulation crash. I can solve this by enlarging the domain, it is not a problem of solver. But still to get this message: six dof angular solver do not converge. This can affect the computation accuracy ?
      The object gets close to or contacts a wall? That'll be a problem unless you've got the collision UDFs on. The moving mesh can't have walls making contact as it breaks the mesh topology.
      Separately the 6DOF solver may be struggling with the rotation speed depending on the time step size relative to the cell size.
    • Alberto
      The object contacts a wall, i've enlarged the domain to avoid that, but angular solver still not converge. It is possible that it is due to a wrong initial setting of the orientation of the object ? cause the only things i know are: inertia tensor and center of gravity. Anything about initial configuration (orientation)
      Initial orientation will have some effect, but that should settle as it falls. Assuming the heavy end finishes up at the bottom and the "slower" bit is at the top.
    • Alberto
      Hi, what this error means? I'm  simulating a dynamic mesh with k-w model for turbolence, and my setup always crash at certain time giving the abnormal exit error without more info. I don't enconteur negative volume cells or divergence problem, I'm running with 15 cpu over a machine with 80 and i'm connected to internet with the lan. Any ideas ?
      OK, to summarise.
      You have:
      • a cortex error, but no other information
      • a transcript that shows a normal end to a run with files saving & parallel data. OK, so the solver isn't converging well but nothing looks wrong
      • domain is big enough to avoid the falling object hitting anything
      Is the extended domain is all one fluid region?
      • Alberto
        yes, when i'm creating the dynamic mesh zone, i make the body as rigid body and the fluid as deforming. In addition i've also create the interior-fluid as deforming, which is a zone automatically created by fluent. Simulation crash also if i solve with one dof only, for example only translation, so no hitting occurs
      OK, so it's potentially the rotation. What remeshing have you got on the fluid?
      • Alberto
        No, becouse it happens also when i'm translating only ( 1DOF). I'm using a unified remeshing method with diffusion coefifcient of 2 or more
      Oops, translation not rotation. OK, so what do the flow & mesh look like just before it fails?
      • Alberto
        This is the report, nothing seem strange also residuals are close to 0 before it fails.
        Fluent
        Version: 3d, dp, pbns, dynamesh, sstkw, transient (3d, double precision, pressure-based, dynamic mesh, SST k-omega, transient)
        Release: 22.2.0
        Title:
        Models
           Model                        Settings
           Space                        3D
           Time                         Unsteady, 2nd-Order Implicit
           Viscous                      SST k-omega turbulence model
           Heat Transfer                Disabled
           Solidification and Melting   Disabled
           Species                      Disabled
           Coupled Dispersed Phase      Disabled
           NOx Pollutants               Disabled
           SOx Pollutants               Disabled
           Soot                         Disabled
           Mercury Pollutants           Disabled
           Structure                    Disabled
           Acoustics                    Disabled
           Eulerian Wall Film           Disabled
           Potential/Li-ion Battery     Disabled
           Multiphase                   Disabled
        Material Properties
           Material: wood-maple (solid)
              Property               Units      Method     Value(s)
              Density                kg/m^3     constant   532.17
              Cp (Specific Heat)     J/(kg K)   constant   1684.8
              Thermal Conductivity   W/(m K)    constant   0.25826
           Material: air (fluid)
              Density                kg/m^3     constant   1.225
              Cp (Specific Heat)     J/(kg K)   constant   1006.43
              Thermal Conductivity   W/(m K)    constant   0.0242
              Viscosity              kg/(m s)   constant   1.7894e-05
              Molecular Weight       kg/kmol    constant   28.966
           Material: aluminum (solid)
              Density                kg/m^3     constant   2719
              Cp (Specific Heat)     J/(kg K)   constant   871
              Thermal Conductivity   W/(m K)    constant   202.4
        Cell Zone Conditions
           Zones
              name    id   type
              fluid   4    fluid
           Setup Conditions
              fluid
                 Condition       Value
                 Frame Motion?   no
                 Mesh Motion?    no
        Boundary Conditions
           Zones
              name    id   type
              walls   5    wall
              seed    6    wall
           Setup Conditions
              walls
                 Condition                  Value
                 Wall Motion                Stationary Wall
                 Shear Boundary Condition   No Slip
                 Wall Surface Roughness     0
              seed
                 Condition                  Value
        Solver Settings
           Equations
              Equation     Solved
              Flow         yes
              Turbulence   yes
           Numerics
              Numeric                         Enabled
              Absolute Velocity Formulation   yes
           Unsteady Calculation Parameters
              Number of Time Steps       4000
              Time Step Size [s]         0.0008
              Max Iterations/Time Step   20
           Under-Relaxation Factors
              Variable                    Relaxation Factor
              Density                     1
              Body Forces                 1
              Turbulent Kinetic Energy    0.8
              Specific Dissipation Rate   0.8
              Turbulent Viscosity         1
              Explicit Momentum           0.75
              Explicit Pressure           0.75
           Linear Solver
              Variable                    Solver Type   Termination Criterion   Residual Reduction Tolerance
              Flow                        F-Cycle       0.1
              Turbulent Kinetic Energy    Flexible      0.1                     0.7
              Specific Dissipation Rate   Flexible      0.1                     0.7
           Pressure-Velocity Coupling
              Parameter             Value
              Type                  Coupled
              Flow Courant Number   200
           Discretization Scheme
              Variable                    Scheme
              Pressure                    PRESTO!
              Momentum                    QUICK
              Turbulent Kinetic Energy    QUICK
              Specific Dissipation Rate   QUICK
           Solution Limits
              Quantity                         Limit
              Minimum Absolute Pressure        1
              Maximum Absolute Pressure        5e+10
              Minimum Temperature              1
              Maximum Temperature              5000
              Minimum Turb. Kinetic Energy     1e-14
              Minimum Spec. Dissipation Rate   1e-20
              Maximum Turb. Viscosity Ratio    100000
      Other than the PBCS courant number being a little optimistic there's nothing obvious to cause problems. Pictures of what's going on in the model (ie mesh & contours) may help.
    • Alberto
      Before closing fluent automatically a window has appeared saying: “there’s no active application”  and then all is closed instantly.
      The mesh motion, contours of velocity and pressure are in agree with physics and nothing strange occurs. Convergence of scaled residual is also good and solution converges in 5 iteration.
      here the last rows of .trn file
      =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
      =   RANK 13 PID 16848 RUNNING AT DESKTOP-C8FD4F6
      =   EXIT STATUS: -1 (ffffffff)
      =   RANK 14 PID 24444 RUNNING AT DESKTOP-C8FD4F6
      ===============Message from the Cortex Process================================
      Fatal error in one of the compute processes.
      Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).
      Error Object: ()
      Error: There is no active application.
      Error Object: (rp-var-value 'pdf/filename)
    • Alberto
      Also some info on the mesh quality
      Minimum Orthogonal Quality =  9.67777e-02 cell 720 on zone 4 (ID: 168922 on partition: 11) at location (-4.73982e-03,  9.61930e-03, -4.66381e-04)
      Maximum Aspect Ratio =  2.29950e+01 cell 2542 on zone 4 (ID: 168589 on partition: 13) at location (-5.72564e-03,  1.96574e-02, -9.18095e-04)
      Now check how the mesh is deforming at the ends. How well resolved is the red "dot" at the left hand end?
    • Alberto
      Sorry I dont understand your question but the mesh does not deform, the picture is related to the latest timestep, i was able to run this simulation two week ago, with same setup, now they crash. Maybe it is related to a parallel setup ? or grapic card settings?
      What has gpu got to do with moving mesh? If the mesh does not deform how are you using 1DOF and dynamic mesh?
    • Alberto
      I was explain myself badly, mesh deforms, but near the solid boundaries anything strange like too deformed tetrahedral . I was able to run this simulation two weeks ago, so i dont think it is a mesh problem or model issue.
      In the .trn file also, this error occurs at each processor (i've run with 15 cores):
       done.
        iter  continuity  x-velocity  y-velocity  z-velocity           k       omega     time/iter
         760  9.9713e-04  1.5911e-05  1.3513e-05  1.8015e-05  2.0660e-06  1.0548e-04  0:00:45   20
         761  6.8108e-03  9.3173e-05  7.0772e-05  1.3309e-04  5.3867e-04  3.5784e-03  0:00:45   19
         762  3.6281e-03  4.8553e-05  4.0775e-05  5.7765e-05  1.2741e-04  1.6395e-03  0:00:42   18
         763  2.0489e-03  3.0135e-05  2.5671e-05  3.6498e-05  3.0753e-05  5.1376e-04  0:00:38   17
         764  1.3749e-03  2.2572e-05  1.9371e-05  2.6834e-05  7.6857e-06  2.0990e-04  0:00:38   16
         765  1.0560e-03  1.8779e-05  1.6088e-05  2.1766e-05  2.0604e-06  1.0932e-04  0:00:35   15
         766  8.5239e-04  1.6339e-05  1.3986e-05  1.8640e-05  6.4454e-07  7.1077e-05  0:00:32   14
      !  766 solution is converged
        step  flow-time   flow-time        drag
         186  1.4880e-01  1.4880e-01  5.6377e-04
      Flow time = 0.1487999999999995s, time step = 186
      3814 more time steps
       done.
      set_part_dest_tree: cell not found on myid = 7
      =   RANK 0 PID 23216 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 1 PID 9040 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 2 PID 26648 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 3 PID 22940 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 4 PID 28556 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 5 PID 19352 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 6 PID 20752 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 7 PID 2416 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 8 PID 26880 RUNNING AT DESKTOP-C8FD4F6
      =   EXIT STATUS: -1073740940 (c0000374)
      =   RANK 9 PID 6276 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 10 PID 27744 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 11 PID 16984 RUNNING AT DESKTOP-C8FD4F6
      =   RANK 12 PID 1988 RUNNING AT DESKTOP-C8FD4F6
      Error Object: ()
      Try with fewer cores. Otherwise, if it worked previously and not know I'm not sure. Also, try with PISO rather than PBCS: in transient there's little benefit to the pressure based coupled solver, and PISO may be better behaved.
    • Alberto
      And how about cores setting? maybe i have to change something, I think the error occurs during the parallelization, so the MPI crash. how can i reset to the default value of fluent without reinstall it ?
      It's a model failure, not the install. Try with fewer parallel cpu set and see if it's any better. Did PISO help?
    • Alberto
      With PISO model diverge in 5 iterations, then i've switch back to coupled and now also this crash at iteration 1. It is so strange
      Go back a few auto saves, then re-run with a smaller time step and look carefully at what's going on. Not just mesh, but also flow (including turbulence). I can only offer guidance.
    • Alberto
      I've reinstall, now the problem of crash is solved (i think) but the model crash due to non negative volume. here my trn file transcript. Do you think i have to lower the timestep? i'm using diffusion method with coefficient = 3 (maximum)
      Build Time: May 28 2021 13:53:52 EDT
      Executable Path: C:/PROGRA~1/ANSYSI~1/v212/fluent/ntbin/win64/fluent.exe
      ID    Hostname         Core  O.S.         PID    Vendor
      n4    DESKTOP-C8FD4F6  5/80  Windows-x64  14108  Intel(R) Xeon(R) Gold 6230
      n3    DESKTOP-C8FD4F6  4/80  Windows-x64  23480  Intel(R) Xeon(R) Gold 6230
      n2    DESKTOP-C8FD4F6  3/80  Windows-x64  15352  Intel(R) Xeon(R) Gold 6230
      n1    DESKTOP-C8FD4F6  2/80  Windows-x64  14232  Intel(R) Xeon(R) Gold 6230
      n0*   DESKTOP-C8FD4F6  1/80  Windows-x64  17316  Intel(R) Xeon(R) Gold 6230
      host  DESKTOP-C8FD4F6        Windows-x64  3176   Intel(R) Xeon(R) Gold 6230
      MPI Option Selected: intel
      Selected system interconnect: default
      Cortex Process ID: 20468
      License Server Path: 1055@192.168.64.92
      (cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Solution|Run Calculation"))
      (cx-gui-do cx-activate-item "NavigationPane*List_Tree1")
      (cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Solution|Calculation Activities"))
      (cx-gui-do cx-activate-item "Run Calculation*Table1*Table9(Solution Advancement)*Table1*PushButton1(Calculate)")
      Writing Settings file "C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF.set"...
          writing rp variables ... Done.
          writing domain variables ... Done.
          writing fluid (type fluid) (mixture) ... Done.
          writing interior-fluid (type interior) (mixture) ... Done.
          writing walls (type wall) (mixture) ... Done.
          writing seed (type wall) (mixture) ... Done.
          writing dynamic zone fluid ... Done
          writing dynamic zone seed ... Done
          writing dynamic zone interior-fluid ... Done
          writing zones map name-id ... Done.
      Fast-loading "C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\\addons\afd\lib\hdfio.bin"
      Done.
      Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-1-00000.cas.h5" in NODE0 mode and compression level 1 ...
        Writing mesh ...
            139800 cells,     1 zone  ...
            298818 faces,     3 zones ...
             33833 nodes,     1 zone  ...
        Done.
      Done.
      Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-1-00000.dat.h5" in NODE0 mode and compression level 1 ...
        Writing results.
      Done.
      Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-Setup-Output.cas.h5" in NODE0 mode and compression level 1 ...
        Writing mesh ...
        Done.
      Done.
       done.
           1  1.0000e+00  1.5394e-03  9.2497e-04  3.2958e-02  2.5839e-04  1.2843e+02  0:00:38   19
           2  1.0000e+00  1.0300e-02  9.6514e-03  3.1551e-02  2.8132e-04  5.9805e-01  0:00:43   18
           3  1.0000e+00  3.5683e-03  3.2347e-03  9.7273e-03  1.0939e-04  3.0929e-01  0:00:39   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 72 cells
           4  7.1627e-01  3.6252e-03  3.2389e-03  1.2984e-02  3.8179e-05  1.1170e-01  0:00:36   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 766 cells
           5  3.5641e-01  3.6778e-03  3.2471e-03  9.7443e-03  1.3667e-05  4.9692e-02  0:00:33   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1095 cells
           6  2.3952e-01  3.3818e-03  2.9535e-03  6.2383e-03  5.4956e-06  2.9290e-02  0:00:30   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1228 cells
           7  2.6042e-01  2.8038e-03  2.4592e-03  4.1362e-03  2.4816e-06  1.9059e-02  0:00:28   13
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1305 cells
           8  2.7782e-01  2.0806e-03  1.8673e-03  2.6871e-03  1.2321e-06  1.3265e-02  0:00:23   12
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1358 cells
           9  2.3487e-01  1.6792e-03  1.5371e-03  2.0153e-03  6.6088e-07  9.8420e-03  0:00:21   11
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1406 cells
          10  1.6773e-01  1.3507e-03  1.2445e-03  1.5990e-03  3.7781e-07  8.0851e-03  0:00:19   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1435 cells
          11  1.1101e-01  1.1002e-03  1.0142e-03  1.2781e-03  2.2999e-07  6.9081e-03  0:00:18    9
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1448 cells
          12  7.4687e-02  9.3017e-04  8.4935e-04  1.0524e-03  1.4990e-07  6.0414e-03  0:00:14    8
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1461 cells
          13  5.4305e-02  8.2594e-04  7.4357e-04  9.0613e-04  1.0449e-07  5.4012e-03  0:00:13    7
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1481 cells
          14  4.2460e-02  7.4220e-04  6.6124e-04  7.9079e-04  7.7275e-08  4.9258e-03  0:00:11    6
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1496 cells
          15  3.3651e-02  6.7879e-04  6.0255e-04  7.0941e-04  5.9726e-08  4.5727e-03  0:00:09    5
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1503 cells
          16  2.6478e-02  6.3267e-04  5.6399e-04  6.5592e-04  4.7105e-08  4.3177e-03  0:00:07    4
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1509 cells
          17  2.0915e-02  5.9846e-04  5.3622e-04  6.2032e-04  3.8459e-08  4.1307e-03  0:00:05    3
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1515 cells
          18  1.6810e-02  5.7117e-04  5.1831e-04  5.9522e-04  3.2318e-08  3.9930e-03  0:00:04    2
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1520 cells
          19  1.3883e-02  5.5106e-04  5.0453e-04  5.7616e-04  2.8135e-08  3.8931e-03  0:00:02    1
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1523 cells
          20  1.1798e-02  5.3722e-04  4.9389e-04  5.6120e-04  2.5620e-08  3.8229e-03  0:00:00    0
      Flow time = 0.0005s, time step = 1
      3999 more time steps
       done.
          20  1.1798e-02  5.3722e-04  4.9389e-04  5.6120e-04  2.5620e-08  3.8229e-03  0:00:34   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1517 cells
          21  1.0246e-02  2.4675e-03  2.4064e-03  2.4517e-03  3.0641e-04  6.9201e-02  0:00:33   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1476 cells
          22  1.1668e-02  8.5329e-04  8.0786e-04  8.6931e-04  7.3897e-05  1.7517e-02  0:00:32   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1452 cells
          23  1.1647e-02  4.4248e-04  4.0350e-04  4.6468e-04  1.7656e-05  7.2321e-03  0:00:28   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1432 cells
          24  1.1356e-02  3.3545e-04  3.0039e-04  3.4723e-04  4.5229e-06  4.3549e-03  0:00:27   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1419 cells
          25  1.1001e-02  2.7400e-04  2.4682e-04  2.7919e-04  1.3250e-06  3.3592e-03  0:00:26   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1411 cells
          26  1.0697e-02  2.2959e-04  2.0822e-04  2.3409e-04  4.7826e-07  2.9453e-03  0:00:25   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1402 cells
          27  1.0391e-02  2.1136e-04  1.9168e-04  2.1748e-04  2.2364e-07  2.7383e-03  0:00:21   13
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1392 cells
          28  1.0115e-02  2.0443e-04  1.8578e-04  2.1282e-04  1.3213e-07  2.6105e-03  0:00:21   12
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1387 cells
          29  9.8508e-03  2.0877e-04  1.9008e-04  2.1775e-04  9.2324e-08  2.5253e-03  0:00:20   11
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1386 cells
          30  9.5898e-03  2.1921e-04  1.9963e-04  2.2893e-04  7.1814e-08  2.4652e-03  0:00:18   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1384 cells
          31  9.3302e-03  2.3261e-04  2.1214e-04  2.4278e-04  6.0077e-08  2.4185e-03  0:00:15    9
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1382 cells
          32  9.0723e-03  2.4728e-04  2.2536e-04  2.5800e-04  5.1961e-08  2.3790e-03  0:00:14    8
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1383 cells
          33  8.8183e-03  2.6178e-04  2.3788e-04  2.7286e-04  4.5732e-08  2.3462e-03  0:00:12    7
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1381 cells
          34  8.5698e-03  2.7559e-04  2.4970e-04  2.8671e-04  4.1418e-08  2.3193e-03  0:00:11    6
          35  8.3286e-03  2.8757e-04  2.5926e-04  2.9891e-04  3.7488e-08  2.2965e-03  0:00:08    5
          36  8.0953e-03  2.9772e-04  2.6721e-04  3.0956e-04  3.4309e-08  2.2774e-03  0:00:07    4
          37  7.8704e-03  3.0676e-04  2.7421e-04  3.1908e-04  3.1862e-08  2.2610e-03  0:00:05    3
          38  7.6542e-03  3.1458e-04  2.8018e-04  3.2695e-04  3.0002e-08  2.2464e-03  0:00:04    2
          39  7.4470e-03  3.2013e-04  2.8464e-04  3.3248e-04  2.7920e-08  2.2323e-03  0:00:02    1
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1380 cells
          40  7.2483e-03  3.2435e-04  2.8820e-04  3.3670e-04  2.6104e-08  2.2210e-03  0:00:00    0
      Flow time = 0.001s, time step = 2
      3998 more time steps
       done.
          40  7.2483e-03  3.2435e-04  2.8820e-04  3.3670e-04  2.6104e-08  2.2210e-03  0:00:35   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1314 cells
          41  7.1056e-03  1.9999e-03  1.9471e-03  4.8915e-03  3.9244e-04  5.6901e-02  0:00:34   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1271 cells
          42  8.1135e-03  7.9265e-04  7.4149e-04  1.5379e-03  8.7552e-05  1.4163e-02  0:00:29   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1242 cells
          43  8.1759e-03  4.8964e-04  4.3840e-04  6.9272e-04  1.9591e-05  4.6063e-03  0:00:29   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1220 cells
          44  8.0154e-03  4.7084e-04  4.1917e-04  5.2960e-04  4.5858e-06  2.2498e-03  0:00:28   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1207 cells
          45  7.7958e-03  4.4177e-04  3.9691e-04  4.6690e-04  1.1824e-06  1.5362e-03  0:00:27   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1202 cells
          46  7.5872e-03  4.1486e-04  3.7717e-04  4.3392e-04  3.6599e-07  1.2662e-03  0:00:26   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1193 cells
          47  7.3960e-03  3.9025e-04  3.5729e-04  4.0777e-04  1.5075e-07  1.1358e-03  0:00:24   13
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1185 cells
          48  7.2183e-03  3.6726e-04  3.3723e-04  3.8361e-04  8.5942e-08  1.0539e-03  0:00:20   12
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1183 cells
          49  7.0504e-03  3.4644e-04  3.1887e-04  3.6197e-04  5.9994e-08  9.9476e-04  0:00:19   11
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1181 cells
          50  6.8946e-03  3.1343e-04  2.8906e-04  3.2724e-04  4.6995e-08  9.5108e-04  0:00:18   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1178 cells
          51  6.7403e-03  3.1088e-04  2.8596e-04  3.2509e-04  4.0209e-08  9.1339e-04  0:00:17    9
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1177 cells
          52  6.5901e-03  2.9671e-04  2.7265e-04  3.0999e-04  3.4978e-08  8.8165e-04  0:00:13    8
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1176 cells
          53  6.4501e-03  2.7314e-04  2.5078e-04  2.8469e-04  3.0639e-08  8.5694e-04  0:00:12    7
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1171 cells
          54  6.3073e-03  2.7338e-04  2.5030e-04  2.8491e-04  2.8316e-08  8.3346e-04  0:00:11    6
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1170 cells
          55  6.1690e-03  2.6352e-04  2.4138e-04  2.7463e-04  2.5861e-08  8.1280e-04  0:00:09    5
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1168 cells
          56  6.0404e-03  2.4421e-04  2.2441e-04  2.5439e-04  2.3476e-08  7.9696e-04  0:00:07    4
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1166 cells
          57  5.9080e-03  2.4547e-04  2.2553e-04  2.5602e-04  2.2377e-08  7.8011e-04  0:00:05    3
          58  5.7859e-03  2.2803e-04  2.0995e-04  2.3777e-04  2.0681e-08  7.6527e-04  0:00:04    2
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1165 cells
          59  5.6598e-03  2.3031e-04  2.1150e-04  2.4062e-04  1.8796e-08  7.5352e-04  0:00:02    1
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1164 cells
          60  5.5439e-03  2.1449e-04  1.9745e-04  2.2385e-04  1.8305e-08  7.4134e-04  0:00:00    0
      Flow time = 0.0015s, time step = 3
      3997 more time steps
       done.
          60  5.5439e-03  2.1449e-04  1.9745e-04  2.2385e-04  1.8305e-08  7.4134e-04  0:00:34   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1048 cells
          61  5.3752e-03  2.6850e-03  2.6305e-03  7.1013e-03  3.9329e-04  4.8751e-02  0:00:37   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 990 cells
          62  5.2691e-03  1.1215e-03  1.0628e-03  2.3898e-03  8.6664e-05  1.2259e-02  0:00:32   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 952 cells
          63  5.1838e-03  6.5477e-04  5.9652e-04  1.0076e-03  1.9279e-05  3.8895e-03  0:00:31   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 929 cells
          64  4.9987e-03  5.9478e-04  5.3289e-04  6.8030e-04  4.5056e-06  1.8012e-03  0:00:30   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 915 cells
          65  4.8348e-03  4.8170e-04  4.3435e-04  5.0686e-04  1.1664e-06  1.1912e-03  0:00:25   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 903 cells
          66  4.7104e-03  4.2486e-04  3.8509e-04  4.4133e-04  3.6648e-07  9.6514e-04  0:00:24   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 896 cells
          67  4.6054e-03  3.7560e-04  3.4219e-04  3.8937e-04  1.5558e-07  8.5631e-04  0:00:23   13
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 894 cells
          68  4.5111e-03  3.3428e-04  3.0535e-04  3.4565e-04  9.0563e-08  7.9059e-04  0:00:20   12
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 893 cells
          69  4.4237e-03  2.9901e-04  2.7422e-04  3.0898e-04  6.4076e-08  7.4370e-04  0:00:19   11
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 890 cells
          70  4.3415e-03  2.6954e-04  2.4812e-04  2.7860e-04  5.1021e-08  7.0748e-04  0:00:18   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 888 cells
          71  4.2635e-03  2.4530e-04  2.2641e-04  2.5385e-04  4.3171e-08  6.7753e-04  0:00:15    9
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 887 cells
          72  4.1889e-03  2.2505e-04  2.0820e-04  2.3299e-04  3.7915e-08  6.5230e-04  0:00:14    8
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 886 cells
          73  4.1170e-03  2.0795e-04  1.9288e-04  2.1530e-04  3.4011e-08  6.2995e-04  0:00:11    7
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 884 cells
          74  4.0476e-03  1.9346e-04  1.7992e-04  2.0031e-04  3.1021e-08  6.1020e-04  0:00:10    6
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 883 cells
          75  3.9805e-03  1.8106e-04  1.6889e-04  1.8746e-04  2.8522e-08  5.9197e-04  0:00:09    5
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 882 cells
          76  3.9154e-03  1.7033e-04  1.5934e-04  1.7631e-04  2.6454e-08  5.7550e-04  0:00:06    4
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 881 cells
          77  3.8523e-03  1.6106e-04  1.5113e-04  1.6676e-04  2.4534e-08  5.6004e-04  0:00:05    3
          78  3.7910e-03  1.5291e-04  1.4388e-04  1.5840e-04  2.2858e-08  5.4604e-04  0:00:03    2
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 877 cells
          79  3.7315e-03  1.4575e-04  1.3744e-04  1.5106e-04  2.1315e-08  5.3288e-04  0:00:02    1
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 875 cells
          80  3.6737e-03  1.3944e-04  1.3173e-04  1.4470e-04  2.0073e-08  5.2098e-04  0:00:00    0
      Flow time = 0.002s, time step = 4
      3996 more time steps
       done.
          80  3.6737e-03  1.3944e-04  1.3173e-04  1.4470e-04  2.0073e-08  5.2098e-04  0:00:33   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 722 cells
          81  3.6275e-03  5.7943e-03  5.6961e-03  1.1552e-02  3.9396e-04  4.3967e-02  0:00:37   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 667 cells
          82  4.8618e-03  1.9111e-03  1.8540e-03  3.5771e-03  8.6265e-05  1.0898e-02  0:00:31   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 636 cells
          83  5.0737e-03  7.1437e-04  6.7904e-04  1.1600e-03  1.9163e-05  3.3124e-03  0:00:31   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 618 cells
          84  5.0193e-03  4.0882e-04  3.8655e-04  5.2193e-04  4.4898e-06  1.4422e-03  0:00:29   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 605 cells
          85  4.9089e-03  3.2853e-04  3.1279e-04  3.5961e-04  1.1707e-06  9.2359e-04  0:00:25   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 600 cells
          86  4.7969e-03  2.8829e-04  2.7639e-04  3.0523e-04  3.7136e-07  7.4937e-04  0:00:24   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 599 cells
          87  4.6927e-03  2.5863e-04  2.4902e-04  2.7242e-04  1.5992e-07  6.7264e-04  0:00:21   13
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 596 cells
          88  4.5946e-03  2.3558e-04  2.2721e-04  2.4723e-04  9.3063e-08  6.2789e-04  0:00:20   12
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 593 cells
          89  4.5009e-03  2.1781e-04  2.1010e-04  2.2784e-04  6.4740e-08  5.9751e-04  0:00:19   11
          90  4.4108e-03  2.0402e-04  1.9674e-04  2.1278e-04  5.1780e-08  5.7294e-04  0:00:16   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 592 cells
          91  4.3233e-03  1.9311e-04  1.8631e-04  2.0068e-04  4.3334e-08  5.5184e-04  0:00:15    9
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 590 cells
          92  4.2383e-03  1.8436e-04  1.7811e-04  1.9115e-04  3.6963e-08  5.3438e-04  0:00:14    8
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 589 cells
          93  4.1553e-03  1.7705e-04  1.7141e-04  1.8336e-04  3.3679e-08  5.1771e-04  0:00:11    7
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 586 cells
          94  4.0744e-03  1.7081e-04  1.6582e-04  1.7676e-04  3.0291e-08  5.0179e-04  0:00:10    6
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 584 cells
          95  3.9954e-03  1.6530e-04  1.6089e-04  1.7092e-04  2.6908e-08  4.8792e-04  0:00:09    5
          96  3.9182e-03  1.6028e-04  1.5639e-04  1.6569e-04  2.5554e-08  4.7403e-04  0:00:06    4
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 583 cells
          97  3.8430e-03  1.5574e-04  1.5225e-04  1.6108e-04  2.3622e-08  4.6050e-04  0:00:05    3
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 582 cells
          98  3.7695e-03  1.5158e-04  1.4836e-04  1.5696e-04  2.1460e-08  4.4879e-04  0:00:03    2
          99  3.6979e-03  1.4766e-04  1.4464e-04  1.5314e-04  2.1113e-08  4.3679e-04  0:00:02    1
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 581 cells
         100  3.6282e-03  1.4398e-04  1.4113e-04  1.4950e-04  1.9804e-08  4.2478e-04  0:00:00    0
      Flow time = 0.0025s, time step = 5
      3995 more time steps
       done.
      >> Dividing domain into 5 partitions using Metis.
         Time = 0.222 seconds.
         Done.
      >> 5 Stored Partitions:
         Collective Partition Statistics:        Minimum   Maximum   Total
         Cell count                              70854     70876     354309
         Mean cell count deviation               -0.0%     0.0%
         Partition boundary cell count           1832      3024      11541
         Partition boundary cell count ratio     2.6%      4.3%      3.3%
         Face count                              146129    147869    727836
         Mean face count deviation               -0.5%     0.7%
         Partition boundary face count           2063      3373      6404
         Partition boundary face count ratio     1.4%      2.3%      0.9%
         Cell weights                            7e+05     7e+05     4e+06
         Mean cell weight deviation              -0.0%     0.0%
         Partition neighbor count                4         4
         Partition Method                        Metis
         Stored Partition Count                  5
      Done.
         Smoothing partition boundaries...
      done.
         100  3.6282e-03  1.4398e-04  1.4113e-04  1.4950e-04  1.9804e-08  4.2478e-04  0:00:34   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 488 cells
         101  3.7213e-03  4.0668e-03  3.9201e-03  1.5643e-02  3.9482e-04  4.0493e-02  0:00:34   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 448 cells
         102  4.6129e-03  1.1915e-03  1.1387e-03  4.2909e-03  8.6139e-05  9.8682e-03  0:00:29   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 429 cells
         103  4.7651e-03  4.2016e-04  3.9924e-04  1.2124e-03  1.9142e-05  2.8904e-03  0:00:25   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 420 cells
         104  4.7117e-03  2.5111e-04  2.4164e-04  4.2246e-04  4.4946e-06  1.1928e-03  0:00:22   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 415 cells
         105  4.6099e-03  2.1867e-04  2.1318e-04  2.5149e-04  1.1757e-06  7.3644e-04  0:00:20   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 414 cells
         106  4.5041e-03  2.0398e-04  2.0024e-04  2.1741e-04  3.7488e-07  5.8916e-04  0:00:20   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 413 cells
         107  4.4016e-03  1.9326e-04  1.9028e-04  2.0385e-04  1.6088e-07  5.2623e-04  0:00:18   13
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 412 cells
         108  4.3032e-03  1.8497e-04  1.8246e-04  1.9440e-04  9.3839e-08  4.8943e-04  0:00:15   12
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 411 cells
         109  4.2086e-03  1.7832e-04  1.7607e-04  1.8706e-04  6.6219e-08  4.6229e-04  0:00:14   11
         110  4.1175e-03  1.7262e-04  1.7067e-04  1.8082e-04  5.2050e-08  4.3957e-04  0:00:12   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 409 cells
         111  4.0296e-03  1.6746e-04  1.6577e-04  1.7534e-04  4.3367e-08  4.1950e-04  0:00:10    9
         112  3.9447e-03  1.6278e-04  1.6127e-04  1.7027e-04  3.7555e-08  4.0152e-04  0:00:11    8
         113  3.8626e-03  1.5839e-04  1.5707e-04  1.6564e-04  3.3250e-08  3.8520e-04  0:00:09    7
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 408 cells
         114  3.7831e-03  1.5432e-04  1.5297e-04  1.6123e-04  2.9670e-08  3.6994e-04  0:00:07    6
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 407 cells
         115  3.7061e-03  1.5046e-04  1.4902e-04  1.5705e-04  2.6838e-08  3.5618e-04  0:00:06    5
         116  3.6315e-03  1.4681e-04  1.4526e-04  1.5308e-04  2.4437e-08  3.4360e-04  0:00:05    4
         117  3.5594e-03  1.4330e-04  1.4166e-04  1.4936e-04  2.2244e-08  3.3202e-04  0:00:04    3
         118  3.4896e-03  1.3987e-04  1.3820e-04  1.4575e-04  2.0505e-08  3.2145e-04  0:00:02    2
         119  3.4222e-03  1.3657e-04  1.3485e-04  1.4220e-04  1.8881e-08  3.1164e-04  0:00:01    1
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 406 cells
         120  3.3570e-03  1.3339e-04  1.3163e-04  1.3884e-04  1.7429e-08  3.0257e-04  0:00:00    0
      Flow time = 0.003s, time step = 6
      3994 more time steps
       done.
         120  3.3570e-03  1.3339e-04  1.3163e-04  1.3884e-04  1.7429e-08  3.0257e-04  0:00:23   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 332 cells
         121  3.5092e-03  2.4134e-03  2.3255e-03  1.5813e-02  3.9580e-04  3.7707e-02  0:00:21   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 309 cells
         122  3.4129e-03  7.2594e-04  6.9376e-04  4.2005e-03  8.6152e-05  9.0503e-03  0:00:23   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 288 cells
         123  3.4016e-03  3.0547e-04  2.9077e-04  1.1733e-03  1.9167e-05  2.5428e-03  0:00:21   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 274 cells
         124  3.3612e-03  2.1577e-04  2.0855e-04  3.9850e-04  4.5146e-06  9.6780e-04  0:00:19   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 270 cells
         125  3.3007e-03  1.8711e-04  1.8265e-04  2.2440e-04  1.1883e-06  5.5129e-04  0:00:17   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 268 cells
         126  3.2396e-03  1.6960e-04  1.6655e-04  1.8799e-04  3.8226e-07  4.2355e-04  0:00:16   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 266 cells
         127  3.1825e-03  1.5711e-04  1.5460e-04  1.7203e-04  1.6460e-07  3.7276e-04  0:00:14   13
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 264 cells
         128  3.1288e-03  1.4776e-04  1.4547e-04  1.6034e-04  9.5216e-08  3.4674e-04  0:00:15   12
         129  3.0777e-03  1.4044e-04  1.3825e-04  1.5099e-04  6.6250e-08  3.2882e-04  0:00:13   11
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 263 cells
         130  3.0286e-03  1.3455e-04  1.3235e-04  1.4343e-04  5.1632e-08  3.1569e-04  0:00:12   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 262 cells
         131  2.9813e-03  1.2963e-04  1.2741e-04  1.3725e-04  4.2878e-08  3.0387e-04  0:00:10    9
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 261 cells
         132  2.9357e-03  1.2537e-04  1.2321e-04  1.3210e-04  3.6798e-08  2.9422e-04  0:00:09    8
         133  2.8916e-03  1.2163e-04  1.1956e-04  1.2770e-04  3.2375e-08  2.8469e-04  0:00:08    7
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 260 cells
         134  2.8491e-03  1.1829e-04  1.1633e-04  1.2386e-04  2.9053e-08  2.7680e-04  0:00:06    6
         135  2.8081e-03  1.1528e-04  1.1346e-04  1.2048e-04  2.6312e-08  2.6864e-04  0:00:06    5
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 258 cells
         136  2.7686e-03  1.1252e-04  1.1083e-04  1.1746e-04  2.4059e-08  2.6166e-04  0:00:05    4
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 257 cells
         137  2.7306e-03  1.0998e-04  1.0842e-04  1.1472e-04  2.2447e-08  2.5419e-04  0:00:03    3
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 256 cells
         138  2.6940e-03  1.0763e-04  1.0618e-04  1.1220e-04  2.0705e-08  2.4780e-04  0:00:02    2
         139  2.6589e-03  1.0544e-04  1.0409e-04  1.0987e-04  1.8953e-08  2.4066e-04  0:00:01    1
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 255 cells
         140  2.6252e-03  1.0344e-04  1.0217e-04  1.0775e-04  1.7633e-08  2.3476e-04  0:00:00    0
      Flow time = 0.0035s, time step = 7
      3993 more time steps
       done.
         140  2.6252e-03  1.0344e-04  1.0217e-04  1.0775e-04  1.7633e-08  2.3476e-04  0:00:26   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 214 cells
         141  2.8288e-03  3.6231e-03  3.5021e-03  1.3539e-02  3.9671e-04  3.5334e-02  0:00:27   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 197 cells
         142  3.2665e-03  1.0481e-03  1.0088e-03  3.6279e-03  8.6240e-05  8.3602e-03  0:00:24   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 190 cells
         143  3.3481e-03  3.8470e-04  3.7127e-04  1.0327e-03  1.9212e-05  2.2641e-03  0:00:22   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 180 cells
         144  3.3247e-03  2.3545e-04  2.3025e-04  3.7262e-04  4.5354e-06  8.0654e-04  0:00:23   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 178 cells
         145  3.2603e-03  2.0118e-04  1.9778e-04  2.2996e-04  1.1963e-06  4.3217e-04  0:00:20   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 176 cells
         146  3.1890e-03  1.8537e-04  1.8230e-04  2.0112e-04  3.8450e-07  3.2299e-04  0:00:18   14
         147  3.1228e-03  1.7449e-04  1.7163e-04  1.8711e-04  1.6480e-07  2.8330e-04  0:00:16   13
         148  3.0616e-03  1.6656e-04  1.6385e-04  1.7712e-04  9.4744e-08  2.6398e-04  0:00:14   12
         149  3.0040e-03  1.6057e-04  1.5809e-04  1.6969e-04  6.5509e-08  2.5164e-04  0:00:13   11
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 175 cells
         150  2.9491e-03  1.5585e-04  1.5358e-04  1.6402e-04  5.1111e-08  2.4229e-04  0:00:13   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 174 cells
         151  2.8966e-03  1.5196e-04  1.4987e-04  1.5953e-04  4.2378e-08  2.3439e-04  0:00:11    9
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 173 cells
         152  2.8464e-03  1.4859e-04  1.4664e-04  1.5579e-04  3.6197e-08  2.2733e-04  0:00:10    8
         153  2.7982e-03  1.4558e-04  1.4373e-04  1.5250e-04  3.1557e-08  2.2086e-04  0:00:08    7
         154  2.7520e-03  1.4278e-04  1.4107e-04  1.4951e-04  2.7734e-08  2.1476e-04  0:00:07    6
         155  2.7078e-03  1.4016e-04  1.3861e-04  1.4675e-04  2.4601e-08  2.0897e-04  0:00:06    5
         156  2.6653e-03  1.3771e-04  1.3630e-04  1.4419e-04  2.2084e-08  2.0347e-04  0:00:05    4
         157  2.6244e-03  1.3535e-04  1.3408e-04  1.4173e-04  2.0006e-08  1.9821e-04  0:00:04    3
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 171 cells
         158  2.5849e-03  1.3305e-04  1.3193e-04  1.3934e-04  1.8256e-08  1.9315e-04  0:00:02    2
         159  2.5468e-03  1.3079e-04  1.2981e-04  1.3700e-04  1.6794e-08  1.8827e-04  0:00:01    1
         160  2.5099e-03  1.2863e-04  1.2776e-04  1.3471e-04  1.5647e-08  1.8357e-04  0:00:00    0
      Flow time = 0.004s, time step = 8
      3992 more time steps
       done.
         160  2.5099e-03  1.2863e-04  1.2776e-04  1.3471e-04  1.5647e-08  1.8357e-04  0:00:22   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 144 cells
         161  2.7172e-03  1.9624e-03  1.8703e-03  1.0534e-02  3.9750e-04  3.3264e-02  0:00:25   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 128 cells
         162  2.7223e-03  6.8900e-04  6.5493e-04  3.1201e-03  8.6338e-05  7.7949e-03  0:00:22   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 123 cells
         163  2.6524e-03  3.3268e-04  3.2048e-04  9.5569e-04  1.9257e-05  2.0588e-03  0:00:20   17
         164  2.5857e-03  2.5865e-04  2.5322e-04  3.9443e-04  4.5562e-06  6.9849e-04  0:00:18   16
         165  2.5093e-03  2.3498e-04  2.3111e-04  2.6619e-04  1.2039e-06  3.5383e-04  0:00:17   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 121 cells
         166  2.4347e-03  2.1972e-04  2.1640e-04  2.3517e-04  3.8688e-07  2.5556e-04  0:00:18   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 120 cells
         167  2.3689e-03  2.0781e-04  2.0488e-04  2.1991e-04  1.6543e-07  2.2074e-04  0:00:16   13
         168  2.3100e-03  1.9814e-04  1.9559e-04  2.0851e-04  9.4814e-08  2.0387e-04  0:00:14   12
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 118 cells
         169  2.2559e-03  1.9008e-04  1.8789e-04  1.9931e-04  6.5253e-08  1.9299e-04  0:00:13   11
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 117 cells
         170  2.2053e-03  1.8315e-04  1.8128e-04  1.9165e-04  5.0410e-08  1.8462e-04  0:00:11   10
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
         171  2.1576e-03  1.7705e-04  1.7544e-04  1.8502e-04  4.1619e-08  1.7759e-04  0:00:12    9
         172  2.1127e-03  1.7158e-04  1.7015e-04  1.7912e-04  3.5571e-08  1.7142e-04  0:00:10    8
         173  2.0703e-03  1.6660e-04  1.6529e-04  1.7381e-04  3.0946e-08  1.6582e-04  0:00:08    7
         174  2.0304e-03  1.6200e-04  1.6081e-04  1.6894e-04  2.7002e-08  1.6067e-04  0:00:07    6
         175  1.9927e-03  1.5770e-04  1.5662e-04  1.6442e-04  2.3805e-08  1.5596e-04  0:00:06    5
         176  1.9572e-03  1.5361e-04  1.5266e-04  1.6019e-04  2.1217e-08  1.5170e-04  0:00:05    4
         177  1.9237e-03  1.4970e-04  1.4885e-04  1.5620e-04  1.9113e-08  1.4777e-04  0:00:04    3
         178  1.8922e-03  1.4597e-04  1.4522e-04  1.5240e-04  1.7402e-08  1.4410e-04  0:00:02    2
         179  1.8626e-03  1.4241e-04  1.4177e-04  1.4876e-04  1.5868e-08  1.4059e-04  0:00:01    1
         180  1.8350e-03  1.3901e-04  1.3846e-04  1.4528e-04  1.4500e-08  1.3720e-04  0:00:00    0
      Flow time = 0.004500000000000001s, time step = 9
      3991 more time steps
       done.
         180  1.8350e-03  1.3901e-04  1.3846e-04  1.4528e-04  1.4500e-08  1.3720e-04  0:00:26   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 100 cells
         181  2.0639e-03  3.9635e-03  3.8713e-03  1.7879e-02  3.9812e-04  3.1447e-02  0:00:23   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 91 cells
         182  1.7726e-03  1.4607e-03  1.4222e-03  5.9272e-03  8.6438e-05  7.3387e-03  0:00:21   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 88 cells
         183  1.6077e-03  6.0706e-04  5.8977e-04  1.8074e-03  1.9304e-05  1.8962e-03  0:00:23   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 86 cells
         184  1.5348e-03  3.9228e-04  3.8274e-04  6.6840e-04  4.5756e-06  6.1150e-04  0:00:20   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 83 cells
         185  1.4700e-03  3.2278e-04  3.1490e-04  3.8319e-04  1.2116e-06  2.8895e-04  0:00:18   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
         186  1.4139e-03  2.8194e-04  2.7514e-04  3.0713e-04  3.8992e-07  1.9929e-04  0:00:16   14
         187  1.3696e-03  2.5167e-04  2.4583e-04  2.7124e-04  1.6665e-07  1.6932e-04  0:00:15   13
         188  1.3335e-03  2.2833e-04  2.2314e-04  2.4549e-04  9.5284e-08  1.5613e-04  0:00:16   12
         189  1.3022e-03  2.0986e-04  2.0521e-04  2.2513e-04  6.5165e-08  1.4838e-04  0:00:14   11
         190  1.2741e-03  1.9495e-04  1.9077e-04  2.0858e-04  4.9998e-08  1.4276e-04  0:00:12   10
         191  1.2485e-03  1.8258e-04  1.7885e-04  1.9486e-04  4.0854e-08  1.3813e-04  0:00:12    9
         192  1.2249e-03  1.7206e-04  1.6874e-04  1.8329e-04  3.4370e-08  1.3402e-04  0:00:10    8
         193  1.2032e-03  1.6292e-04  1.5996e-04  1.7328e-04  2.9511e-08  1.3031e-04  0:00:09    7
         194  1.1831e-03  1.5484e-04  1.5223e-04  1.6452e-04  2.5732e-08  1.2694e-04  0:00:07    6
         195  1.1647e-03  1.4762e-04  1.4530e-04  1.5674e-04  2.2694e-08  1.2384e-04  0:00:06    5
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 78 cells
         196  1.1477e-03  1.4109e-04  1.3906e-04  1.4972e-04  2.0318e-08  1.2098e-04  0:00:05    4
         197  1.1322e-03  1.3518e-04  1.3338e-04  1.4338e-04  1.8524e-08  1.1831e-04  0:00:04    3
         198  1.1181e-03  1.2975e-04  1.2819e-04  1.3755e-04  1.6712e-08  1.1572e-04  0:00:02    2
         199  1.1052e-03  1.2477e-04  1.2340e-04  1.3217e-04  1.4930e-08  1.1331e-04  0:00:01    1
         200  1.0935e-03  1.2017e-04  1.1894e-04  1.2720e-04  1.3322e-08  1.1106e-04  0:00:00    0
      Flow time = 0.005000000000000001s, time step = 10
      3990 more time steps
       done.
         200  1.0935e-03  1.2017e-04  1.1894e-04  1.2720e-04  1.3322e-08  1.1106e-04  0:00:23   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 71 cells
         201  1.4057e-03  6.9893e-03  6.7858e-03  3.4997e-02  3.9855e-04  2.9897e-02  0:00:21   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 67 cells
         202  1.2787e-03  2.6430e-03  2.5590e-03  1.2316e-02  8.6526e-05  7.0101e-03  0:00:23   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 64 cells
         203  1.1687e-03  9.6695e-04  9.3193e-04  3.5950e-03  1.9345e-05  1.7835e-03  0:00:21   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 63 cells
         204  1.1202e-03  5.3016e-04  5.1249e-04  1.1662e-03  4.5925e-06  5.5688e-04  0:00:19   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 61 cells
         205  1.0745e-03  4.0937e-04  3.9677e-04  5.4578e-04  1.2175e-06  2.5163e-04  0:00:17   15
         206  1.0353e-03  3.4655e-04  3.3647e-04  3.8376e-04  3.9179e-07  1.6818e-04  0:00:16   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 60 cells
         207  1.0057e-03  3.0133e-04  2.9323e-04  3.2293e-04  1.6687e-07  1.4101e-04  0:00:14   13
         208  9.8235e-04  2.6681e-04  2.6012e-04  2.8454e-04  9.4775e-08  1.2939e-04  0:00:13   12
      !  208 solution is converged
      Flow time = 0.005500000000000001s, time step = 11
      3989 more time steps
       done.
         208  9.8235e-04  2.6681e-04  2.6012e-04  2.8454e-04  9.4775e-08  1.2939e-04  0:00:21   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 58 cells
         209  1.3222e-03  9.0554e-03  8.7845e-03  5.6668e-02  3.9873e-04  2.8606e-02  0:00:24   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 55 cells
         210  1.7842e-03  2.4817e-03  2.3979e-03  1.4378e-02  8.6566e-05  6.8500e-03  0:00:22   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 54 cells
         211  1.8239e-03  8.0370e-04  7.7499e-04  3.5616e-03  1.9365e-05  1.7275e-03  0:00:20   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 53 cells
         212  1.8046e-03  4.6579e-04  4.5297e-04  1.0819e-03  4.5971e-06  5.3247e-04  0:00:18   16
         213  1.7591e-03  3.8429e-04  3.7582e-04  4.9827e-04  1.2153e-06  2.3609e-04  0:00:17   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
         214  1.7086e-03  3.4224e-04  3.3578e-04  3.7470e-04  3.8765e-07  1.5561e-04  0:00:15   14
         215  1.6631e-03  3.1210e-04  3.0685e-04  3.3596e-04  1.6273e-07  1.2956e-04  0:00:16   13
         216  1.6224e-03  2.8936e-04  2.8508e-04  3.0980e-04  9.1164e-08  1.1830e-04  0:00:15   12
         217  1.5848e-03  2.7230e-04  2.6860e-04  2.8961e-04  6.1180e-08  1.1163e-04  0:00:13   11
         218  1.5495e-03  2.5906e-04  2.5579e-04  2.7376e-04  4.6129e-08  1.0674e-04  0:00:11   10
         219  1.5158e-03  2.4852e-04  2.4572e-04  2.6115e-04  3.7037e-08  1.0275e-04  0:00:10    9
         220  1.4834e-03  2.3998e-04  2.3752e-04  2.5088e-04  3.0834e-08  9.9322e-05  0:00:09    8
         221  1.4522e-03  2.3282e-04  2.3060e-04  2.4241e-04  2.6172e-08  9.6275e-05  0:00:07    7
         222  1.4219e-03  2.2672e-04  2.2473e-04  2.3529e-04  2.2498e-08  9.3433e-05  0:00:08    6
         223  1.3925e-03  2.2133e-04  2.1954e-04  2.2920e-04  1.9549e-08  9.0727e-05  0:00:06    5
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 51 cells
         224  1.3639e-03  2.1654e-04  2.1494e-04  2.2391e-04  1.7130e-08  8.8132e-05  0:00:05    4
         225  1.3361e-03  2.1208e-04  2.1075e-04  2.1915e-04  1.5116e-08  8.5648e-05  0:00:03    3
         226  1.3090e-03  2.0794e-04  2.0683e-04  2.1485e-04  1.3463e-08  8.3273e-05  0:00:03    2
         227  1.2826e-03  2.0407e-04  2.0318e-04  2.1088e-04  1.2025e-08  8.1010e-05  0:00:01    1
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 50 cells
         228  1.2569e-03  2.0038e-04  1.9965e-04  2.0716e-04  1.0774e-08  7.8916e-05  0:00:00    0
      Flow time = 0.006000000000000002s, time step = 12
      3988 more time steps
       done.
         228  1.2569e-03  2.0038e-04  1.9965e-04  2.0716e-04  1.0774e-08  7.8916e-05  0:00:24   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 46 cells
         229  1.7753e-03  2.8031e-03  2.7581e-03  5.6505e-02  3.9884e-04  2.7692e-02  0:00:26   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 39 cells
         230  1.8083e-03  6.5105e-04  6.2867e-04  1.0524e-02  8.6635e-05  6.8444e-03  0:00:23   18
         231  1.6681e-03  2.9554e-04  2.8230e-04  2.5823e-03  1.9409e-05  1.7112e-03  0:00:21   17
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 37 cells
         232  1.5987e-03  2.2385e-04  2.1613e-04  7.2687e-04  4.6198e-06  5.0840e-04  0:00:19   16
         233  1.5408e-03  1.9982e-04  1.9464e-04  2.7945e-04  1.2268e-06  2.0733e-04  0:00:17   15
         234  1.4877e-03  1.8509e-04  1.8128e-04  2.0251e-04  3.9432e-07  1.2578e-04  0:00:18   14
         235  1.4448e-03  1.7427e-04  1.7130e-04  1.8592e-04  1.6706e-07  1.0012e-04  0:00:16   13
         236  1.4093e-03  1.6584e-04  1.6345e-04  1.7608e-04  9.4105e-08  8.9700e-05  0:00:14   12
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
         237  1.3781e-03  1.5903e-04  1.5710e-04  1.6825e-04  6.3366e-08  8.3950e-05  0:00:13   11
         238  1.3499e-03  1.5337e-04  1.5177e-04  1.6167e-04  4.8129e-08  7.9950e-05  0:00:11   10
         239  1.3237e-03  1.4851e-04  1.4712e-04  1.5607e-04  3.8696e-08  7.6773e-05  0:00:10    9
         240  1.2991e-03  1.4422e-04  1.4302e-04  1.5122e-04  3.1903e-08  7.4130e-05  0:00:09    8
         241  1.2757e-03  1.4035e-04  1.3928e-04  1.4689e-04  2.6856e-08  7.1959e-05  0:00:07    7
         242  1.2533e-03  1.3679e-04  1.3583e-04  1.4299e-04  2.2950e-08  7.0154e-05  0:00:08    6
         243  1.2317e-03  1.3347e-04  1.3264e-04  1.3941e-04  1.9838e-08  6.8626e-05  0:00:06    5
         244  1.2107e-03  1.3034e-04  1.2966e-04  1.3613e-04  1.7332e-08  6.7307e-05  0:00:05    4
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 35 cells
         245  1.1904e-03  1.2735e-04  1.2682e-04  1.3304e-04  1.5327e-08  6.6134e-05  0:00:03    3
         246  1.1707e-03  1.2448e-04  1.2407e-04  1.3009e-04  1.3538e-08  6.5040e-05  0:00:03    2
         247  1.1515e-03  1.2176e-04  1.2142e-04  1.2729e-04  1.1958e-08  6.4012e-05  0:00:01    1
         248  1.1329e-03  1.1919e-04  1.1889e-04  1.2459e-04  1.0646e-08  6.3115e-05  0:00:00    0
      Flow time = 0.006500000000000002s, time step = 13
      3987 more time steps
       done.
         248  1.1329e-03  1.1919e-04  1.1889e-04  1.2459e-04  1.0646e-08  6.3115e-05  0:00:24   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 31 cells
         249  1.9637e-03  2.8665e-03  2.7469e-03  3.3314e-02  3.9885e-04  2.7024e-02  0:00:26   19
         250  1.8630e-03  7.0427e-04  6.6858e-04  7.0074e-03  8.6701e-05  6.7245e-03  0:00:23   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 30 cells
         251  1.6891e-03  2.7951e-04  2.6321e-04  1.7901e-03  1.9446e-05  1.6899e-03  0:00:21   17
         252  1.6019e-03  1.8367e-04  1.7457e-04  5.2251e-04  4.6340e-06  4.9509e-04  0:00:19   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
         253  1.5360e-03  1.5306e-04  1.4695e-04  2.1538e-04  1.2315e-06  1.9321e-04  0:00:17   15
         254  1.4782e-03  1.3563e-04  1.3107e-04  1.5171e-04  3.9578e-07  1.1167e-04  0:00:16   14
         255  1.4373e-03  1.2315e-04  1.1950e-04  1.3356e-04  1.6746e-07  8.6694e-05  0:00:14   13
         256  1.4100e-03  1.1360e-04  1.1055e-04  1.2263e-04  9.4065e-08  7.7187e-05  0:00:13   12
         257  1.3902e-03  1.0607e-04  1.0347e-04  1.1416e-04  6.2979e-08  7.2345e-05  0:00:14   11
         258  1.3747e-03  9.9980e-05  9.7773e-05  1.0728e-04  4.7202e-08  6.9150e-05  0:00:12   10
         259  1.3624e-03  9.4921e-05  9.3039e-05  1.0159e-04  3.7568e-08  6.6677e-05  0:00:10    9
         260  1.3520e-03  9.0647e-05  8.9041e-05  9.6801e-05  3.0915e-08  6.4610e-05  0:00:09    8
         261  1.3431e-03  8.6988e-05  8.5619e-05  9.2731e-05  2.5966e-08  6.2816e-05  0:00:08    7
         262  1.3354e-03  8.3825e-05  8.2653e-05  8.9211e-05  2.2114e-08  6.1217e-05  0:00:07    6
         263  1.3285e-03  8.1054e-05  8.0032e-05  8.6148e-05  1.9027e-08  5.9757e-05  0:00:05    5
         264  1.3224e-03  7.8591e-05  7.7714e-05  8.3418e-05  1.6503e-08  5.8398e-05  0:00:04    4
         265  1.3168e-03  7.6404e-05  7.5657e-05  8.0995e-05  1.4408e-08  5.7108e-05  0:00:03    3
         266  1.3117e-03  7.4442e-05  7.3825e-05  7.8827e-05  1.2650e-08  5.5862e-05  0:00:02    2
         267  1.3070e-03  7.2657e-05  7.2184e-05  7.6872e-05  1.1160e-08  5.4635e-05  0:00:01    1
         268  1.3028e-03  7.1050e-05  7.0702e-05  7.5092e-05  9.8883e-09  5.3412e-05  0:00:00    0
      Flow time = 0.007000000000000003s, time step = 14
      3986 more time steps
       done.
         268  1.3028e-03  7.1050e-05  7.0702e-05  7.5092e-05  9.8883e-09  5.3412e-05  0:00:23   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 28 cells
         269  2.7003e-03  2.8761e-03  2.7503e-03  1.9882e-02  3.9876e-04  2.5929e-02  0:00:25   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 25 cells
         270  2.7855e-03  7.4603e-04  7.0752e-04  4.5470e-03  8.6752e-05  6.4361e-03  0:00:23   18
         271  2.5387e-03  2.7814e-04  2.6299e-04  1.2059e-03  1.9477e-05  1.6039e-03  0:00:20   17
         272  2.3783e-03  1.7108e-04  1.6424e-04  3.7950e-04  4.6476e-06  4.6239e-04  0:00:19   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
         273  2.2584e-03  1.4053e-04  1.3643e-04  1.7577e-04  1.2368e-06  1.7297e-04  0:00:17   15
         274  2.1569e-03  1.2413e-04  1.2118e-04  1.3421e-04  3.9821e-07  9.4667e-05  0:00:15   14
         275  2.0834e-03  1.1244e-04  1.1009e-04  1.2046e-04  1.6894e-07  6.9872e-05  0:00:14   13
         276  2.0324e-03  1.0348e-04  1.0156e-04  1.1057e-04  9.5092e-08  6.0745e-05  0:00:13   12
         277  1.9943e-03  9.6483e-05  9.4902e-05  1.0266e-04  6.3796e-08  5.5576e-05  0:00:12   11
         278  1.9646e-03  9.0899e-05  8.9547e-05  9.6278e-05  4.7831e-08  5.2906e-05  0:00:10   10
         279  1.9407e-03  8.6326e-05  8.5119e-05  9.1047e-05  3.8186e-08  5.0353e-05  0:00:09    9
         280  1.9208e-03  8.2525e-05  8.1408e-05  8.6691e-05  3.1553e-08  4.9015e-05  0:00:10    8
         281  1.9037e-03  7.9295e-05  7.8244e-05  8.3006e-05  2.6820e-08  4.7272e-05  0:00:08    7
         282  1.8886e-03  7.6514e-05  7.5523e-05  7.9840e-05  2.2822e-08  4.6450e-05  0:00:07    6
         283  1.8751e-03  7.4088e-05  7.3150e-05  7.7099e-05  1.9704e-08  4.5096e-05  0:00:06    5
         284  1.8629e-03  7.1932e-05  7.1059e-05  7.4685e-05  1.7126e-08  4.4630e-05  0:00:04    4
         285  1.8516e-03  6.9998e-05  6.9188e-05  7.2533e-05  1.5107e-08  4.3554e-05  0:00:03    3
         286  1.8410e-03  6.8253e-05  6.7508e-05  7.0614e-05  1.3349e-08  4.3277e-05  0:00:02    2
         287  1.8310e-03  6.6670e-05  6.5980e-05  6.8869e-05  1.1953e-08  4.2327e-05  0:00:01    1
         288  1.8216e-03  6.5232e-05  6.4580e-05  6.7275e-05  1.0687e-08  4.2130e-05  0:00:00    0
      Flow time = 0.007500000000000003s, time step = 15
      3985 more time steps
       done.
         288  1.8216e-03  6.5232e-05  6.4580e-05  6.7275e-05  1.0687e-08  4.2130e-05  0:00:21   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 20 cells
         289  3.4786e-03  2.1270e-03  2.0342e-03  1.1918e-02  3.9859e-04  2.4670e-02  0:00:23   19
         290  3.5243e-03  5.9757e-04  5.6515e-04  2.9055e-03  8.6796e-05  6.1017e-03  0:00:21   18
         291  3.1820e-03  2.3540e-04  2.2128e-04  8.0035e-04  1.9507e-05  1.5032e-03  0:00:20   17
         292  2.9613e-03  1.5062e-04  1.4350e-04  2.6647e-04  4.6566e-06  4.2561e-04  0:00:18   16
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 19 cells
         293  2.8031e-03  1.2541e-04  1.2051e-04  1.3924e-04  1.2378e-06  1.5504e-04  0:00:16   15
         294  2.6698e-03  1.1135e-04  1.0761e-04  1.1632e-04  3.9629e-07  8.2147e-05  0:00:15   14
         295  2.5688e-03  1.0118e-04  9.8087e-05  1.0557e-04  1.6617e-07  5.9901e-05  0:00:14   13
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
         296  2.4955e-03  9.3385e-05  9.0737e-05  9.7220e-05  9.2202e-08  5.1422e-05  0:00:13   12
         297  2.4384e-03  8.7299e-05  8.4985e-05  9.0551e-05  6.0878e-08  4.7057e-05  0:00:11   11
         298  2.3919e-03  8.2463e-05  8.0403e-05  8.5214e-05  4.5006e-08  4.4134e-05  0:00:10   10
         299  2.3531e-03  7.8525e-05  7.6658e-05  8.0867e-05  3.5343e-08  4.1840e-05  0:00:09    9
         300  2.3199e-03  7.5245e-05  7.3529e-05  7.7281e-05  2.8706e-08  3.9900e-05  0:00:08    8
         301  2.2911e-03  7.2449e-05  7.0875e-05  7.4270e-05  2.3806e-08  3.8201e-05  0:00:07    7
         302  2.2654e-03  7.0031e-05  6.8587e-05  7.1707e-05  2.0026e-08  3.6678e-05  0:00:07    6
         303  2.2421e-03  6.7908e-05  6.6589e-05  6.9476e-05  1.7025e-08  3.5299e-05  0:00:06    5
         304  2.2209e-03  6.6032e-05  6.4824e-05  6.7510e-05  1.4596e-08  3.4044e-05  0:00:05    4
         305  2.2014e-03  6.4363e-05  6.3250e-05  6.5758e-05  1.2598e-08  3.2901e-05  0:00:03    3
         306  2.1833e-03  6.2864e-05  6.1826e-05  6.4188e-05  1.0935e-08  3.1861e-05  0:00:02    2
         307  2.1663e-03  6.1503e-05  6.0536e-05  6.2764e-05  9.5362e-09  3.0918e-05  0:00:01    1
         308  2.1504e-03  6.0262e-05  5.9360e-05  6.1472e-05  8.3487e-09  3.0064e-05  0:00:00    0
      Flow time = 0.008000000000000004s, time step = 16
      3984 more time steps
       done.
         Time = 0.16 seconds.
         Done.
         Cell count                              70622     70654     353168
         Partition boundary cell count           1719      3014      11169
         Partition boundary cell count ratio     2.4%      4.3%      3.2%
         Face count                              145673    147164    725554
         Mean face count deviation               -0.5%     0.6%
         Partition boundary face count           1918      3335      6203
         Partition boundary face count ratio     1.3%      2.3%      0.9%
         Partition neighbor count                2         4
      Done.
      done.
         308  2.1504e-03  6.0262e-05  5.9360e-05  6.1472e-05  8.3487e-09  3.0064e-05  0:00:21   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 15 cells
         309  3.9188e-03  1.2064e-03  1.1553e-03  4.9341e-03  3.9836e-04  2.3664e-02  0:00:20   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 14 cells
         310  3.7433e-03  3.8076e-04  3.6001e-04  1.2981e-03  8.6831e-05  5.8699e-03  0:00:19   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 13 cells
         311  3.3402e-03  1.7298e-04  1.6278e-04  3.8589e-04  1.9537e-05  1.4339e-03  0:00:17   17
         312  3.0788e-03  1.2267e-04  1.1675e-04  1.5249e-04  4.6684e-06  3.9749e-04  0:00:20   16
         313  2.8967e-03  1.0652e-04  1.0239e-04  1.1014e-04  1.2414e-06  1.3746e-04  0:00:18   15
         314  2.7488e-03  9.7165e-05  9.3946e-05  9.9722e-05  3.9691e-07  6.7615e-05  0:00:16   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
         315  2.6368e-03  9.0245e-05  8.7578e-05  9.2786e-05  1.6574e-07  4.6431e-05  0:00:14   13
         316  2.5535e-03  8.4858e-05  8.2581e-05  8.7272e-05  9.1413e-08  3.8494e-05  0:00:13   12
         317  2.4882e-03  8.0593e-05  7.8591e-05  8.2856e-05  5.9938e-08  3.4560e-05  0:00:12   11
         318  2.4353e-03  7.7133e-05  7.5337e-05  7.9264e-05  4.3957e-08  3.2064e-05  0:00:11   10
         319  2.3912e-03  7.4265e-05  7.2630e-05  7.6283e-05  3.4246e-08  3.0209e-05  0:00:09    9
         320  2.3535e-03  7.1811e-05  7.0336e-05  7.3750e-05  2.7607e-08  2.8702e-05  0:00:08    8
         321  2.3207e-03  6.9671e-05  6.8342e-05  7.1546e-05  2.2734e-08  2.7410e-05  0:00:07    7
         322  2.2916e-03  6.7788e-05  6.6581e-05  6.9603e-05  1.8999e-08  2.6253e-05  0:00:06    6
         323  2.2656e-03  6.6118e-05  6.5009e-05  6.7871e-05  1.6052e-08  2.5193e-05  0:00:05    5
         324  2.2420e-03  6.4614e-05  6.3595e-05  6.6307e-05  1.3681e-08  2.4212e-05  0:00:04    4
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
         325  2.2204e-03  6.3247e-05  6.2307e-05  6.4881e-05  1.1743e-08  2.3291e-05  0:00:03    3
         326  2.2004e-03  6.2004e-05  6.1125e-05  6.3571e-05  1.0140e-08  2.2416e-05  0:00:02    2
         327  2.1816e-03  6.0862e-05  6.0041e-05  6.2366e-05  8.8025e-09  2.1577e-05  0:00:01    1
         328  2.1640e-03  5.9812e-05  5.9043e-05  6.1245e-05  7.6742e-09  2.0771e-05  0:00:00    0
      Flow time = 0.008500000000000004s, time step = 17
      3983 more time steps
       done.
         328  2.1640e-03  5.9812e-05  5.9043e-05  6.1245e-05  7.6742e-09  2.0771e-05  0:00:20   20
         329  4.0142e-03  4.5963e-04  4.3376e-04  3.5314e-03  3.9808e-04  2.2721e-02  0:00:19   19
         330  3.6138e-03  2.0205e-04  1.8807e-04  9.8809e-04  8.6863e-05  5.6961e-03  0:00:18   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 9 cells
         331  3.1078e-03  1.2767e-04  1.1874e-04  3.0414e-04  1.9565e-05  1.3775e-03  0:00:17   17
         332  2.8255e-03  1.0381e-04  9.8258e-05  1.3333e-04  4.6784e-06  3.7468e-04  0:00:19   16
         333  2.6363e-03  9.2653e-05  8.8743e-05  9.9107e-05  1.2439e-06  1.2291e-04  0:00:17   15
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
         334  2.4843e-03  8.5180e-05  8.2146e-05  8.8673e-05  3.9693e-07  5.5213e-05  0:00:16   14
         335  2.3695e-03  7.9451e-05  7.6947e-05  8.2298e-05  1.6522e-07  3.4707e-05  0:00:14   13
         336  2.2856e-03  7.4873e-05  7.2750e-05  7.7416e-05  9.0558e-08  2.7104e-05  0:00:13   12
         337  2.2210e-03  7.1146e-05  6.9306e-05  7.3460e-05  5.8877e-08  2.3416e-05  0:00:12   11
         338  2.1692e-03  6.8051e-05  6.6446e-05  7.0171e-05  4.2823e-08  2.1060e-05  0:00:11   10
         339  2.1268e-03  6.5437e-05  6.4029e-05  6.7387e-05  3.3090e-08  1.9493e-05  0:00:09    9
         340  2.0911e-03  6.3197e-05  6.1952e-05  6.4999e-05  2.6458e-08  1.8325e-05  0:00:08    8
         341  2.0606e-03  6.1248e-05  6.0144e-05  6.2924e-05  2.1611e-08  1.7413e-05  0:00:07    7
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
         342  2.0340e-03  5.9543e-05  5.8557e-05  6.1106e-05  1.7914e-08  1.6668e-05  0:00:06    6
         343  2.0105e-03  5.8036e-05  5.7155e-05  5.9497e-05  1.5018e-08  1.6038e-05  0:00:05    5
         344  1.9894e-03  5.6695e-05  5.5899e-05  5.8060e-05  1.2707e-08  1.5487e-05  0:00:04    4
         345  1.9702e-03  5.5493e-05  5.4771e-05  5.6773e-05  1.0829e-08  1.4981e-05  0:00:03    3
         346  1.9526e-03  5.4410e-05  5.3750e-05  5.5615e-05  9.2885e-09  1.4494e-05  0:00:02    2
         347  1.9362e-03  5.3426e-05  5.2817e-05  5.4564e-05  8.0125e-09  1.4010e-05  0:00:01    1
         348  1.9209e-03  5.2529e-05  5.1968e-05  5.3613e-05  6.9455e-09  1.3517e-05  0:00:00    0
      Flow time = 0.009000000000000005s, time step = 18
      3982 more time steps
      Updating solution at time levels N and N-1.
       done.
      Updating mesh at time level N... done.
         348  1.9209e-03  5.2529e-05  5.1968e-05  5.3613e-05  6.9455e-09  1.3517e-05  0:00:20   20
         349  3.8802e-03  7.7460e-04  7.1732e-04  9.6757e-03  3.9776e-04  2.1947e-02  0:00:23   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 6 cells
         350  3.2232e-03  2.7983e-04  2.5817e-04  2.7136e-03  8.6889e-05  5.5172e-03  0:00:21   18
         351  2.6493e-03  1.4009e-04  1.3024e-04  7.5676e-04  1.9593e-05  1.3313e-03  0:00:19   17
         352  2.3490e-03  1.0418e-04  9.8804e-05  2.3849e-04  4.6884e-06  3.5746e-04  0:00:18   16
         353  2.1576e-03  8.9523e-05  8.5856e-05  1.1368e-04  1.2457e-06  1.1288e-04  0:00:16   15
         354  2.0066e-03  8.0272e-05  7.7362e-05  8.7926e-05  3.9616e-07  4.7284e-05  0:00:15   14
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
         355  1.8954e-03  7.3574e-05  7.1107e-05  7.8419e-05  1.6358e-07  2.7586e-05  0:00:14   13
         356  1.8150e-03  6.8484e-05  6.6343e-05  7.2296e-05  8.9022e-08  2.0395e-05  0:00:13   12
      (cx-use-window-id 5)
         357  1.7530e-03  6.4510e-05  6.2644e-05  6.7680e-05  5.7484e-08  1.6984e-05  0:00:11   11
         358  1.7033e-03  6.1331e-05  5.9705e-05  6.4055e-05  4.1536e-08  1.4931e-05  0:00:10   10
         359  1.6627e-03  5.8722e-05  5.7295e-05  6.1097e-05  3.1901e-08  1.3494e-05  0:00:09    9
         360  1.6288e-03  5.6547e-05  5.5276e-05  5.8630e-05  2.5363e-08  1.2399e-05  0:00:08    8
         361  1.5998e-03  5.4698e-05  5.3562e-05  5.6538e-05  2.0605e-08  1.1520e-05  0:00:07    7
         362  1.5746e-03  5.3100e-05  5.2091e-05  5.4740e-05  1.6992e-08  1.0788e-05  0:00:06    6
         363  1.5525e-03  5.1705e-05  5.0807e-05  5.3181e-05  1.4169e-08  1.0155e-05  0:00:05    5
         364  1.5327e-03  5.0472e-05  4.9671e-05  5.1819e-05  1.1919e-08  9.5979e-06  0:00:04    4
         365  1.5149e-03  4.9373e-05  4.8661e-05  5.0619e-05  1.0097e-08  9.1055e-06  0:00:03    3
         366  1.4988e-03  4.8382e-05  4.7757e-05  4.9548e-05  8.6030e-09  8.6724e-06  0:00:02    2
         367  1.4840e-03  4.7489e-05  4.6943e-05  4.8586e-05  7.3653e-09  8.2990e-06  0:00:01    1
         368  1.4704e-03  4.6680e-05  4.6204e-05  4.7720e-05  6.3313e-09  7.9789e-06  0:00:00    0
      Flow time = 0.009500000000000005s, time step = 19
      3981 more time steps
       done.
         368  1.4704e-03  4.6680e-05  4.6204e-05  4.7720e-05  6.3313e-09  7.9789e-06  0:00:20   20
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 4 cells
         369  3.5042e-03  1.2158e-03  1.1499e-03  1.6520e-02  3.9742e-04  2.1042e-02  0:00:23   19
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
         370  2.7519e-03  4.1969e-04  3.9359e-04  4.8362e-03  8.6908e-05  5.3015e-03  0:00:21   18
         371  2.1320e-03  1.8118e-04  1.6932e-04  1.3371e-03  1.9617e-05  1.2689e-03  0:00:19   17
         372  1.8174e-03  1.2163e-04  1.1535e-04  3.9680e-04  4.6969e-06  3.3680e-04  0:00:18   16
         373  1.6167e-03  9.9857e-05  9.5638e-05  1.5826e-04  1.2472e-06  1.0361e-04  0:00:13   15
         374  1.4611e-03  8.6595e-05  8.3322e-05  1.0163e-04  3.9558e-07  4.1512e-05  0:00:13   14
         375  1.3479e-03  7.7129e-05  7.4388e-05  8.5128e-05  1.6245e-07  2.3105e-05  0:00:12   13
         376  1.2667e-03  7.0044e-05  6.7686e-05  7.6060e-05  8.7639e-08  1.6512e-05  0:00:11   12
         377  1.2052e-03  6.4600e-05  6.2565e-05  6.9468e-05  5.6130e-08  1.3430e-05  0:00:10   11
         378  1.1566e-03  6.0299e-05  5.8540e-05  6.4359e-05  4.0292e-08  1.1577e-05  0:00:10   10
         379  1.1170e-03  5.6808e-05  5.5303e-05  6.0276e-05  3.0767e-08  1.0267e-05  0:00:09    9
         380  1.0840e-03  5.3924e-05  5.2641e-05  5.6929e-05  2.4322e-08  9.2653e-06  0:00:08    8
         381  1.0560e-03  5.1488e-05  5.0400e-05  5.4122e-05  1.9643e-08  8.4713e-06  0:00:07    7
         382  1.0318e-03  4.9398e-05  4.8474e-05  5.1731e-05  1.6097e-08  7.8340e-06  0:00:06    6
         383  1.0108e-03  4.7587e-05  4.6800e-05  4.9671e-05  1.3335e-08  7.3161e-06  0:00:05    5
         384  9.9226e-04  4.5997e-05  4.5326e-05  4.7874e-05  1.1142e-08  6.8946e-06  0:00:04    4
      !  384 solution is converged
      Flow time = 0.01000000000000001s, time step = 20
      3980 more time steps
       done.
         384  9.9226e-04  4.5997e-05  4.5326e-05  4.7874e-05  1.1142e-08  6.8946e-06  0:00:20   20
         385  3.4427e-03  1.4866e-03  1.4037e-03  2.3729e-02  3.9704e-04  2.0391e-02  0:00:23   19
         386  2.5305e-03  5.3633e-04  5.0228e-04  7.2714e-03  8.6919e-05  5.1510e-03  0:00:21   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
         387  1.8373e-03  2.3240e-04  2.1608e-04  2.0263e-03  1.9638e-05  1.2331e-03  0:00:19   17
         388  1.4886e-03  1.5465e-04  1.4560e-04  5.9152e-04  4.7031e-06  3.2586e-04  0:00:18   16
         389  1.2653e-03  1.2604e-04  1.1998e-04  2.2293e-04  1.2479e-06  9.8553e-05  0:00:16   15
         390  1.0884e-03  1.0830e-04  1.0374e-04  1.3320e-04  3.9448e-07  3.8025e-05  0:00:12   14
         391  9.5983e-04  9.5650e-05  9.1941e-05  1.0842e-04  1.6092e-07  2.0166e-05  0:00:12   13
      !  391 solution is converged
      Flow time = 0.01050000000000001s, time step = 21
      3979 more time steps
       done.
         Time = 0.146 seconds.
         Done.
         Cell count                              70910     70934     354592
         Partition boundary cell count           1620      3018      10910
         Partition boundary cell count ratio     2.3%      4.3%      3.1%
         Face count                              146153    147650    728402
         Mean face count deviation               -0.5%     0.5%
         Partition boundary face count           1781      3265      5933
         Partition boundary face count ratio     1.2%      2.2%      0.8%
      Done.
      done.
         391  9.5983e-04  9.5650e-05  9.1941e-05  1.0842e-04  1.6092e-07  2.0166e-05  0:00:18   20
         392  3.5282e-03  1.7329e-03  1.6238e-03  3.1225e-02  3.9661e-04  1.9808e-02  0:00:21   19
         393  2.7477e-03  5.7653e-04  5.3641e-04  8.5621e-03  8.6905e-05  5.0729e-03  0:00:20   18
         394  2.0698e-03  2.5289e-04  2.3518e-04  2.2232e-03  1.9647e-05  1.2092e-03  0:00:15   17
         395  1.6793e-03  1.7866e-04  1.6895e-04  6.4271e-04  4.7024e-06  3.2066e-04  0:00:14   16
         396  1.4290e-03  1.4938e-04  1.4245e-04  2.4416e-04  1.2426e-06  9.7470e-05  0:00:14   15
         397  1.2345e-03  1.3039e-04  1.2492e-04  1.5390e-04  3.8876e-07  3.7833e-05  0:00:13   14
         398  1.0934e-03  1.1657e-04  1.1204e-04  1.3106e-04  1.5587e-07  2.0238e-05  0:00:12   13
         399  9.9386e-04  1.0611e-04  1.0226e-04  1.1783e-04  8.1788e-08  1.4012e-05  0:00:11   12
      !  399 solution is converged
      Flow time = 0.01100000000000001s, time step = 22
      3978 more time steps
       done.
         399  9.9386e-04  1.0611e-04  1.0226e-04  1.1783e-04  8.1788e-08  1.4012e-05  0:00:19   20
         400  3.6642e-03  1.5324e-03  1.4209e-03  3.1937e-02  3.9620e-04  1.9288e-02  0:00:18   19
         401  3.1618e-03  4.2595e-04  3.9354e-04  7.0294e-03  8.6904e-05  4.9502e-03  0:00:18   18
       turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
         402  2.5091e-03  1.9522e-04  1.8161e-04  1.7891e-03  1.9666e-05  1.1839e-03  0:00:17   17
         403  2.1326e-03  1.4241e-04  1.3485e-04  5.1169e-04  4.7099e-06  3.1402e-04  0:00:16   16
         404  1.8837e-03  1.2135e-04  1.1589e-04  1.9075e-04  1.2445e-06  9.4230e-05  0:00:15   15
         405  1.6846e-03  1.0781e-04  1.0344e-04  1.2411e-04  3.8893e-07  3.5310e-05  0:00:14   14
         406  1.5403e-03  9.7983e-05  9.4308e-05  1.0847e-04  1.5559e-07  1.7940e-05  0:00:13   13
         407  1.4395e-03  9.0488e-05  8.7257e-05  9.9290e-05  8.1410e-08  1.1922e-05  0:00:12   12
         408  1.3653e-03  8.4567e-05  8.1678e-05  9.2034e-05  5.2274e-08  9.2930e-06  0:00:09   11
         409  1.3082e-03  7.9768e-05  7.7158e-05  8.6129e-05  3.6686e-08  7.8392e-06  0:00:08   10
         410  1.2624e-03  7.5762e-05  7.3429e-05  8.1227e-05  2.7452e-08  6.8924e-06  0:00:08    9
         411  1.2246e-03  7.2339e-05  7.0253e-05  7.7093e-05  2.1305e-08  6.2173e-06  0:00:07    8
         412  1.1925e-03  6.9368e-05  6.7489e-05  7.3547e-05  1.6913e-08  5.7110e-06  0:00:06    7
         413  1.1648e-03  6.6741e-05  6.5040e-05  7.0456e-05  1.3639e-08  5.3188e-06  0:00:06    6
         414  1.1404e-03  6.4386e-05  6.2837e-05  6.7731e-05  1.1128e-08  5.0120e-06  0:00:05    5
         415  1.1186e-03  6.2264e-05  6.0843e-05  6.5308e-05  9.1632e-09  4.7668e-06  0:00:04    4
         416  1.0989e-03  6.0342e-05  5.9027e-05  6.3132e-05  7.6030e-09  4.5674e-06  0:00:03    3
         417  1.0810e-03  5.8591e-05  5.7364e-05  6.1156e-05  6.3488e-09  4.4027e-06  0:00:02    2
         418  1.0644e-03  5.6983e-05  5.5828e-05  5.9346e-05  5.3306e-09  4.2642e-06  0:00:01    1
         419  1.0492e-03  5.5502e-05  5.4406e-05  5.7685e-05  4.4969e-09  4.1465e-06  0:00:00    0
      Flow time = 0.01150000000000001s, time step = 23
      3977 more time steps
       done.
         419  1.0492e-03  5.5502e-05  5.4406e-05  5.7685e-05  4.4969e-09  4.1465e-06  0:00:20   20
         420  3.9989e-03  1.1525e-03  1.0582e-03  2.2943e-02  3.9581e-04  1.8459e-02  0:00:19   19
         421  3.6649e-03  3.3694e-04  3.0809e-04  5.1351e-03  8.6912e-05  4.7955e-03  0:00:18   18
         422  2.9733e-03  1.5998e-04  1.4737e-04  1.3304e-03  1.9693e-05  1.1361e-03  0:00:17   17
         423  2.5584e-03  1.1534e-04  1.0851e-04  3.8688e-04  4.7232e-06  3.0067e-04  0:00:16   16
         424  2.2816e-03  9.7253e-05  9.2676e-05  1.4614e-04  1.2509e-06  9.0954e-05  0:00:15   15
         425  2.0609e-03  8.5701e-05  8.2237e-05  9.5524e-05  3.9261e-07  3.5011e-05  0:00:14   14
         426  1.8985e-03  7.7217e-05  7.4421e-05  8.3130e-05  1.5814e-07  1.8519e-05  0:00:13   13
         427  1.7825e-03  7.0703e-05  6.8376e-05  7.5680e-05  8.3338e-08  1.2701e-05  0:00:12   12
         428  1.6953e-03  6.5554e-05  6.3574e-05  6.9752e-05  5.3778e-08  1.0027e-05  0:00:11   11
         429  1.6267e-03  6.1394e-05  5.9692e-05  6.4916e-05  3.7825e-08  8.4236e-06  0:00:10   10
         430  1.5708e-03  5.7962e-05  5.6508e-05  6.0937e-05  2.8317e-08  7.2949e-06  0:00:09    9
         431  1.5242e-03  5.5093e-05  5.3844e-05  5.7640e-05  2.1960e-08  6.4363e-06  0:00:08    8
         432  1.4847e-03  5.2666e-05  5.1588e-05  5.4865e-05  1.7408e-08  5.7600e-06  0:00:07    7
         433  1.4506e-03  5.0583e-05  4.9657e-05  5.2505e-05  1.4010e-08  5.2194e-06  0:00:05    6
         434  1.4208e-03  4.8788e-05  4.7981e-05  5.0486e-05  1.1403e-08  4.7884e-06  0:00:04    5
         435  1.3944e-03  4.7230e-05  4.6520e-05  4.8738e-05  9.3637e-09  4.4379e-06  0:00:03    4
         436  1.3709e-03  4.5859e-05  4.5237e-05  4.7216e-05  7.7458e-09  4.1580e-06  0:00:03    3
         437  1.3498e-03  4.4652e-05  4.4102e-05  4.5880e-05  6.4471e-09  3.9330e-06  0:00:02    2
         438  1.3307e-03  4.3579e-05  4.3090e-05  4.4696e-05  5.3945e-09  3.7521e-06  0:00:01    1
         439  1.3133e-03  4.2621e-05  4.2181e-05  4.3648e-05  4.5346e-09  3.6060e-06  0:00:00    0
      Flow time = 0.01200000000000001s, time step = 24
      3976 more time steps
       done.
         439  1.3133e-03  4.2621e-05  4.2181e-05  4.3648e-05  4.5346e-09  3.6060e-06  0:00:19   20
         440  4.6688e-03  1.0487e-03  9.7967e-04  1.4980e-02  3.9540e-04  1.8125e-02  0:00:22   19
         441  4.0842e-03  3.1476e-04  2.9234e-04  3.5340e-03  8.6909e-05  4.7863e-03  0:00:20   18
         442  3.3074e-03  1.4469e-04  1.3425e-04  9.3510e-04  1.9711e-05  1.1344e-03  0:00:19   17
         443  2.8606e-03  1.0298e-04  9.7306e-05  2.7967e-04  4.7310e-06  3.0048e-04  0:00:17   16
         444  2.5632e-03  8.7347e-05  8.3708e-05  1.1385e-04  1.2531e-06  8.9432e-05  0:00:16   15
         445  2.3252e-03  7.7834e-05  7.5211e-05  8.3835e-05  3.9291e-07  3.2803e-05  0:00:15   14
         446  2.1505e-03  7.1032e-05  6.9007e-05  7.5542e-05  1.5788e-07  1.6175e-05  0:00:14   13
         447  2.0259e-03  6.5914e-05  6.4277e-05  6.9738e-05  8.2899e-08  1.0429e-05  0:00:12   12
         448  1.9325e-03  6.1953e-05  6.0613e-05  6.5105e-05  5.3270e-08  7.8966e-06  0:00:09   11
         449  1.8593e-03  5.8822e-05  5.7709e-05  6.1409e-05  3.7291e-08  6.4733e-06  0:00:09   10
        iter  continuity  x-velocity  y-velocity  z-velocity           k       omega     time/iter
         450  1.8002e-03  5.6285e-05  5.5345e-05  5.8423e-05  2.7780e-08  5.5404e-06  0:00:08    9
         451  1.7514e-03  5.4178e-05  5.3385e-05  5.5960e-05  2.1438e-08  4.8778e-06  0:00:07    8
         452  1.7102e-03  5.2386e-05  5.1729e-05  5.3895e-05  1.6910e-08  4.3987e-06  0:00:07    7
         453  1.6746e-03  5.0832e-05  5.0292e-05  5.2144e-05  1.3543e-08  4.0346e-06  0:00:06    6
         454  1.6435e-03  4.9465e-05  4.9029e-05  5.0630e-05  1.0970e-08  3.6351e-06  0:00:05    5
         455  1.6162e-03  4.8252e-05  4.7905e-05  4.9301e-05  8.9656e-09  3.3881e-06  0:00:04    4
         456  1.5917e-03  4.7167e-05  4.6898e-05  4.8129e-05  7.3818e-09  3.1921e-06  0:00:03    3
         457  1.5697e-03  4.6194e-05  4.5990e-05  4.7088e-05  6.1158e-09  3.0331e-06  0:00:02    2
         458  1.5499e-03  4.5318e-05  4.5167e-05  4.6156e-05  5.0939e-09  2.9010e-06  0:00:01    1
         459  1.5317e-03  4.4522e-05  4.4419e-05  4.5314e-05  4.2624e-09  2.7889e-06  0:00:00    0
      Flow time = 0.01250000000000001s, time step = 25
      3975 more time steps
       done.
         459  1.5317e-03  4.4522e-05  4.4419e-05  4.5314e-05  4.2624e-09  2.7889e-06  0:00:20   20
         460  4.9664e-03  8.5131e-04  7.9221e-04  8.4378e-03  3.9499e-04  1.7570e-02  0:00:19   19
         461  4.3547e-03  2.7208e-04  2.5147e-04  2.1002e-03  8.6903e-05  4.6033e-03  0:00:18   18
         462  3.5299e-03  1.3085e-04  1.2143e-04  5.7788e-04  1.9727e-05  1.0990e-03  0:00:17   17
         463  3.0627e-03  9.6082e-05  9.1065e-05  1.8645e-04  4.7367e-06  2.9111e-04  0:00:16   16
         464  2.7509e-03  8.2935e-05  7.9701e-05  9.3411e-05  1.2538e-06  8.6418e-05  0:00:15   15
         465  2.4989e-03  7.4850e-05  7.2464e-05  7.8303e-05  3.9213e-07  3.1561e-05  0:00:14   14
         466  2.3142e-03  6.8993e-05  6.7098e-05  7.1947e-05  1.5679e-07  1.5538e-05  0:00:13   13
         467  2.1824e-03  6.4541e-05  6.3007e-05  6.7077e-05  8.1798e-08  1.0065e-05  0:00:12   12
         468  2.0831e-03  6.1078e-05  5.9815e-05  6.3179e-05  5.2229e-08  7.7031e-06  0:00:11   11
         469  2.0050e-03  5.8331e-05  5.7269e-05  6.0081e-05  3.6336e-08  6.3677e-06  0:00:10   10
         470  1.9418e-03  5.6081e-05  5.5183e-05  5.7591e-05  2.6912e-08  5.4820e-06  0:00:09    9
         471  1.8895e-03  5.4196e-05  5.3426e-05  5.5529e-05  2.0652e-08  4.8448e-06  0:00:08    8
         472  1.8454e-03  5.2581e-05  5.1910e-05  5.3787e-05  1.6203e-08  4.3849e-06  0:00:07    7
         473  1.8076e-03  5.1177e-05  5.0590e-05  5.2290e-05  1.2908e-08  4.0339e-06  0:00:05    6
         474  1.7749e-03  4.9940e-05  4.9423e-05  5.0976e-05  1.0401e-08  3.7606e-06  0:00:04    5
         475  1.7464e-03  4.8835e-05  4.8382e-05  4.9807e-05  8.4577e-09  3.5435e-06  0:00:03    4
         476  1.7211e-03  4.7838e-05  4.7447e-05  4.8756e-05  6.9287e-09  3.3692e-06  0:00:03    3
         477  1.6984e-03  4.6936e-05  4.6599e-05  4.7807e-05  5.7119e-09  3.2285e-06  0:00:02    2
         478  1.6778e-03  4.6114e-05  4.5824e-05  4.6945e-05  4.7342e-09  3.1112e-06  0:00:01    1
         479  1.6590e-03  4.5359e-05  4.5110e-05  4.6157e-05  3.9421e-09  3.0125e-06  0:00:00    0
      Flow time = 0.01300000000000001s, time step = 26
      3974 more time steps
       done.
         Time = 0.145 seconds.
         Done.
         Cell count                              71431     71614     357560
         Mean cell count deviation               -0.1%     0.1%
         Partition boundary cell count           1666      2885      10820
         Partition boundary cell count ratio     2.3%      4.0%      3.0%
         Face count                              147304    149078    734338
         Partition boundary face count           1825      3109      5899
         Partition boundary face count ratio     1.2%      2.1%      0.8%
         Mean cell weight deviation              -0.1%     0.1%
      Done.
         Smoothing partition boundaries...done.
         479  1.6590e-03  4.5359e-05  4.5110e-05  4.6157e-05  3.9421e-09  3.0125e-06  0:00:19   20
         480  5.3406e-03  6.4482e-04  5.9071e-04  3.1603e-03  3.9459e-04  1.6985e-02  0:00:18   19
         481  4.5556e-03  2.3104e-04  2.1186e-04  8.5735e-04  8.6894e-05  4.4686e-03  0:00:17   18
         482  3.6972e-03  1.2263e-04  1.1388e-04  2.6952e-04  1.9742e-05  1.0606e-03  0:00:17   17
         483  3.1807e-03  9.2918e-05  8.8256e-05  1.1496e-04  4.7417e-06  2.7982e-04  0:00:16   16
         484  2.8410e-03  8.0583e-05  7.7615e-05  8.4264e-05  1.2541e-06  8.2444e-05  0:00:15   15
         485  2.5765e-03  7.2707e-05  7.0532e-05  7.5256e-05  3.9104e-07  2.9621e-05  0:00:14   14
         486  2.3831e-03  6.6835e-05  6.5137e-05  6.9206e-05  1.5546e-07  1.4205e-05  0:00:13   13
         487  2.2415e-03  6.2282e-05  6.0916e-05  6.4391e-05  8.0514e-08  8.9173e-06  0:00:12   12
         488  2.1325e-03  5.8678e-05  5.7577e-05  6.0495e-05  5.1046e-08  6.5879e-06  0:00:11   11
         489  2.0456e-03  5.5786e-05  5.4873e-05  5.7357e-05  3.5279e-08  5.2760e-06  0:00:10   10
         490  1.9747e-03  5.3402e-05  5.2630e-05  5.4789e-05  2.5971e-08  4.4074e-06  0:00:09    9
         491  1.9155e-03  5.1394e-05  5.0744e-05  5.2642e-05  1.9817e-08  3.7719e-06  0:00:06    8
         492  1.8653e-03  4.9688e-05  4.9137e-05  5.0827e-05  1.5464e-08  3.3055e-06  0:00:06    7
         493  1.8219e-03  4.8221e-05  4.7753e-05  4.9277e-05  1.2255e-08  2.9491e-06  0:00:05    6
         494  1.7839e-03  4.6947e-05  4.6542e-05  4.7929e-05  9.8250e-09  2.6668e-06  0:00:04    5
         495  1.7503e-03  4.5824e-05  4.5471e-05  4.6746e-05  7.9494e-09  2.4396e-06  0:00:04    4
         496  1.7204e-03  4.4829e-05  4.4524e-05  4.5701e-05  6.4807e-09  2.2543e-06  0:00:03    3
         497  1.6935e-03  4.3943e-05  4.3679e-05  4.4770e-05  5.3173e-09  2.1086e-06  0:00:02    2
         498  1.6692e-03  4.3151e-05  4.2923e-05  4.3938e-05  4.3866e-09  1.9864e-06  0:00:01    1
         499  1.6471e-03  4.2440e-05  4.2244e-05  4.3189e-05  3.6361e-09  1.8840e-06  0:00:00    0
      Flow time = 0.01350000000000001s, time step = 27
      3973 more time steps
       done.
         499  1.6471e-03  4.2440e-05  4.2244e-05  4.3189e-05  3.6361e-09  1.8840e-06  0:00:19   20
         500  5.7401e-03  4.8259e-04  4.3856e-04  2.6686e-03  3.9419e-04  1.6516e-02  0:00:18   19
         501  4.6858e-03  1.9828e-04  1.8133e-04  7.5732e-04  8.6883e-05  4.3962e-03  0:00:18   18
         502  3.6775e-03  1.1404e-04  1.0557e-04  2.4543e-04  1.9755e-05  1.0413e-03  0:00:17   17
         503  3.1257e-03  8.7561e-05  8.2730e-05  1.1396e-04  4.7461e-06  2.7474e-04  0:00:16   16
         504  2.7713e-03  7.5865e-05  7.2643e-05  8.2214e-05  1.2541e-06  8.0849e-05  0:00:15   15
         505  2.4870e-03  6.8429e-05  6.5986e-05  7.1861e-05  3.8983e-07  2.8964e-05  0:00:14   14
         506  2.2766e-03  6.3035e-05  6.1030e-05  6.5778e-05  1.5407e-07  1.3826e-05  0:00:13   13
         507  2.1235e-03  5.8910e-05  5.7222e-05  6.1232e-05  7.9204e-08  8.6684e-06  0:00:12   12
         508  2.0072e-03  5.5674e-05  5.4255e-05  5.7644e-05  4.9858e-08  6.4176e-06  0:00:11   11
         509  1.9154e-03  5.3071e-05  5.1886e-05  5.4783e-05  3.4231e-08  5.1291e-06  0:00:10   10
         510  1.8409e-03  5.0922e-05  4.9923e-05  5.2439e-05  2.5048e-08  4.2592e-06  0:00:09    9
         511  1.7792e-03  4.9104e-05  4.8267e-05  5.0476e-05  1.9006e-08  3.6479e-06  0:00:08    8
         512  1.7276e-03  4.7535e-05  4.6836e-05  4.8793e-05  1.4751e-08  3.2062e-06  0:00:07    7
         513  1.6836e-03  4.6162e-05  4.5583e-05  4.7327e-05  1.1629e-08  2.8598e-06  0:00:06    6
         514  1.6455e-03  4.4943e-05  4.4469e-05  4.6038e-05  9.2750e-09  2.5725e-06  0:00:05    5
         515  1.6120e-03  4.3853e-05  4.3466e-05  4.4888e-05  7.4667e-09  2.3537e-06  0:00:04    4
         516  1.5824e-03  4.2871e-05  4.2555e-05  4.3856e-05  6.0568e-09  2.2081e-06  0:00:02    3
         517  1.5561e-03  4.1979e-05  4.1722e-05  4.2918e-05  4.9449e-09  2.0845e-06  0:00:02    2
         518  1.5323e-03  4.1164e-05  4.0958e-05  4.2060e-05  4.0595e-09  1.9751e-06  0:00:01    1
         519  1.5107e-03  4.0414e-05  4.0251e-05  4.1277e-05  3.3485e-09  1.8776e-06  0:00:00    0
      Flow time = 0.01400000000000001s, time step = 28
      3972 more time steps
       done.
         519  1.5107e-03  4.0414e-05  4.0251e-05  4.1277e-05  3.3485e-09  1.8776e-06  0:00:18   20
         520  5.7172e-03  6.0355e-04  5.4622e-04  7.2305e-03  3.9380e-04  1.6064e-02  0:00:21   19
         521  4.5348e-03  2.3207e-04  2.1051e-04  1.9997e-03  8.6872e-05  4.2676e-03  0:00:20   18
         522  3.4323e-03  1.2408e-04  1.1398e-04  5.7242e-04  1.9767e-05  1.0118e-03  0:00:18   17
         523  2.8290e-03  9.2605e-05  8.7169e-05  1.9189e-04  4.7502e-06  2.6746e-04  0:00:17   16
         524  2.4433e-03  7.8525e-05  7.4942e-05  9.6251e-05  1.2540e-06  7.8744e-05  0:00:16   15
         525  2.1409e-03  6.9354e-05  6.6609e-05  7.5223e-05  3.8860e-07  2.8182e-05  0:00:15   14
         526  1.9202e-03  6.2580e-05  6.0323e-05  6.6501e-05  1.5269e-07  1.3428e-05  0:00:11   13
         527  1.7646e-03  5.7342e-05  5.5436e-05  6.0439e-05  7.7922e-08  8.3690e-06  0:00:10   12
         528  1.6492e-03  5.3194e-05  5.1573e-05  5.5710e-05  4.8706e-08  6.1607e-06  0:00:10   11
         529  1.5601e-03  4.9845e-05  4.8456e-05  5.1938e-05  3.3223e-08  4.9340e-06  0:00:09   10
         530  1.4893e-03  4.7065e-05  4.5876e-05  4.8848e-05  2.4169e-08  4.1335e-06  0:00:08    9
         531  1.4319e-03  4.4728e-05  4.3703e-05  4.6276e-05  1.8238e-08  3.5605e-06  0:00:08    8
         532  1.3844e-03  4.2743e-05  4.1849e-05  4.4104e-05  1.4081e-08  3.1241e-06  0:00:07    7
         533  1.3442e-03  4.1028e-05  4.0245e-05  4.2239e-05  1.1044e-08  2.7964e-06  0:00:06    6
         534  1.3099e-03  3.9532e-05  3.8845e-05  4.0623e-05  8.7654e-09  2.5428e-06  0:00:05    5
         535  1.2804e-03  3.8216e-05  3.7614e-05  3.9214e-05  7.0223e-09  2.3403e-06  0:00:04    4
         536  1.2546e-03  3.7046e-05  3.6526e-05  3.7974e-05  5.6694e-09  2.1789e-06  0:00:03    3
         537  1.2317e-03  3.6012e-05  3.5558e-05  3.6873e-05  4.6071e-09  2.0518e-06  0:00:02    2
         538  1.2115e-03  3.5092e-05  3.4695e-05  3.5896e-05  3.7648e-09  1.9462e-06  0:00:01    1
         539  1.1935e-03  3.4270e-05  3.3922e-05  3.5023e-05  3.0915e-09  1.8576e-06  0:00:00    0
      Flow time = 0.01450000000000001s, time step = 29
      3971 more time steps
       done.
         539  1.1935e-03  3.4270e-05  3.3922e-05  3.5023e-05  3.0915e-09  1.8576e-06  0:00:20   20
         540  5.5545e-03  7.9779e-04  7.2700e-04  1.1528e-02  3.9341e-04  1.5675e-02  0:00:23   19
         541  4.2910e-03  2.8741e-04  2.6174e-04  3.2348e-03  8.6859e-05  4.2217e-03  0:00:17   18
         542  3.1655e-03  1.3695e-04  1.2560e-04  9.0094e-04  1.9778e-05  9.9720e-04  0:00:16   17
         543  2.5555e-03  9.5376e-05  8.9303e-05  2.7785e-04  4.7539e-06  2.6464e-04  0:00:16   16
         544  2.1640e-03  7.7877e-05  7.3761e-05  1.1437e-04  1.2538e-06  7.8472e-05  0:00:15   15
         545  1.8586e-03  6.6737e-05  6.3580e-05  7.6307e-05  3.8737e-07  2.8241e-05  0:00:14   14
         546  1.6379e-03  5.8736e-05  5.6179e-05  6.4332e-05  1.5135e-07  1.3466e-05  0:00:13   13
         547  1.4826e-03  5.2756e-05  5.0640e-05  5.7059e-05  7.6687e-08  8.3924e-06  0:00:12   12
         548  1.3669e-03  4.8215e-05  4.6440e-05  5.1677e-05  4.7606e-08  6.1700e-06  0:00:11   11
         549  1.2777e-03  4.4705e-05  4.3187e-05  4.7555e-05  3.2269e-08  4.9010e-06  0:00:10   10
         550  1.2070e-03  4.1919e-05  4.0612e-05  4.4317e-05  2.3341e-08  4.0297e-06  0:00:09    9
         551  1.1499e-03  3.9667e-05  3.8532e-05  4.1705e-05  1.7520e-08  3.3980e-06  0:00:08    8
         552  1.1028e-03  3.7812e-05  3.6829e-05  3.9570e-05  1.3458e-08  2.9367e-06  0:00:07    7
         553  1.0633e-03  3.6262e-05  3.5407e-05  3.7796e-05  1.0504e-08  2.5962e-06  0:00:06    6
         554  1.0297e-03  3.4951e-05  3.4202e-05  3.6305e-05  8.2968e-09  2.3350e-06  0:00:05    5
         555  1.0007e-03  3.3819e-05  3.3161e-05  3.5038e-05  6.6159e-09  2.1355e-06  0:00:04    4
         556  9.7525e-04  3.2835e-05  3.2254e-05  3.3944e-05  5.3170e-09  1.9741e-06  0:00:03    3
      !  556 solution is converged
      Flow time = 0.01500000000000001s, time step = 30
      3970 more time steps
       done.
         556  9.7525e-04  3.2835e-05  3.2254e-05  3.3944e-05  5.3170e-09  1.9741e-06  0:00:20   20
         557  5.6758e-03  9.5324e-04  8.6983e-04  1.5251e-02  3.9303e-04  1.5386e-02  0:00:23   19
         558  4.2305e-03  3.4562e-04  3.1565e-04  4.3790e-03  8.6846e-05  4.2115e-03  0:00:21   18
         559  2.9854e-03  1.6098e-04  1.4809e-04  1.2189e-03  1.9789e-05  9.9524e-04  0:00:19   17
         560  2.3266e-03  1.1059e-04  1.0359e-04  3.7119e-04  4.7569e-06  2.6525e-04  0:00:18   16
         561  1.9127e-03  8.9566e-05  8.4759e-05  1.4771e-04  1.2532e-06  7.8250e-05  0:00:16   15
         562  1.5868e-03  7.6032e-05  7.2276e-05  9.1430e-05  3.8590e-07  2.7603e-05  0:00:15   14
         563  1.3501e-03  6.6276e-05  6.3145e-05  7.4220e-05  1.4984e-07  1.2736e-05  0:00:14   13
         564  1.1826e-03  5.8910e-05  5.6253e-05  6.4846e-05  7.5330e-08  7.6672e-06  0:00:13   12
         565  1.0583e-03  5.3176e-05  5.0898e-05  5.7914e-05  4.6415e-08  5.4623e-06  0:00:11   11
         566  9.6284e-04  4.8595e-05  4.6619e-05  5.2473e-05  3.1252e-08  4.2320e-06  0:00:10   10
      !  566 solution is converged
      Flow time = 0.01550000000000001s, time step = 31
      3969 more time steps
       done.
         Done.
         Cell count                              71706     72934     363362
         Mean cell count deviation               -1.3%     0.4%
         Partition boundary cell count           1847      2918      11490
         Partition boundary cell count ratio     2.6%      4.0%      3.2%
         Face count                              147967    151627    745942
         Mean face count deviation               -1.7%     0.8%
         Partition boundary face count           2067      3173      6331
         Partition boundary face count ratio     1.4%      2.1%      0.8%
         Mean cell weight deviation              -1.3%     0.4%
         Partition neighbor count                3         4
      Done.
         566  9.6284e-04  4.8595e-05  4.6619e-05  5.2473e-05  3.1252e-08  4.2320e-06  0:00:21   20
         567  5.7253e-03  1.1674e-03  1.0674e-03  1.8367e-02  3.9266e-04  1.5036e-02  0:00:19   19
         568  4.1442e-03  4.1127e-04  3.7420e-04  5.1615e-03  8.6829e-05  4.1313e-03  0:00:18   18
         569  2.9325e-03  1.8778e-04  1.7137e-04  1.3929e-03  1.9795e-05  9.7147e-04  0:00:17   17
         570  2.2682e-03  1.2975e-04  1.2055e-04  4.2207e-04  4.7574e-06  2.5954e-04  0:00:16   16
         571  1.8483e-03  1.0642e-04  1.0000e-04  1.6993e-04  1.2509e-06  7.7456e-05  0:00:15   15
         572  1.5242e-03  9.1519e-05  8.6586e-05  1.0803e-04  3.8309e-07  2.8184e-05  0:00:14   14
         573  1.2952e-03  8.0741e-05  7.6776e-05  9.0438e-05  1.4731e-07  1.3755e-05  0:00:13   13
         574  1.1375e-03  7.2645e-05  6.9336e-05  8.0547e-05  7.3182e-08  8.8473e-06  0:00:12   12
         575  1.0215e-03  6.6368e-05  6.3544e-05  7.2948e-05  4.4606e-08  6.7533e-06  0:00:11   11
         576  9.3234e-04  6.1369e-05  5.8948e-05  6.6871e-05  2.9767e-08  5.6057e-06  0:00:10   10
      !  576 solution is converged
      Flow time = 0.01600000000000001s, time step = 32
      3968 more time steps
       done.
         576  9.3234e-04  6.1369e-05  5.8948e-05  6.6871e-05  2.9767e-08  5.6057e-06  0:00:20   20
         577  5.8717e-03  1.3335e-03  1.2274e-03  1.9714e-02  3.9230e-04  1.4454e-02  0:00:23   19
         578  4.5413e-03  4.0240e-04  3.6781e-04  4.6964e-03  8.6816e-05  3.9682e-03  0:00:21   18
         579  3.2425e-03  1.8163e-04  1.6618e-04  1.2448e-03  1.9804e-05  9.4136e-04  0:00:19   17
         580  2.5346e-03  1.2615e-04  1.1756e-04  3.7988e-04  4.7600e-06  2.5278e-04  0:00:18   16
         581  2.0889e-03  1.0388e-04  9.8052e-05  1.5610e-04  1.2503e-06  7.6266e-05  0:00:16   15
         582  1.7408e-03  8.9591e-05  8.5251e-05  1.0268e-04  3.8184e-07  2.8369e-05  0:00:15   14
         583  1.4905e-03  7.9060e-05  7.5766e-05  8.7252e-05  1.4608e-07  1.4262e-05  0:00:14   13
         584  1.3175e-03  7.0990e-05  6.8441e-05  7.7732e-05  7.2114e-08  9.4325e-06  0:00:13   12
         585  1.1919e-03  6.4616e-05  6.2636e-05  7.0171e-05  4.3700e-08  7.3556e-06  0:00:11   11
         586  1.0958e-03  5.9491e-05  5.7922e-05  6.4060e-05  2.9015e-08  6.2162e-06  0:00:10   10
         587  1.0196e-03  5.5282e-05  5.4004e-05  5.9058e-05  2.0618e-08  5.4881e-06  0:00:09    9
         588  9.5736e-04  5.1752e-05  5.0694e-05  5.4894e-05  1.5232e-08  4.9801e-06  0:00:08    8
      !  588 solution is converged
      Flow time = 0.01650000000000001s, time step = 33
      3967 more time steps
       done.
         588  9.5736e-04  5.1752e-05  5.0694e-05  5.4894e-05  1.5232e-08  4.9801e-06  0:00:20   20
         589  6.1257e-03  1.1727e-03  1.0878e-03  1.6549e-02  3.9196e-04  1.4202e-02  0:00:23   19
         590  4.9233e-03  3.4748e-04  3.2138e-04  3.9196e-03  8.6807e-05  3.9299e-03  0:00:21   18
         591  3.6409e-03  1.5444e-04  1.4325e-04  1.0418e-03  1.9815e-05  9.2779e-04  0:00:19   17
         592  2.9204e-03  1.0578e-04  9.9695e-05  3.1582e-04  4.7641e-06  2.4865e-04  0:00:18   16
         593  2.4584e-03  8.7175e-05  8.3146e-05  1.2813e-04  1.2510e-06  7.4368e-05  0:00:16   15
         594  2.0941e-03  7.5761e-05  7.2746e-05  8.5657e-05  3.8156e-07  2.7071e-05  0:00:15   14
         595  1.8293e-03  6.7576e-05  6.5226e-05  7.3661e-05  1.4562e-07  1.3115e-05  0:00:11   13
         596  1.6426e-03  6.1423e-05  5.9557e-05  6.6348e-05  7.1672e-08  8.3170e-06  0:00:11   12
         597  1.5046e-03  5.6717e-05  5.5189e-05  6.0679e-05  4.3299e-08  6.2371e-06  0:00:10   11
         598  1.3988e-03  5.2969e-05  5.1720e-05  5.6152e-05  2.8662e-08  5.0899e-06  0:00:09   10
         599  1.3154e-03  4.9907e-05  4.8887e-05  5.2527e-05  2.0306e-08  4.3419e-06  0:00:08    9
         600  1.2480e-03  4.7346e-05  4.6522e-05  4.9549e-05  1.4959e-08  3.8137e-06  0:00:08    8
         601  1.1921e-03  4.5164e-05  4.4512e-05  4.7048e-05  1.1291e-08  3.4237e-06  0:00:07    7
         602  1.1456e-03  4.3278e-05  4.2760e-05  4.4914e-05  8.6666e-09  3.1297e-06  0:00:06    6
         603  1.1058e-03  4.1621e-05  4.1210e-05  4.3077e-05  6.7358e-09  2.9022e-06  0:00:05    5
         604  1.0714e-03  4.0144e-05  3.9825e-05  4.1452e-05  5.2876e-09  2.7196e-06  0:00:04    4
         605  1.0414e-03  3.8808e-05  3.8570e-05  4.0009e-05  4.1851e-09  2.5741e-06  0:00:03    3
         606  1.0149e-03  3.7603e-05  3.7428e-05  3.8720e-05  3.3356e-09  2.4555e-06  0:00:02    2
         607  9.9133e-04  3.6500e-05  3.6381e-05  3.7538e-05  2.6744e-09  2.3572e-06  0:00:01    1
      !  607 solution is converged
      Flow time = 0.01700000000000001s, time step = 34
      3966 more time steps
       done.
         607  9.9133e-04  3.6500e-05  3.6381e-05  3.7538e-05  2.6744e-09  2.3572e-06  0:00:20   20
         608  6.5977e-03  9.2902e-04  8.6768e-04  1.2429e-02  3.9164e-04  1.3831e-02  0:00:23   19
         609  5.3372e-03  2.8833e-04  2.6680e-04  3.0251e-03  8.6800e-05  3.8219e-03  0:00:21   18
         610  3.9970e-03  1.3252e-04  1.2259e-04  8.1576e-04  1.9826e-05  9.0701e-04  0:00:19   17
         611  3.2478e-03  9.2811e-05  8.7361e-05  2.5175e-04  4.7685e-06  2.4422e-04  0:00:18   16
         612  2.7625e-03  7.7542e-05  7.4042e-05  1.0630e-04  1.2520e-06  7.4269e-05  0:00:16   15
         613  2.3811e-03  6.8154e-05  6.5584e-05  7.5014e-05  3.8153e-07  2.8118e-05  0:00:15   14
         614  2.1064e-03  6.1381e-05  5.9367e-05  6.5924e-05  1.4538e-07  1.4507e-05  0:00:14   13
         615  1.9144e-03  5.6269e-05  5.4649e-05  6.0055e-05  7.1396e-08  9.8026e-06  0:00:12   12
         616  1.7730e-03  5.2315e-05  5.0996e-05  5.5420e-05  4.3031e-08  7.7190e-06  0:00:11   11
         617  1.6645e-03  4.9197e-05  4.8097e-05  5.1756e-05  2.8412e-08  6.5604e-06  0:00:10   10
         618  1.5786e-03  4.6657e-05  4.5725e-05  4.8818e-05  2.0077e-08  5.8022e-06  0:00:09    9
         619  1.5092e-03  4.4547e-05  4.3734e-05  4.6411e-05  1.4749e-08  5.2678e-06  0:00:08    8
         620  1.4524e-03  4.2759e-05  4.2030e-05  4.4393e-05  1.1102e-08  4.8949e-06  0:00:08    7
         621  1.4046e-03  4.1217e-05  4.0564e-05  4.2677e-05  8.4976e-09  4.6161e-06  0:00:07    6
         622  1.3638e-03  3.9864e-05  3.9288e-05  4.1195e-05  6.5859e-09  4.4041e-06  0:00:06    5
         623  1.3286e-03  3.8660e-05  3.8151e-05  3.9885e-05  5.1551e-09  4.2258e-06  0:00:04    4
         624  1.2979e-03  3.7583e-05  3.7135e-05  3.8720e-05  4.0683e-09  4.0818e-06  0:00:03    3
         625  1.2706e-03  3.6614e-05  3.6222e-05  3.7678e-05  3.2328e-09  3.9642e-06  0:00:02    2
         626  1.2460e-03  3.5732e-05  3.5396e-05  3.6734e-05  2.5843e-09  3.8669e-06  0:00:01    1
         627  1.2238e-03  3.4934e-05  3.4644e-05  3.5873e-05  2.0764e-09  3.7860e-06  0:00:00    0
      Flow time = 0.01750000000000001s, time step = 35
      3965 more time steps
       done.
         627  1.2238e-03  3.4934e-05  3.4644e-05  3.5873e-05  2.0764e-09  3.7860e-06  0:00:21   20
         628  7.0294e-03  7.2056e-04  6.7065e-04  8.3058e-03  3.9132e-04  1.3584e-02  0:00:20   19
         629  5.7576e-03  2.4383e-04  2.2445e-04  2.0895e-03  8.6791e-05  3.7587e-03  0:00:19   18
         630  4.3093e-03  1.2170e-04  1.1223e-04  5.8222e-04  1.9835e-05  8.9368e-04  0:00:21   17
         631  3.5085e-03  8.9289e-05  8.3825e-05  1.9131e-04  4.7715e-06  2.4076e-04  0:00:19   16
         632  2.9994e-03  7.5338e-05  7.1638e-05  9.1277e-05  1.2519e-06  7.2129e-05  0:00:17   15
         633  2.6003e-03  6.6355e-05  6.3518e-05  7.1041e-05  3.8066e-07  2.6014e-05  0:00:16   14
         634  2.3091e-03  5.9827e-05  5.7463e-05  6.3428e-05  1.4445e-07  1.2314e-05  0:00:14   13
         635  2.1023e-03  5.4861e-05  5.2837e-05  5.7827e-05  7.0567e-08  7.5813e-06  0:00:13   12
         636  1.9503e-03  5.0969e-05  4.9235e-05  5.3341e-05  4.2310e-08  5.5081e-06  0:00:12   11
         637  1.8329e-03  4.7865e-05  4.6372e-05  4.9767e-05  2.7802e-08  4.3525e-06  0:00:10   10
         638  1.7394e-03  4.5345e-05  4.4043e-05  4.6886e-05  1.9559e-08  3.6002e-06  0:00:09    9
         639  1.6637e-03  4.3251e-05  4.2109e-05  4.4533e-05  1.4309e-08  3.0696e-06  0:00:08    8
         640  1.6008e-03  4.1477e-05  4.0475e-05  4.2571e-05  1.0728e-08  2.6766e-06  0:00:07    7
         641  1.5477e-03  3.9958e-05  3.9071e-05  4.0910e-05  8.1802e-09  2.3794e-06  0:00:07    6
         642  1.5019e-03  3.8635e-05  3.7842e-05  3.9479e-05  6.3165e-09  2.1474e-06  0:00:06    5
         643  1.4621e-03  3.7479e-05  3.6761e-05  3.8239e-05  4.9266e-09  1.9648e-06  0:00:05    4
         644  1.4272e-03  3.6455e-05  3.5798e-05  3.7147e-05  3.8746e-09  1.8189e-06  0:00:03    3
         645  1.3960e-03  3.5537e-05  3.4938e-05  3.6177e-05  3.0685e-09  1.7059e-06  0:00:02    2
         646  1.3680e-03  3.4706e-05  3.4161e-05  3.5311e-05  2.4450e-09  1.6133e-06  0:00:01    1
         647  1.3430e-03  3.3956e-05  3.3457e-05  3.4527e-05  1.9585e-09  1.5352e-06  0:00:00    0
      Flow time = 0.01800000000000001s, time step = 36
      3964 more time steps
       done.
         Time = 0.153 seconds.
         Done.
         Cell count                              73723     75058     373942
         Mean cell count deviation               -1.4%     0.4%
         Partition boundary cell count           1815      3106      12076
         Partition boundary cell count ratio     2.4%      4.1%      3.2%
         Face count                              152300    155973    767102
         Mean face count deviation               -1.6%     0.8%
         Partition boundary face count           1994      3430      6705
         Partition boundary face count ratio     1.3%      2.2%      0.9%
         Cell weights                            7e+05     8e+05     4e+06
         Mean cell weight deviation              -1.4%     0.4%
      Done.
         647  1.3430e-03  3.3956e-05  3.3457e-05  3.4527e-05  1.9585e-09  1.5352e-06  0:00:21   20
         648  7.6214e-03  6.1513e-04  5.5250e-04  4.5107e-03  3.9102e-04  1.3131e-02  0:00:20   19
         649  5.9569e-03  2.1752e-04  1.9552e-04  1.1918e-03  8.6784e-05  3.6816e-03  0:00:19   18
         650  4.4940e-03  1.1376e-04  1.0356e-04  3.5655e-04  1.9844e-05  8.6555e-04  0:00:18   17
         651  3.6489e-03  8.4772e-05  7.8925e-05  1.3494e-04  4.7737e-06  2.3167e-04  0:00:16   16
         652  3.1061e-03  7.1977e-05  6.8009e-05  7.9793e-05  1.2513e-06  6.9255e-05  0:00:18   15
         653  2.6918e-03  6.3773e-05  6.0737e-05  6.7745e-05  3.7942e-07  2.5220e-05  0:00:16   14
         654  2.3937e-03  5.7899e-05  5.5443e-05  6.1293e-05  1.4324e-07  1.2181e-05  0:00:15   13
         655  2.1829e-03  5.3517e-05  5.1448e-05  5.6301e-05  6.9518e-08  7.6159e-06  0:00:13   12
         656  2.0265e-03  5.0117e-05  4.8344e-05  5.2330e-05  4.1414e-08  5.5731e-06  0:00:12   11
         657  1.9061e-03  4.7407e-05  4.5879e-05  4.9186e-05  2.7058e-08  4.4085e-06  0:00:11   10
         658  1.8110e-03  4.5192e-05  4.3841e-05  4.6666e-05  1.8939e-08  3.6414e-06  0:00:10    9
         659  1.7345e-03  4.3324e-05  4.2116e-05  4.4587e-05  1.3791e-08  3.0965e-06  0:00:08    8
         660  1.6719e-03  4.1716e-05  4.0639e-05  4.2828e-05  1.0294e-08  2.6910e-06  0:00:07    7
         661  1.6197e-03  4.0311e-05  3.9350e-05  4.1311e-05  7.8163e-09  2.3903e-06  0:00:06    6
         662  1.5753e-03  3.9077e-05  3.8205e-05  3.9989e-05  6.0106e-09  2.1502e-06  0:00:06    5
         663  1.5370e-03  3.7985e-05  3.7183e-05  3.8824e-05  4.6690e-09  1.9550e-06  0:00:05    4
         664  1.5036e-03  3.7013e-05  3.6266e-05  3.7788e-05  3.6573e-09  1.7981e-06  0:00:03    3
         665  1.4742e-03  3.6134e-05  3.5435e-05  3.6858e-05  2.8851e-09  1.6707e-06  0:00:02    2
         666  1.4480e-03  3.5332e-05  3.4685e-05  3.6014e-05  2.2899e-09  1.5660e-06  0:00:01    1
         667  1.4246e-03  3.4600e-05  3.4000e-05  3.5248e-05  1.8272e-09  1.4787e-06  0:00:00    0
      Flow time = 0.01850000000000001s, time step = 37
      3963 more time steps
       done.
         667  1.4246e-03  3.4600e-05  3.4000e-05  3.5248e-05  1.8272e-09  1.4787e-06  0:00:21   20
         668  7.9654e-03  5.3861e-04  4.9478e-04  2.1999e-03  3.9074e-04  1.2940e-02  0:00:24   19
         669  6.2791e-03  2.1136e-04  1.9402e-04  6.3980e-04  8.6777e-05  3.8560e-03  0:00:22   18
         670  4.6809e-03  1.1673e-04  1.0686e-04  2.2148e-04  1.9852e-05  9.1722e-04  0:00:20   17
         671  3.8071e-03  8.7950e-05  8.2134e-05  1.0819e-04  4.7757e-06  2.4521e-04  0:00:18   16
         672  3.2586e-03  7.4151e-05  7.0211e-05  7.9633e-05  1.2506e-06  7.2712e-05  0:00:17   15
         673  2.8323e-03  6.5074e-05  6.1966e-05  6.8643e-05  3.7816e-07  2.6206e-05  0:00:15   14
         674  2.5213e-03  5.8501e-05  5.5861e-05  6.1419e-05  1.4204e-07  1.2593e-05  0:00:14   13
         675  2.2968e-03  5.3548e-05  5.1294e-05  5.5857e-05  6.8488e-08  7.8782e-06  0:00:15   12
         676  2.1275e-03  4.9703e-05  4.7766e-05  5.1511e-05  4.0546e-08  5.9202e-06  0:00:13   11
         677  1.9950e-03  4.6635e-05  4.4953e-05  4.8069e-05  2.6344e-08  4.7328e-06  0:00:12   10
         678  1.8881e-03  4.4123e-05  4.2662e-05  4.5275e-05  1.8350e-08  3.9627e-06  0:00:10    9
         679  1.7997e-03  4.2040e-05  4.0755e-05  4.2992e-05  1.3304e-08  3.4090e-06  0:00:09    8
         680  1.7258e-03  4.0292e-05  3.9142e-05  4.1105e-05  9.8898e-09  3.0348e-06  0:00:08    7
         681  1.6633e-03  3.8799e-05  3.7766e-05  3.9526e-05  7.4802e-09  2.7074e-06  0:00:06    6
         682  1.6095e-03  3.7508e-05  3.6578e-05  3.8179e-05  5.7311e-09  2.4822e-06  0:00:05    5
         683  1.5628e-03  3.6384e-05  3.5541e-05  3.7012e-05  4.4364e-09  2.3181e-06  0:00:04    4
         684  1.5216e-03  3.5395e-05  3.4628e-05  3.5988e-05  3.4636e-09  2.1998e-06  0:00:03    3
         685  1.4851e-03  3.4519e-05  3.3813e-05  3.5081e-05  2.7238e-09  2.0340e-06  0:00:02    2
         686  1.4526e-03  3.3732e-05  3.3083e-05  3.4272e-05  2.1556e-09  1.9335e-06  0:00:01    1
         687  1.4235e-03  3.3025e-05  3.2428e-05  3.3547e-05  1.7153e-09  1.8339e-06  0:00:00    0
      Flow time = 0.01900000000000001s, time step = 38
      3962 more time steps
       done.
         687  1.4235e-03  3.3025e-05  3.2428e-05  3.3547e-05  1.7153e-09  1.8339e-06  0:00:24   20
         688  8.3116e-03  5.3236e-04  4.9937e-04  3.3020e-03  3.9047e-04  1.2700e-02  0:00:25   19
         689  6.4507e-03  2.2501e-04  2.1097e-04  9.4916e-04  8.6772e-05  3.5852e-03  0:00:23   18
         690  4.6725e-03  1.2626e-04  1.1697e-04  3.0865e-04  1.9860e-05  8.5006e-04  0:00:21   17
         691  3.7161e-03  9.4458e-05  8.8703e-05  1.3515e-04  4.7776e-06  2.2984e-04  0:00:19   16
         692  3.1279e-03  7.8059e-05  7.4474e-05  8.7811e-05  1.2498e-06  6.9082e-05  0:00:17   15
         693  2.6815e-03  6.6956e-05  6.4403e-05  7.1842e-05  3.7689e-07  2.4960e-05  0:00:16   14
         694  2.3601e-03  5.9188e-05  5.7064e-05  6.2818e-05  1.4086e-07  1.1833e-05  0:00:14   13
         695  2.1324e-03  5.3532e-05  5.1723e-05  5.6357e-05  6.7491e-08  7.2675e-06  0:00:15   12
         696  1.9624e-03  4.9302e-05  4.7714e-05  5.1478e-05  3.9717e-08  5.2544e-06  0:00:13   11
         697  1.8312e-03  4.5983e-05  4.4609e-05  4.7720e-05  2.5672e-08  4.1255e-06  0:00:12   10
         698  1.7275e-03  4.3334e-05  4.2145e-05  4.4783e-05  1.7802e-08  3.3862e-06  0:00:10    9
         699  1.6435e-03  4.1101e-05  4.0061e-05  4.2398e-05  1.2854e-08  2.8639e-06  0:00:09    8
         700  1.5740e-03  3.9160e-05  3.8337e-05  4.0336e-05  9.5198e-09  2.4796e-06  0:00:08    7
         701  1.5150e-03  3.7589e-05  3.6857e-05  3.8665e-05  7.1746e-09  2.1845e-06  0:00:08    6
         702  1.4647e-03  3.6188e-05  3.5557e-05  3.7214e-05  5.4782e-09  1.9525e-06  0:00:06    5
         703  1.4208e-03  3.4959e-05  3.4432e-05  3.5928e-05  4.2265e-09  1.7801e-06  0:00:05    4
         704  1.3823e-03  3.3882e-05  3.3412e-05  3.4805e-05  3.2890e-09  1.6400e-06  0:00:03    3
         705  1.3482e-03  3.2908e-05  3.2514e-05  3.3796e-05  2.5778e-09  1.5236e-06  0:00:02    2
         706  1.3178e-03  3.2001e-05  3.1694e-05  3.2832e-05  2.0336e-09  1.4267e-06  0:00:01    1
         707  1.2902e-03  3.1255e-05  3.0940e-05  3.2075e-05  1.6130e-09  1.3451e-06  0:00:00    0
      Flow time = 0.01950000000000001s, time step = 39
      3961 more time steps
       done.
         707  1.2902e-03  3.1255e-05  3.0940e-05  3.2075e-05  1.6130e-09  1.3451e-06  0:00:21   20
         708  8.5655e-03  5.9899e-04  5.3648e-04  6.3115e-03  3.9020e-04  1.2942e-02  0:00:20   19
         709  6.4838e-03  2.4995e-04  2.2740e-04  1.7667e-03  8.6767e-05  5.0121e-02  0:00:22   18
         710  4.5591e-03  1.3354e-04  1.2300e-04  5.2621e-04  1.9868e-05  1.8696e-02  0:00:20   17
         711  3.5749e-03  9.8240e-05  9.3071e-05  1.9208e-04  4.7794e-06  6.5760e-03  0:00:19   16
         712  2.9669e-03  8.0743e-05  7.7413e-05  1.0075e-04  1.2491e-06  2.1587e-03  0:00:17   15
         713  2.4935e-03  6.8833e-05  6.6341e-05  7.6725e-05  3.7568e-07  6.4143e-04  0:00:15   14
         714  2.1538e-03  6.0358e-05  5.8274e-05  6.5823e-05  1.3975e-07  1.7369e-04  0:00:17   13
         715  1.9157e-03  5.4131e-05  5.2308e-05  5.8278e-05  6.6559e-08  5.0686e-05  0:00:15   12
         716  1.7403e-03  4.9410e-05  4.7769e-05  5.2551e-05  3.8946e-08  1.9570e-05  0:00:13   11
         717  1.6060e-03  4.5686e-05  4.4215e-05  4.8144e-05  2.5959e-08  1.4623e-05  0:00:11   10
         718  1.5007e-03  4.2650e-05  4.1336e-05  4.4617e-05  1.7934e-08  1.1433e-05  0:00:10    9
         719  1.4171e-03  4.0124e-05  3.8936e-05  4.1742e-05  1.2898e-08  9.9355e-06  0:00:09    8
         720  1.3483e-03  3.7987e-05  3.6900e-05  3.9364e-05  9.5136e-09  1.0464e-05  0:00:08    7
         721  1.2908e-03  3.6156e-05  3.5153e-05  3.7343e-05  7.1418e-09  1.0771e-05  0:00:08    6
         722  1.2420e-03  3.4569e-05  3.3648e-05  3.5604e-05  5.4324e-09  9.2889e-06  0:00:06    5
         723  1.1996e-03  3.3176e-05  3.2334e-05  3.4116e-05  4.1759e-09  8.9408e-06  0:00:05    4
         724  1.1624e-03  3.1942e-05  3.1173e-05  3.2811e-05  3.2382e-09  9.0028e-06  0:00:03    3
         725  1.1300e-03  3.0851e-05  3.0142e-05  3.1653e-05  2.5298e-09  8.9198e-06  0:00:02    2
         726  1.1012e-03  2.9873e-05  2.9221e-05  3.0615e-05  1.9891e-09  8.6405e-06  0:00:01    1
         727  1.0754e-03  2.8992e-05  2.8391e-05  2.9683e-05  1.5729e-09  8.3074e-06  0:00:00    0
      Flow time = 0.02000000000000001s, time step = 40
      3960 more time steps
       done.
         727  1.0754e-03  2.8992e-05  2.8391e-05  2.9683e-05  1.5729e-09  8.3074e-06  0:00:25   20
         728  8.5697e-03  8.1286e-04  7.4310e-04  9.0916e-03  3.8996e-04  1.2178e-02  0:00:23   19
         729  6.4193e-03  3.0346e-04  2.7801e-04  2.5267e-03  8.6764e-05  3.4809e-03  0:00:21   18
         730  4.4774e-03  1.4983e-04  1.3706e-04  7.2741e-04  1.9875e-05  8.2157e-04  0:00:23   17
         731  3.4614e-03  1.0468e-04  9.7499e-05  2.4576e-04  4.7810e-06  2.2341e-04  0:00:20   16
         732  2.8387e-03  8.4490e-05  7.9594e-05  1.1497e-04  1.2484e-06  6.8249e-05  0:00:18   15
         733  2.3529e-03  7.1081e-05  6.7479e-05  8.0308e-05  3.7448e-07  2.5555e-05  0:00:16   14
         734  1.9995e-03  6.1532e-05  5.8582e-05  6.7136e-05  1.3864e-07  1.2720e-05  0:00:15   13
         735  1.7501e-03  5.4314e-05  5.1896e-05  5.8568e-05  6.5634e-08  8.1986e-06  0:00:16   12
         736  1.5634e-03  4.8730e-05  4.6690e-05  5.2023e-05  3.8182e-08  6.1712e-06  0:00:14   11
         737  1.4186e-03  4.4356e-05  4.2590e-05  4.6978e-05  2.5324e-08  5.0227e-06  0:00:12   10
         738  1.3029e-03  4.0801e-05  3.9285e-05  4.2973e-05  1.7419e-08  4.2493e-06  0:00:10    9
         739  1.2090e-03  3.7853e-05  3.6552e-05  3.9687e-05  1.2479e-08  3.6887e-06  0:00:09    8
         740  1.1315e-03  3.5382e-05  3.4253e-05  3.6959e-05  9.1709e-09  3.2890e-06  0:00:08    7
         741  1.0662e-03  3.3268e-05  3.2301e-05  3.4651e-05  6.8610e-09  2.9881e-06  0:00:08    6
         742  1.0109e-03  3.1453e-05  3.0615e-05  3.2670e-05  5.2019e-09  2.7453e-06  0:00:06    5
         743  9.6336e-04  2.9878e-05  2.9137e-05  3.0952e-05  3.9864e-09  2.5451e-06  0:00:05    4
      !  743 solution is converged
      Flow time = 0.02050000000000001s, time step = 41
      3959 more time steps
      (cx-use-window-id 1)
       done.
      >> Dividing domain into 5 partitions using Metis.
         Time = 0.163 seconds.
         Done.
      >> 5 Stored Partitions:
         Collective Partition Statistics:        Minimum   Maximum   Total
         Cell count                              77405     78681     392069
         Mean cell count deviation               -1.3%     0.3%
         Partition boundary cell count           1863      3169      12574
         Partition boundary cell count ratio     2.4%      4.0%      3.2%
         Face count                              159670    163193    803356
         Mean face count deviation               -1.5%     0.7%
         Partition boundary face count           2022      3493      6899
         Partition boundary face count ratio     1.2%      2.1%      0.9%
         Cell weights                            8e+05     8e+05     4e+06
         Mean cell weight deviation              -1.3%     0.3%
         Partition Method                        Metis
         Stored Partition Count                  5
      Done.
         743  9.6336e-04  2.9878e-05  2.9137e-05  3.0952e-05  3.9864e-09  2.5451e-06  0:00:24   20
         744  8.1001e-03  9.3353e-04  8.8151e-04  1.1130e-02  3.8973e-04  1.1819e-02  0:00:22   19
         745  5.9270e-03  3.3014e-04  3.0737e-04  3.0952e-03  8.6761e-05  3.4577e-03  0:00:20   18
         746  4.1336e-03  1.5455e-04  1.4327e-04  8.7633e-04  1.9882e-05  8.0900e-04  0:00:22   17
         747  3.1008e-03  1.0453e-04  9.8362e-05  2.8348e-04  4.7823e-06  2.1853e-04  0:00:20   16
         748  2.4613e-03  8.3017e-05  7.8714e-05  1.2433e-04  1.2473e-06  6.6142e-05  0:00:18   15
         749  1.9836e-03  6.8855e-05  6.5346e-05  8.0483e-05  3.7309e-07  2.4403e-05  0:00:16   14
         750  1.6370e-03  5.8512e-05  5.5518e-05  6.4692e-05  1.3741e-07  1.1913e-05  0:00:15   13
         751  1.3898e-03  5.0753e-05  4.8173e-05  5.5200e-05  6.4618e-08  7.4993e-06  0:00:13   12
         752  1.2048e-03  4.4807e-05  4.2553e-05  4.8119e-05  3.7349e-08  5.5104e-06  0:00:12   11
         753  1.0609e-03  4.0129e-05  3.8138e-05  4.2639e-05  2.4637e-08  4.3767e-06  0:00:13   10
         754  9.4737e-04  3.6371e-05  3.4606e-05  3.8320e-05  1.6865e-08  3.6276e-06  0:00:11    9
      !  754 solution is converged
      Flow time = 0.02100000000000002s, time step = 42
      3958 more time steps
       done.
         754  9.4737e-04  3.6371e-05  3.4606e-05  3.8320e-05  1.6865e-08  3.6276e-06  0:00:24   20
         755  7.9482e-03  9.6096e-04  9.0552e-04  1.2531e-02  3.8951e-04  1.1733e-02  0:00:22   19
         756  5.7897e-03  3.3016e-04  3.0677e-04  3.3999e-03  8.6759e-05  3.4441e-03  0:00:24   18
         757  3.9894e-03  1.5018e-04  1.3753e-04  9.3395e-04  1.9888e-05  8.0842e-04  0:00:22   17
         758  3.0128e-03  1.0142e-04  9.3534e-05  2.9557e-04  4.7825e-06  2.2238e-04  0:00:19   16
         759  2.4010e-03  8.1498e-05  7.5883e-05  1.2602e-04  1.2456e-06  6.9192e-05  0:00:18   15
         760  1.9219e-03  6.8727e-05  6.4434e-05  8.0755e-05  3.7121e-07  2.6741e-05  0:00:16   14
         761  1.5757e-03  5.9428e-05  5.6007e-05  6.5917e-05  1.3580e-07  1.4033e-05  0:00:14   13
         762  1.3359e-03  5.2418e-05  4.9629e-05  5.7380e-05  6.3320e-08  9.6126e-06  0:00:13   12
         763  1.1623e-03  4.6979e-05  4.4680e-05  5.0935e-05  3.6303e-08  7.7180e-06  0:00:14   11
         764  1.0309e-03  4.2670e-05  4.0739e-05  4.5901e-05  2.3788e-08  6.7461e-06  0:00:12   10
         765  9.2788e-04  3.9178e-05  3.7547e-05  4.1880e-05  1.6192e-08  6.1458e-06  0:00:11    9
      !  765 solution is converged
      Flow time = 0.02150000000000002s, time step = 43
      3957 more time steps
       done.
         765  9.2788e-04  3.9178e-05  3.7547e-05  4.1880e-05  1.6192e-08  6.1458e-06  0:00:23   20
         766  8.5159e-03  9.1145e-04  8.3352e-04  1.2632e-02  3.8930e-04  1.1469e-02  0:00:22   19
         767  6.3976e-03  2.9949e-04  2.7346e-04  3.1078e-03  8.6759e-05  4.3590e-03  0:00:24   18
         768  4.4550e-03  1.4483e-04  1.3182e-04  8.5492e-04  1.9895e-05  1.1617e-03  0:00:21   17
         769  3.4180e-03  1.0205e-04  9.4361e-05  2.7574e-04  4.7838e-06  3.2154e-04  0:00:19   16
         770  2.7785e-03  8.3121e-05  7.7719e-05  1.2118e-04  1.2447e-06  9.2469e-05  0:00:17   15
         771  2.2764e-03  7.0774e-05  6.6636e-05  8.0940e-05  3.6998e-07  3.0809e-05  0:00:16   14
         772  1.9113e-03  6.1945e-05  5.8567e-05  6.8190e-05  1.3474e-07  1.3780e-05  0:00:14   13
         773  1.6552e-03  5.5322e-05  5.2513e-05  6.0282e-05  6.2462e-08  8.4627e-06  0:00:15   12
         774  1.4670e-03  5.0190e-05  4.7804e-05  5.4169e-05  3.5619e-08  6.2480e-06  0:00:13   11
         775  1.3219e-03  4.6092e-05  4.4019e-05  4.9301e-05  2.3238e-08  5.1109e-06  0:00:12   10
         776  1.2070e-03  4.2731e-05  4.0921e-05  4.5374e-05  1.5760e-08  4.2187e-06  0:00:10    9
         777  1.1140e-03  3.9898e-05  3.8333e-05  4.2114e-05  1.1152e-08  3.7215e-06  0:00:09    8
         778  1.0368e-03  3.7463e-05  3.6117e-05  3.9370e-05  8.1053e-09  3.2798e-06  0:00:08    7
         779  9.7170e-04  3.5330e-05  3.4190e-05  3.7020e-05  6.0018e-09  2.9237e-06  0:00:08    6
      !  779 solution is converged
      Flow time = 0.02200000000000002s, time step = 44
      3956 more time steps
       done.
         779  9.7170e-04  3.5330e-05  3.4190e-05  3.7020e-05  6.0018e-09  2.9237e-06  0:00:25   20
         780  8.9407e-03  7.9588e-04  7.2605e-04  1.0668e-02  3.8911e-04  1.1268e-02  0:00:27   19
         781  6.8196e-03  2.7394e-04  2.4979e-04  2.6535e-03  8.6763e-05  3.3117e-03  0:00:24   18
         782  4.8254e-03  1.3609e-04  1.2530e-04  7.3707e-04  1.9904e-05  7.8333e-04  0:00:22   17
         783  3.7620e-03  9.7054e-05  9.1279e-05  2.4273e-04  4.7861e-06  2.1599e-04  0:00:19   16
         784  3.1033e-03  7.9253e-05  7.5593e-05  1.0979e-04  1.2447e-06  6.6714e-05  0:00:18   15
         785  2.5898e-03  6.7714e-05  6.4841e-05  7.6399e-05  3.6947e-07  2.4919e-05  0:00:19   14
         786  2.2213e-03  5.9552e-05  5.7043e-05  6.5282e-05  1.3423e-07  1.2239e-05  0:00:17   13
         787  1.9644e-03  5.3507e-05  5.1306e-05  5.8020e-05  6.2050e-08  7.7680e-06  0:00:15   12
         788  1.7752e-03  4.8900e-05  4.6967e-05  5.2432e-05  3.5287e-08  5.7809e-06  0:00:13   11
         789  1.6287e-03  4.5254e-05  4.3554e-05  4.8055e-05  2.2968e-08  4.6828e-06  0:00:11   10
         790  1.5125e-03  4.2272e-05  4.0771e-05  4.4558e-05  1.5543e-08  3.9644e-06  0:00:12    9
         791  1.4180e-03  3.9787e-05  3.8448e-05  4.1678e-05  1.0976e-08  3.4602e-06  0:00:10    8
         792  1.3398e-03  3.7678e-05  3.6456e-05  3.9268e-05  7.9627e-09  3.0884e-06  0:00:08    7
         793  1.2736e-03  3.5845e-05  3.4733e-05  3.7210e-05  5.8859e-09  2.8022e-06  0:00:07    6
         794  1.2170e-03  3.4239e-05  3.3228e-05  3.5434e-05  4.4145e-09  2.5709e-06  0:00:06    5
         795  1.1679e-03  3.2926e-05  3.1893e-05  3.3877e-05  3.3481e-09  2.3845e-06  0:00:05    4
         796  1.1251e-03  3.1694e-05  3.0723e-05  3.2544e-05  2.5620e-09  2.2298e-06  0:00:04    3
         797  1.0866e-03  3.0437e-05  2.9628e-05  3.1249e-05  1.9776e-09  2.1008e-06  0:00:02    2
         798  1.0527e-03  2.9372e-05  2.8617e-05  3.0099e-05  1.5376e-09  1.9911e-06  0:00:01    1
         799  1.0220e-03  2.8404e-05  2.7698e-05  2.9069e-05  1.2033e-09  1.8975e-06  0:00:00    0
      Flow time = 0.02250000000000002s, time step = 45
      3955 more time steps
       done.
         799  1.0220e-03  2.8404e-05  2.7698e-05  2.9069e-05  1.2033e-09  1.8975e-06  0:00:22   20
         800  9.5739e-03  8.9385e-04  7.9158e-04  7.9848e-03  3.8894e-04  1.1114e-02  0:00:25   19
         801  7.3593e-03  2.9586e-04  2.6550e-04  2.0290e-03  8.6768e-05  5.1584e-03  0:00:22   18
         802  5.2876e-03  1.3927e-04  1.2558e-04  5.7939e-04  1.9912e-05  1.3623e-03  0:00:20   17
         803  4.1842e-03  9.6331e-05  8.8804e-05  2.0014e-04  4.7881e-06  3.7958e-04  0:00:18   16
         804  3.4959e-03  7.8455e-05  7.3456e-05  9.8013e-05  1.2444e-06  1.0774e-04  0:00:17   15
         805  2.9576e-03  6.7199e-05  6.3376e-05  7.3121e-05  3.6877e-07  3.2392e-05  0:00:18   14
         806  2.5643e-03  5.9230e-05  5.6154e-05  6.3709e-05  1.3358e-07  1.7420e-05  0:00:16   13
         807  2.2861e-03  5.3369e-05  5.0796e-05  5.7161e-05  6.1519e-08  1.3874e-05  0:00:14   12
         808  2.0809e-03  4.8890e-05  4.6710e-05  5.2030e-05  3.4859e-08  1.2698e-05  0:00:13   11
         809  1.9189e-03  4.5377e-05  4.3507e-05  4.8086e-05  2.2619e-08  1.1937e-05  0:00:13   10
         810  1.7924e-03  4.2561e-05  4.0944e-05  4.4953e-05  1.5265e-08  1.1890e-05  0:00:11    9
         811  1.6874e-03  4.0231e-05  3.8806e-05  4.2364e-05  1.0753e-08  1.1467e-05  0:00:10    8
         812  1.5999e-03  3.8282e-05  3.7003e-05  4.0222e-05  7.7828e-09  1.0874e-05  0:00:08    7
         813  1.5291e-03  3.6610e-05  3.5446e-05  3.8448e-05  5.7411e-09  1.0465e-05  0:00:07    6
         814  1.4632e-03  3.5179e-05  3.4091e-05  3.6814e-05  4.2958e-09  1.0193e-05  0:00:07    5
         815  1.4093e-03  3.3892e-05  3.2891e-05  3.5536e-05  3.2517e-09  1.0486e-05  0:00:05    4
         816  1.3644e-03  3.2769e-05  3.1840e-05  3.4270e-05  2.4855e-09  1.0934e-05  0:00:04    3
         817  1.3172e-03  3.1736e-05  3.0867e-05  3.3179e-05  1.9160e-09  1.0247e-05  0:00:02    2
         818  1.2791e-03  3.0806e-05  3.0000e-05  3.2205e-05  1.4879e-09  1.0008e-05  0:00:01    1
         819  1.2484e-03  2.9943e-05  2.9194e-05  3.1329e-05  1.1633e-09  9.9112e-06  0:00:00    0
      Flow time = 0.02300000000000002s, time step = 46
      3954 more time steps
       done.
      Updating mesh at time level N... (cx-use-window-id 1)
      done.
         819  1.2484e-03  2.9943e-05  2.9194e-05  3.1329e-05  1.1633e-09  9.9112e-06  0:00:26   20
         820  9.5145e-03  7.0040e-04  6.2854e-04  5.1968e-03  3.8878e-04  1.0790e-02  0:00:27   19
         821  7.4785e-03  2.4420e-04  2.2035e-04  1.3661e-03  8.6774e-05  3.2062e-03  0:00:24   18
         822  5.4313e-03  1.2161e-04  1.1129e-04  4.0886e-04  1.9919e-05  7.5540e-04  0:00:22   17
         823  4.3034e-03  8.7826e-05  8.2111e-05  1.5352e-04  4.7894e-06  2.0892e-04  0:00:20   16
         824  3.5918e-03  7.3502e-05  6.9679e-05  8.4883e-05  1.2436e-06  6.4822e-05  0:00:18   15
         825  3.0410e-03  6.4165e-05  6.1204e-05  6.8844e-05  3.6767e-07  2.4474e-05  0:00:16   14
         826  2.6436e-03  5.7336e-05  5.4898e-05  6.1157e-05  1.3263e-07  1.2202e-05  0:00:14   13
         827  2.3623e-03  5.2121e-05  5.0094e-05  5.5237e-05  6.0745e-08  7.8170e-06  0:00:16   12
         828  2.1538e-03  4.8024e-05  4.6338e-05  5.0508e-05  3.4235e-08  5.8354e-06  0:00:14   11
         829  1.9913e-03  4.4741e-05  4.3331e-05  4.6739e-05  2.2111e-08  4.7137e-06  0:00:12   10
         830  1.8608e-03  4.2050e-05  4.0878e-05  4.3691e-05  1.4862e-08  3.9683e-06  0:00:10    9
         831  1.7551e-03  3.9800e-05  3.8815e-05  4.1173e-05  1.0431e-08  3.4343e-06  0:00:09    8
         832  1.6670e-03  3.7895e-05  3.7058e-05  3.9049e-05  7.5250e-09  3.0326e-06  0:00:09    7
         833  1.5927e-03  3.6257e-05  3.5531e-05  3.7252e-05  5.5342e-09  2.7232e-06  0:00:07    6
         834  1.5290e-03  3.4837e-05  3.4190e-05  3.5714e-05  4.1294e-09  2.4805e-06  0:00:06    5
         835  1.4738e-03  3.3593e-05  3.3010e-05  3.4373e-05  3.1178e-09  2.2872e-06  0:00:05    4
         836  1.4255e-03  3.2498e-05  3.1971e-05  3.3196e-05  2.3776e-09  2.1297e-06  0:00:04    3
         837  1.3831e-03  3.1528e-05  3.1044e-05  3.2163e-05  1.8291e-09  2.0009e-06  0:00:02    2
         838  1.3453e-03  3.0660e-05  3.0211e-05  3.1243e-05  1.4180e-09  1.8941e-06  0:00:01    1
         839  1.3115e-03  2.9879e-05  2.9454e-05  3.0416e-05  1.1071e-09  1.8039e-06  0:00:00    0
      Flow time = 0.02350000000000002s, time step = 47
      3953 more time steps
       done.
         Time = 0.168 seconds.
         Done.
         Cell count                              80414     80450     402142
         Mean cell count deviation               -0.0%     0.0%
         Partition boundary cell count           1843      3289      12131
         Partition boundary cell count ratio     2.3%      4.1%      3.0%
         Face count                              165381    166622    823502
         Mean face count deviation               -0.4%     0.4%
         Partition boundary face count           1981      3643      6666
         Mean cell weight deviation              -0.0%     0.0%
      Done.
         839  1.3115e-03  2.9879e-05  2.9454e-05  3.0416e-05  1.1071e-09  1.8039e-06  0:00:23   20
         840  9.8515e-03  6.2315e-04  5.6164e-04  2.8030e-03  3.8863e-04  1.0581e-02  0:00:25   19
         841  7.5484e-03  2.2068e-04  1.9841e-04  7.7817e-04  8.6781e-05  3.1429e-03  0:00:23   18
         842  5.5375e-03  1.1238e-04  1.0212e-04  2.5739e-04  1.9927e-05  7.3973e-04  0:00:20   17
         843  4.3717e-03  8.1400e-05  7.5599e-05  1.1348e-04  4.7906e-06  2.0326e-04  0:00:22   16
         844  3.6489e-03  6.7962e-05  6.4053e-05  7.4783e-05  1.2428e-06  6.2489e-05  0:00:19   15
         845  3.1045e-03  5.9349e-05  5.6386e-05  6.3459e-05  3.6653e-07  2.3262e-05  0:00:17   14
         846  2.7082e-03  5.3079e-05  5.0684e-05  5.6439e-05  1.3163e-07  1.1346e-05  0:00:15   13
         847  2.4251e-03  4.8334e-05  4.6322e-05  5.0982e-05  5.9939e-08  7.0512e-06  0:00:14   12
         848  2.2127e-03  4.4688e-05  4.2943e-05  4.6689e-05  3.3585e-08  5.0837e-06  0:00:12   11
         849  2.0466e-03  4.1809e-05  4.0279e-05  4.3341e-05  2.1582e-08  3.9656e-06  0:00:13   10
         850  1.9137e-03  3.9465e-05  3.8127e-05  4.0700e-05  1.4442e-08  3.2218e-06  0:00:11    9
         851  1.8055e-03  3.7524e-05  3.6345e-05  3.8556e-05  1.0095e-08  2.6923e-06  0:00:10    8
         852  1.7154e-03  3.5885e-05  3.4845e-05  3.6781e-05  7.2555e-09  2.2956e-06  0:00:08    7
         853  1.6393e-03  3.4476e-05  3.3560e-05  3.5275e-05  5.3170e-09  1.9916e-06  0:00:07    6
         854  1.5740e-03  3.3249e-05  3.2440e-05  3.3979e-05  3.9544e-09  1.7545e-06  0:00:05    5
         855  1.5174e-03  3.2163e-05  3.1449e-05  3.2842e-05  2.9765e-09  1.5644e-06  0:00:05    4
         856  1.4678e-03  3.1195e-05  3.0565e-05  3.1829e-05  2.2636e-09  1.4108e-06  0:00:04    3
         857  1.4244e-03  3.0331e-05  2.9770e-05  3.0919e-05  1.7369e-09  1.2813e-06  0:00:02    2
         858  1.3860e-03  2.9552e-05  2.9050e-05  3.0100e-05  1.3435e-09  1.1733e-06  0:00:01    1
         859  1.3516e-03  2.8850e-05  2.8390e-05  2.9362e-05  1.0469e-09  1.0831e-06  0:00:00    0
      Flow time = 0.02400000000000002s, time step = 48
      3952 more time steps
       done.
         859  1.3516e-03  2.8850e-05  2.8390e-05  2.9362e-05  1.0469e-09  1.0831e-06  0:00:22   20
         860  1.0507e-02  6.3528e-04  5.6332e-04  1.5922e-03  3.8850e-04  1.0457e-02  0:00:25   19
         861  7.8188e-03  2.4142e-04  2.1877e-04  4.9968e-04  8.6790e-05  3.1580e-03  0:00:22   18
         862  5.6178e-03  1.2760e-04  1.1638e-04  1.9835e-04  1.9934e-05  7.4355e-04  0:00:20   17
         863  4.4291e-03  9.2689e-05  8.6049e-05  1.1080e-04  4.7916e-06  2.0509e-04  0:00:22   16
         864  3.6893e-03  7.6740e-05  7.2112e-05  8.3488e-05  1.2418e-06  6.3186e-05  0:00:19   15
         865  3.1165e-03  6.6603e-05  6.2964e-05  7.1385e-05  3.6531e-07  2.3405e-05  0:00:17   14
         866  2.6992e-03  5.9446e-05  5.6355e-05  6.3175e-05  1.3059e-07  1.1338e-05  0:00:15   13
         867  2.4044e-03  5.4099e-05  5.1392e-05  5.6916e-05  5.9120e-08  7.0452e-06  0:00:14   12
         868  2.1847e-03  4.9887e-05  4.7565e-05  5.1992e-05  3.2942e-08  5.1201e-06  0:00:12   11
         869  2.0145e-03  4.6461e-05  4.4539e-05  4.8100e-05  2.1074e-08  4.0180e-06  0:00:13   10
         870  1.8790e-03  4.3605e-05  4.2011e-05  4.4962e-05  1.4051e-08  3.2840e-06  0:00:11    9
         871  1.7687e-03  4.1183e-05  3.9871e-05  4.2357e-05  9.7936e-09  2.7603e-06  0:00:09    8
         872  1.6761e-03  3.9119e-05  3.8018e-05  4.0170e-05  7.0217e-09  2.3694e-06  0:00:08    7
         873  1.5974e-03  3.7328e-05  3.6392e-05  3.8288e-05  5.1353e-09  2.0696e-06  0:00:07    6
         874  1.5297e-03  3.5767e-05  3.4950e-05  3.6653e-05  3.8130e-09  1.8343e-06  0:00:06    5
         875  1.4709e-03  3.4385e-05  3.3666e-05  3.5220e-05  2.8663e-09  1.6460e-06  0:00:05    4
         876  1.4190e-03  3.3156e-05  3.2505e-05  3.3938e-05  2.1775e-09  1.4921e-06  0:00:04    3
         877  1.3728e-03  3.2039e-05  3.1446e-05  3.2779e-05  1.6696e-09  1.3641e-06  0:00:02    2
         878  1.3314e-03  3.1014e-05  3.0477e-05  3.1718e-05  1.2909e-09  1.2573e-06  0:00:01    1
         879  1.2942e-03  3.0084e-05  2.9593e-05  3.0746e-05  1.0056e-09  1.1665e-06  0:00:00    0
      Flow time = 0.02450000000000002s, time step = 49
      3951 more time steps
       done.
         879  1.2942e-03  3.0084e-05  2.9593e-05  3.0746e-05  1.0056e-09  1.1665e-06  0:00:26   20
         880  1.0363e-02  5.5498e-04  4.9287e-04  2.9771e-03  3.8837e-04  1.0214e-02  0:00:24   19
         881  7.8689e-03  2.1548e-04  1.9487e-04  8.5541e-04  8.6799e-05  3.1007e-03  0:00:25   18
         882  5.5935e-03  1.1703e-04  1.0655e-04  2.8395e-04  1.9941e-05  7.2065e-04  0:00:22   17
         883  4.3821e-03  8.6575e-05  8.0633e-05  1.2559e-04  4.7926e-06  1.9993e-04  0:00:20   16
         884  3.6196e-03  7.1991e-05  6.8023e-05  8.1617e-05  1.2409e-06  6.2624e-05  0:00:18   15
         885  3.0210e-03  6.2300e-05  5.9279e-05  6.7136e-05  3.6423e-07  2.4066e-05  0:00:16   14
         886  2.5870e-03  5.5211e-05  5.2833e-05  5.8868e-05  1.2969e-07  1.2256e-05  0:00:17   13
         887  2.2766e-03  4.9876e-05  4.7906e-05  5.2738e-05  5.8409e-08  7.9804e-06  0:00:15   12
         888  2.0448e-03  4.5728e-05  4.4075e-05  4.7993e-05  3.2382e-08  6.0321e-06  0:00:13   11
         889  1.8639e-03  4.2435e-05  4.1021e-05  4.4268e-05  2.0628e-08  4.9107e-06  0:00:12   10
         890  1.7198e-03  3.9752e-05  3.8527e-05  4.1282e-05  1.3703e-08  4.1601e-06  0:00:10    9
         891  1.6027e-03  3.7504e-05  3.6426e-05  3.8821e-05  9.5201e-09  3.6286e-06  0:00:10    8
         892  1.5060e-03  3.5595e-05  3.4624e-05  3.6743e-05  6.8054e-09  3.2415e-06  0:00:09    7
         893  1.4249e-03  3.3947e-05  3.3066e-05  3.4969e-05  4.9636e-09  2.9417e-06  0:00:07    6
         894  1.3559e-03  3.2502e-05  3.1699e-05  3.3424e-05  3.6761e-09  2.7002e-06  0:00:06    5
         895  1.2967e-03  3.1217e-05  3.0487e-05  3.2066e-05  2.7568e-09  2.5110e-06  0:00:05    4
         896  1.2453e-03  3.0066e-05  2.9417e-05  3.0860e-05  2.0897e-09  2.3552e-06  0:00:04    3
         897  1.2002e-03  2.9027e-05  2.8454e-05  2.9784e-05  1.5990e-09  2.2240e-06  0:00:02    2
         898  1.1603e-03  2.8075e-05  2.7585e-05  2.8800e-05  1.2339e-09  2.1131e-06  0:00:01    1
         899  1.1247e-03  2.7202e-05  2.6790e-05  2.7909e-05  9.5964e-10  2.0196e-06  0:00:00    0
      (update-animation-object "animation-3")
      Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-3.cxa
      (update-animation-object "animation-2")
      Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-2.cxa
      (update-animation-object "animation-1")
      Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-1.cxa
      Flow time = 0.02500000000000002s, time step = 50
      3950 more time steps
       done.
         899  1.1247e-03  2.7202e-05  2.6790e-05  2.7909e-05  9.5964e-10  2.0196e-06  0:00:23   20
         900  1.0683e-02  6.3609e-04  5.6429e-04  5.0837e-03  3.8826e-04  1.0046e-02  0:00:25   19
         901  7.9097e-03  2.4297e-04  2.1703e-04  1.4170e-03  8.6810e-05  3.0236e-03  0:00:26   18
         902  5.5127e-03  1.2500e-04  1.1338e-04  4.3256e-04  1.9948e-05  7.1298e-04  0:00:23   17
         903  4.2027e-03  9.0219e-05  8.3843e-05  1.6445e-04  4.7935e-06  1.9824e-04  0:00:21   16
         904  3.3874e-03  7.4054e-05  6.9651e-05  8.9673e-05  1.2399e-06  6.2148e-05  0:00:18   15
         905  2.7653e-03  6.3139e-05  5.9599e-05  6.8568e-05  3.6306e-07  2.3957e-05  0:00:17   14
         906  2.3143e-03  5.5053e-05  5.2103e-05  5.8674e-05  1.2871e-07  1.2294e-05  0:00:15   13
         907  1.9947e-03  4.8851e-05  4.6390e-05  5.1609e-05  5.7634e-08  8.0727e-06  0:00:16   12
         908  1.7584e-03  4.3988e-05  4.1955e-05  4.6115e-05  3.1774e-08  6.1307e-06  0:00:14   11
         909  1.5765e-03  4.0133e-05  3.8426e-05  4.1815e-05  2.0146e-08  5.0386e-06  0:00:12   10
         910  1.4339e-03  3.7012e-05  3.5552e-05  3.8406e-05  1.3331e-08  4.2984e-06  0:00:10    9
         911  1.3201e-03  3.4428e-05  3.3166e-05  3.5613e-05  9.2307e-09  3.7582e-06  0:00:09    8
         912  1.2274e-03  3.2245e-05  3.1158e-05  3.3281e-05  6.5795e-09  3.3504e-06  0:00:08    7
         913  1.1511e-03  3.0387e-05  2.9444e-05  3.1306e-05  4.7869e-09  3.0395e-06  0:00:06    6
         914  1.0878e-03  2.8789e-05  2.7976e-05  2.9616e-05  3.5378e-09  2.7947e-06  0:00:06    5
         915  1.0345e-03  2.7402e-05  2.6703e-05  2.8161e-05  2.6485e-09  2.6006e-06  0:00:05    4
         916  9.8931e-04  2.6187e-05  2.5588e-05  2.6896e-05  2.0050e-09  2.4516e-06  0:00:04    3
      !  916 solution is converged
      Flow time = 0.02550000000000002s, time step = 51
      3949 more time steps
      (cx-set-camera-relative '(0.0242794 -0.0108583 -0.0440158) '(0 0 0) '(0.170573 -0.0395451 0.103049) 0 0)
      (cx-set-camera-relative '(0.0188594 0.00197589 -0.0519243) '(0 0 0) '(0.178125 -0.0379114 0.0632562) 0 0)
       done.
         916  9.8931e-04  2.6187e-05  2.5588e-05  2.6896e-05  2.0050e-09  2.4516e-06  0:00:23   20
         917  1.0686e-02  7.1218e-04  6.3453e-04  6.5392e-03  3.8816e-04  9.8942e-03  0:00:25   19
         918  7.7671e-03  2.5961e-04  2.3352e-04  1.8118e-03  8.6822e-05  3.0608e-03  0:00:23   18
         919  5.3280e-03  1.2821e-04  1.1516e-04  5.3601e-04  1.9955e-05  7.1594e-04  0:00:21   17
         920  4.0357e-03  8.9447e-05  8.1392e-05  1.9142e-04  4.7940e-06  1.9955e-04  0:00:19   16
         921  3.2399e-03  7.1852e-05  6.6154e-05  9.5016e-05  1.2386e-06  6.2865e-05  0:00:20   15
         922  2.6163e-03  6.0311e-05  5.5970e-05  6.7594e-05  3.6170e-07  2.4362e-05  0:00:18   14
         923  2.1627e-03  5.1985e-05  4.8604e-05  5.6523e-05  1.2761e-07  1.2559e-05  0:00:16   13
         924  1.8423e-03  4.5800e-05  4.3059e-05  4.9166e-05  5.6786e-08  8.3005e-06  0:00:14   12
         925  1.6064e-03  4.1077e-05  3.8769e-05  4.3558e-05  3.1119e-08  6.3462e-06  0:00:13   11
         926  1.4242e-03  3.7360e-05  3.5373e-05  3.9196e-05  1.9634e-08  5.2341e-06  0:00:13   10
         927  1.2794e-03  3.4317e-05  3.2596e-05  3.5743e-05  1.2940e-08  4.4875e-06  0:00:11    9
         928  1.1628e-03  3.1775e-05  3.0273e-05  3.2910e-05  8.9300e-09  3.9285e-06  0:00:10    8
         929  1.0674e-03  2.9609e-05  2.8295e-05  3.0537e-05  6.3467e-09  3.5249e-06  0:00:08    7
         930  9.8789e-04  2.7741e-05  2.6575e-05  2.8528e-05  4.6056e-09  3.2148e-06  0:00:07    6
      !  930 solution is converged
      Flow time = 0.02600000000000002s, time step = 52
      3948 more time steps
       done.
         Time = 0.174 seconds.
         Done.
         Cell count                              83535     84082     419567
         Mean cell count deviation               -0.5%     0.2%
         Partition boundary cell count           1956      3219      12737
         Partition boundary cell count ratio     2.3%      3.8%      3.0%
         Face count                              172612    173720    858352
         Mean face count deviation               -0.3%     0.4%
         Partition boundary face count           2101      3548      7003
         Partition boundary face count ratio     1.2%      2.0%      0.8%
         Mean cell weight deviation              -0.5%     0.2%
         Partition neighbor count                2         4
      Done.
         930  9.8789e-04  2.7741e-05  2.6575e-05  2.8528e-05  4.6056e-09  3.2148e-06  0:00:23   20
         931  1.1299e-02  8.5819e-04  7.3641e-04  7.4730e-03  3.8808e-04  9.6860e-03  0:00:25   19
         932  7.8026e-03  3.1187e-04  2.6675e-04  2.0783e-03  8.6837e-05  2.9233e-03  0:00:22   18
         933  5.2409e-03  1.5498e-04  1.3248e-04  6.2026e-04  1.9963e-05  6.8673e-04  0:00:20   17
         934  3.8460e-03  1.0601e-04  9.2542e-05  2.2470e-04  4.7949e-06  1.9118e-04  0:00:18   16
         935  3.0034e-03  8.3502e-05  7.4408e-05  1.1297e-04  1.2377e-06  6.0010e-05  0:00:17   15
         936  2.3696e-03  6.8992e-05  6.2345e-05  7.8653e-05  3.6057e-07  2.3053e-05  0:00:18   14
         937  1.9154e-03  5.8710e-05  5.3558e-05  6.4195e-05  1.2666e-07  1.1669e-05  0:00:16   13
         938  1.5964e-03  5.1133e-05  4.6949e-05  5.5118e-05  5.6051e-08  7.5035e-06  0:00:14   12
         939  1.3624e-03  4.5369e-05  4.1806e-05  4.8335e-05  3.0547e-08  5.5799e-06  0:00:13   11
         940  1.1828e-03  4.0743e-05  3.7631e-05  4.3011e-05  1.9186e-08  4.4691e-06  0:00:13   10
         941  1.0423e-03  3.6925e-05  3.4208e-05  3.8728e-05  1.2598e-08  3.7272e-06  0:00:13    9
         942  9.3025e-04  3.3736e-05  3.1328e-05  3.5205e-05  8.6676e-09  3.1996e-06  0:00:11    8
      !  942 solution is converged
      Flow time = 0.02650000000000002s, time step = 53
      3947 more time steps
       done.
         942  9.3025e-04  3.3736e-05  3.1328e-05  3.5205e-05  8.6676e-09  3.1996e-06  0:00:27   20
         943  1.0115e-02  7.8214e-04  7.0580e-04  7.9391e-03  3.8800e-04  9.4361e-03  0:00:28   19
         944  7.4833e-03  2.8040e-04  2.5161e-04  2.1427e-03  8.6850e-05  2.9116e-03  0:00:25   18
         945  5.1084e-03  1.3653e-04  1.2275e-04  6.1809e-04  1.9969e-05  6.7724e-04  0:00:22   17
         946  3.8113e-03  9.5135e-05  8.6948e-05  2.1779e-04  4.7954e-06  1.8815e-04  0:00:20   16
         947  3.0051e-03  7.7016e-05  7.1241e-05  1.0725e-04  1.2366e-06  5.9180e-05  0:00:18   15
         948  2.3867e-03  6.5084e-05  6.0574e-05  7.5115e-05  3.5938e-07  2.2907e-05  0:00:16   14
         949  1.9427e-03  5.6312e-05  5.2649e-05  6.2788e-05  1.2572e-07  1.1771e-05  0:00:17   13
         950  1.6347e-03  4.9558e-05  4.6514e-05  5.4692e-05  5.5343e-08  7.6876e-06  0:00:15   12
         951  1.4130e-03  4.4203e-05  4.1638e-05  4.8279e-05  3.0014e-08  5.8139e-06  0:00:13   11
         952  1.2454e-03  3.9896e-05  3.7696e-05  4.3162e-05  1.8780e-08  4.7261e-06  0:00:12   10
         953  1.1149e-03  3.6370e-05  3.4454e-05  3.9024e-05  1.2298e-08  3.9947e-06  0:00:10    9
         954  1.0109e-03  3.3430e-05  3.1743e-05  3.5601e-05  8.4445e-09  3.4745e-06  0:00:10    8
         955  9.2630e-04  3.0927e-05  2.9447e-05  3.2742e-05  5.9781e-09  3.0938e-06  0:00:09    7
      !  955 solution is converged
      Flow time = 0.02700000000000002s, time step = 54
      3946 more time steps
       done.
         955  9.2630e-04  3.0927e-05  2.9447e-05  3.2742e-05  5.9781e-09  3.0938e-06  0:00:25   20
         956  1.1087e-02  8.8298e-04  7.7854e-04  7.8135e-03  3.8794e-04  9.4176e-03  0:00:27   19
         957  8.0617e-03  3.1319e-04  2.7910e-04  2.0388e-03  8.6868e-05  2.9863e-03  0:00:24   18
         958  5.4778e-03  1.5290e-04  1.3667e-04  6.0166e-04  1.9977e-05  6.9341e-04  0:00:21   17
         959  4.1299e-03  1.0448e-04  9.5634e-05  2.2163e-04  4.7961e-06  1.9437e-04  0:00:22   16
         960  3.3119e-03  8.2787e-05  7.6924e-05  1.1313e-04  1.2355e-06  6.1783e-05  0:00:20   15
         961  2.6785e-03  6.8772e-05  6.4478e-05  8.0253e-05  3.5826e-07  2.4200e-05  0:00:18   14
         962  2.2248e-03  5.9075e-05  5.5528e-05  6.6871e-05  1.2485e-07  1.2587e-05  0:00:16   13
         963  1.9071e-03  5.1959e-05  4.9022e-05  5.7870e-05  5.4697e-08  8.3411e-06  0:00:16   12
         964  1.6755e-03  4.6543e-05  4.4089e-05  5.1066e-05  2.9539e-08  6.3733e-06  0:00:14   11
         965  1.4999e-03  4.2348e-05  4.0263e-05  4.5884e-05  1.8427e-08  5.2354e-06  0:00:12   10
         966  1.3623e-03  3.8999e-05  3.7209e-05  4.1819e-05  1.2043e-08  4.4781e-06  0:00:11    9
         967  1.2519e-03  3.6247e-05  3.4697e-05  3.8538e-05  8.2597e-09  3.9339e-06  0:00:11    8
         968  1.1614e-03  3.3920e-05  3.2551e-05  3.5867e-05  5.8433e-09  3.5305e-06  0:00:09    7
         969  1.0852e-03  3.1929e-05  3.0683e-05  3.3586e-05  4.2265e-09  3.2207e-06  0:00:07    6
         970  1.0200e-03  3.0184e-05  2.9046e-05  3.1608e-05  3.1102e-09  2.9787e-06  0:00:07    5
         971  9.6367e-04  2.8651e-05  2.7599e-05  2.9922e-05  2.3217e-09  2.7852e-06  0:00:05    4
      !  971 solution is converged
      Flow time = 0.02750000000000002s, time step = 55
      3945 more time steps
      Updating solution at time levels N and N-1.
       done.
      Updating mesh at time level N... done.
         971  9.6367e-04  2.8651e-05  2.7599e-05  2.9922e-05  2.3217e-09  2.7852e-06  0:00:26   20
         972  1.1301e-02  7.8754e-04  7.2176e-04  6.7360e-03  3.8788e-04  9.3209e-03  0:00:27   19
         973  8.4481e-03  2.6773e-04  2.4383e-04  1.7516e-03  8.6886e-05  2.9141e-03  0:00:24   18
         974  5.8483e-03  1.2897e-04  1.1644e-04  5.1170e-04  1.9985e-05  6.8297e-04  0:00:22   17
         975  4.4695e-03  8.9767e-05  8.2003e-05  1.8398e-04  4.7976e-06  1.9261e-04  0:00:20   16
         976  3.6187e-03  7.3111e-05  6.7513e-05  9.3244e-05  1.2352e-06  6.1635e-05  0:00:21   15
         977  2.9623e-03  6.2325e-05  5.7983e-05  6.8917e-05  3.5766e-07  2.4452e-05  0:00:18   14
         978  2.4901e-03  5.4579e-05  5.1011e-05  5.9224e-05  1.2435e-07  1.2967e-05  0:00:16   13
         979  2.1582e-03  4.8733e-05  4.5718e-05  5.2392e-05  5.4328e-08  8.7511e-06  0:00:17   12
         980  1.9132e-03  4.4229e-05  4.1619e-05  4.7032e-05  2.9263e-08  6.7963e-06  0:00:14   11
         981  1.7237e-03  4.0622e-05  3.8373e-05  4.2839e-05  1.8217e-08  5.6555e-06  0:00:13   10
         982  1.5734e-03  3.7652e-05  3.5725e-05  3.9477e-05  1.1887e-08  4.9052e-06  0:00:11    9
         983  1.4515e-03  3.5171e-05  3.3503e-05  3.6722e-05  8.1429e-09  4.3533e-06  0:00:11    8
         984  1.3502e-03  3.3059e-05  3.1599e-05  3.4419e-05  5.7556e-09  4.6863e-06  0:00:09    7
         985  1.2651e-03  3.1235e-05  2.9948e-05  3.2463e-05  4.1609e-09  3.8683e-06  0:00:07    6
         986  1.1927e-03  2.9639e-05  2.8497e-05  3.0770e-05  3.0613e-09  3.4264e-06  0:00:07    5
         987  1.1303e-03  2.8231e-05  2.7204e-05  2.9271e-05  2.2855e-09  3.1644e-06  0:00:05    4
         988  1.0762e-03  2.6974e-05  2.6040e-05  2.7936e-05  1.7285e-09  2.9813e-06  0:00:04    3
         989  1.0289e-03  2.5849e-05  2.4994e-05  2.6735e-05  1.3224e-09  2.8400e-06  0:00:03    2
         990  9.8740e-04  2.4811e-05  2.4043e-05  2.5645e-05  1.0228e-09  2.7251e-06  0:00:01    1
      !  990 solution is converged
      Flow time = 0.02800000000000002s, time step = 56
      3944 more time steps
       done.
         990  9.8740e-04  2.4811e-05  2.4043e-05  2.5645e-05  1.0228e-09  2.7251e-06  0:00:26   20
         991  1.1901e-02  8.2961e-04  7.3337e-04  5.4804e-03  3.8784e-04  9.0612e-03  0:00:27   19
         992  8.8631e-03  2.8609e-04  2.5452e-04  1.4538e-03  8.6906e-05  2.8296e-03  0:00:24   18
         993  6.2159e-03  1.3682e-04  1.2162e-04  4.3921e-04  1.9993e-05  6.6172e-04  0:00:25   17
         994  4.7889e-03  9.3739e-05  8.5114e-05  1.6738e-04  4.7986e-06  1.8575e-04  0:00:22   16
         995  3.9173e-03  7.5520e-05  6.9858e-05  9.0799e-05  1.2344e-06  5.8899e-05  0:00:20   15
         996  3.2451e-03  6.4251e-05  5.9849e-05  6.9690e-05  3.5674e-07  2.2836e-05  0:00:20   14
         997  2.7564e-03  5.6222e-05  5.2615e-05  6.0137e-05  1.2362e-07  1.1638e-05  0:00:18   13
         998  2.4102e-03  5.0167e-05  4.7144e-05  5.3148e-05  5.3776e-08  7.4941e-06  0:00:15   12
         999  2.1534e-03  4.5445e-05  4.2891e-05  4.7693e-05  2.8849e-08  5.5553e-06  0:00:16   11
        1000  1.9530e-03  4.1661e-05  3.9511e-05  4.3403e-05  1.7902e-08  4.4224e-06  0:00:13   10
        1001  1.7929e-03  3.8574e-05  3.6730e-05  3.9966e-05  1.2106e-08  3.6544e-06  0:00:11    9
        1002  1.6631e-03  3.6020e-05  3.4415e-05  3.7187e-05  8.2792e-09  3.0990e-06  0:00:13    8
        1003  1.5553e-03  3.3871e-05  3.2457e-05  3.4879e-05  5.8425e-09  2.6850e-06  0:00:10    7
        1004  1.4643e-03  3.2029e-05  3.0779e-05  3.2906e-05  4.2177e-09  2.3681e-06  0:00:08    6
        1005  1.3863e-03  3.0431e-05  2.9317e-05  3.1203e-05  3.0996e-09  2.1153e-06  0:00:08    5
        1006  1.3192e-03  2.9034e-05  2.8038e-05  2.9724e-05  2.3126e-09  1.9105e-06  0:00:06    4
        1007  1.2606e-03  2.7801e-05  2.6911e-05  2.8437e-05  1.7485e-09  1.7403e-06  0:00:04    3
        1008  1.2089e-03  2.6705e-05  2.5912e-05  2.7309e-05  1.3380e-09  1.5969e-06  0:00:03    2
        1009  1.1629e-03  2.5725e-05  2.5014e-05  2.6317e-05  1.0354e-09  1.4806e-06  0:00:01    1
        1010  1.1216e-03  2.4830e-05  2.4187e-05  2.5422e-05  8.0960e-10  1.3857e-06  0:00:00    0
      Flow time = 0.02850000000000002s, time step = 57
      3943 more time steps
       done.
         Time = 0.177 seconds.
         Done.
         Cell count                              85945     86176     430402
         Mean cell count deviation               -0.2%     0.1%
         Partition boundary cell count           2076      3209      13616
         Partition boundary cell count ratio     2.4%      3.7%      3.2%
         Face count                              176814    178009    880022
         Mean face count deviation               -0.4%     0.3%
         Partition boundary face count           2224      3524      7484
         Partition boundary face count ratio     1.3%      2.0%      0.9%
         Cell weights                            9e+05     9e+05     4e+06
         Mean cell weight deviation              -0.2%     0.1%
      Done.
        1010  1.1216e-03  2.4830e-05  2.4187e-05  2.5422e-05  8.0960e-10  1.3857e-06  0:00:26   20
        1011  1.2357e-02  6.1944e-04  5.7173e-04  3.8533e-03  3.8781e-04  8.9220e-03  0:00:27   19
        1012  9.0693e-03  2.1804e-04  1.9980e-04  1.0427e-03  8.6927e-05  2.8045e-03  0:00:28   18
        1013  6.4031e-03  1.1041e-04  1.0077e-04  3.2774e-04  2.0001e-05  6.5584e-04  0:00:24   17
        1014  4.9423e-03  7.9098e-05  7.3375e-05  1.3134e-04  4.7995e-06  1.8342e-04  0:00:22   16
        1015  4.0497e-03  6.5249e-05  6.1421e-05  7.6290e-05  1.2336e-06  5.8128e-05  0:00:19   15
        1016  3.3631e-03  5.6357e-05  5.3482e-05  6.1594e-05  3.5581e-07  2.2807e-05  0:00:20   14
        1017  2.8643e-03  4.9969e-05  4.7665e-05  5.4107e-05  1.2287e-07  1.1923e-05  0:00:17   13
        1018  2.5106e-03  4.5238e-05  4.3295e-05  4.8461e-05  5.3204e-08  7.8923e-06  0:00:15   12
        1019  2.2486e-03  4.1608e-05  3.9970e-05  4.4103e-05  2.8411e-08  5.9917e-06  0:00:16   11
        1020  2.0447e-03  3.8749e-05  3.7373e-05  4.0750e-05  1.7561e-08  4.8601e-06  0:00:13   10
        1021  1.8816e-03  3.6443e-05  3.5244e-05  3.8094e-05  1.1835e-08  4.1015e-06  0:00:11    9
        1022  1.7485e-03  3.4534e-05  3.3444e-05  3.5915e-05  8.0691e-09  3.5551e-06  0:00:11    8
        1023  1.6379e-03  3.2896e-05  3.1902e-05  3.4085e-05  5.6777e-09  3.1453e-06  0:00:09    7
        1024  1.5443e-03  3.1474e-05  3.0562e-05  3.2523e-05  4.0875e-09  2.8277e-06  0:00:08    6
        1025  1.4641e-03  3.0216e-05  2.9368e-05  3.1147e-05  2.9961e-09  2.5755e-06  0:00:06    5
        1026  1.3947e-03  2.9083e-05  2.8300e-05  2.9922e-05  2.2297e-09  2.3717e-06  0:00:05    4
        1027  1.3343e-03  2.8058e-05  2.7337e-05  2.8822e-05  1.6818e-09  2.2027e-06  0:00:04    3
        1028  1.2810e-03  2.7115e-05  2.6456e-05  2.7830e-05  1.2842e-09  2.0730e-06  0:00:02    2
        1029  1.2338e-03  2.6254e-05  2.5647e-05  2.6930e-05  9.9161e-10  1.9752e-06  0:00:01    1
        1030  1.1916e-03  2.5458e-05  2.4896e-05  2.6103e-05  7.7385e-10  1.8764e-06  0:00:00    0
      Flow time = 0.02900000000000002s, time step = 58
      3942 more time steps
       done.
        1030  1.1916e-03  2.5458e-05  2.4896e-05  2.6103e-05  7.7385e-10  1.8764e-06  0:00:26   20
        1031  1.2419e-02  5.6654e-04  4.9459e-04  2.1468e-03  3.8779e-04  8.8851e-03  0:00:28   19
        1032  9.1017e-03  2.1306e-04  1.8616e-04  6.2731e-04  8.6949e-05  2.8646e-03  0:00:24   18
        1033  6.3289e-03  1.1389e-04  1.0060e-04  2.2567e-04  2.0008e-05  6.6097e-04  0:00:25   17
        1034  4.8549e-03  8.3866e-05  7.5945e-05  1.0948e-04  4.8003e-06  1.8591e-04  0:00:22   16
        1035  3.9608e-03  6.9451e-05  6.3853e-05  7.5128e-05  1.2326e-06  5.9030e-05  0:00:20   15
        1036  3.2768e-03  5.9790e-05  5.5449e-05  6.3423e-05  3.5475e-07  2.2801e-05  0:00:20   14
        1037  2.7884e-03  5.2821e-05  4.9300e-05  5.5819e-05  1.2201e-07  1.1504e-05  0:00:18   13
        1038  2.4443e-03  4.7511e-05  4.4609e-05  4.9937e-05  5.2553e-08  7.3458e-06  0:00:15   12
        1039  2.1914e-03  4.3355e-05  4.0943e-05  4.5276e-05  2.7911e-08  5.4132e-06  0:00:16   11
        1040  1.9969e-03  4.0028e-05  3.8029e-05  4.1580e-05  1.7171e-08  4.2975e-06  0:00:13   10
        1041  1.8433e-03  3.7313e-05  3.5612e-05  3.8596e-05  1.1528e-08  3.5409e-06  0:00:11    9
        1042  1.7192e-03  3.5062e-05  3.3589e-05  3.6153e-05  7.8328e-09  2.9973e-06  0:00:11    8
        1043  1.6167e-03  3.3163e-05  3.1859e-05  3.4111e-05  5.4944e-09  2.5912e-06  0:00:09    7
        1044  1.5305e-03  3.1534e-05  3.0370e-05  3.2388e-05  3.9445e-09  2.2892e-06  0:00:08    6
        1045  1.4574e-03  3.0127e-05  2.9071e-05  3.0903e-05  2.8838e-09  2.0325e-06  0:00:07    5
        1046  1.3948e-03  2.8890e-05  2.7919e-05  2.9605e-05  2.1411e-09  1.8293e-06  0:00:05    4
        1047  1.3407e-03  2.7786e-05  2.6891e-05  2.8448e-05  1.6117e-09  1.6626e-06  0:00:04    3
        1048  1.2936e-03  2.6800e-05  2.5971e-05  2.7435e-05  1.2281e-09  1.5233e-06  0:00:03    2
        1049  1.2524e-03  2.5899e-05  2.5136e-05  2.6484e-05  9.4654e-10  1.4055e-06  0:00:01    1
        1050  1.2159e-03  2.5081e-05  2.4373e-05  2.5639e-05  7.3752e-10  1.3056e-06  0:00:00    0
      Flow time = 0.02950000000000002s, time step = 59
      3941 more time steps
       done.
        1050  1.2159e-03  2.5081e-05  2.4373e-05  2.5639e-05  7.3752e-10  1.3056e-06  0:00:25   20
        1051  1.2985e-02  7.1272e-04  6.2200e-04  1.3446e-03  3.8778e-04  8.6923e-03  0:00:23   19
        1052  9.3822e-03  2.6161e-04  2.3056e-04  4.3989e-04  8.6973e-05  2.7313e-03  0:00:25   18
        1053  6.4780e-03  1.3391e-04  1.1920e-04  1.8948e-04  2.0016e-05  6.4263e-04  0:00:22   17
        1054  4.9547e-03  9.4753e-05  8.6111e-05  1.1152e-04  4.8009e-06  1.8225e-04  0:00:20   16
        1055  4.0330e-03  7.7124e-05  7.1056e-05  8.4302e-05  1.2316e-06  5.8464e-05  0:00:21   15
        1056  3.3280e-03  6.5709e-05  6.1041e-05  7.1037e-05  3.5366e-07  2.2994e-05  0:00:18   14
        1057  2.8213e-03  5.7569e-05  5.3737e-05  6.1925e-05  1.2115e-07  1.1915e-05  0:00:16   13
        1058  2.4656e-03  5.1458e-05  4.8145e-05  5.4896e-05  5.1905e-08  7.8293e-06  0:00:17   12
        1059  2.2036e-03  4.6662e-05  4.3788e-05  4.9356e-05  2.7425e-08  5.9059e-06  0:00:15   11
        1060  2.0014e-03  4.2778e-05  4.0322e-05  4.4950e-05  1.6802e-08  4.7782e-06  0:00:13   10
        1061  1.8408e-03  3.9560e-05  3.7482e-05  4.1407e-05  1.1245e-08  4.0190e-06  0:00:13    9
        1062  1.7116e-03  3.6858e-05  3.5117e-05  3.8499e-05  7.6232e-09  3.4658e-06  0:00:11    8
        1063  1.6050e-03  3.4562e-05  3.3096e-05  3.6076e-05  5.3388e-09  3.0623e-06  0:00:09    7
        1064  1.5153e-03  3.2603e-05  3.1360e-05  3.4018e-05  3.8290e-09  2.7479e-06  0:00:08    6
        1065  1.4388e-03  3.0914e-05  2.9832e-05  3.2249e-05  2.7983e-09  2.4991e-06  0:00:07    5
        1066  1.3729e-03  2.9448e-05  2.8482e-05  3.0695e-05  2.0781e-09  2.2984e-06  0:00:05    4
        1067  1.3157e-03  2.8156e-05  2.7293e-05  2.9331e-05  1.5655e-09  2.1340e-06  0:00:04    3
        1068  1.2656e-03  2.7010e-05  2.6255e-05  2.8125e-05  1.1949e-09  1.9986e-06  0:00:03    2
        1069  1.2213e-03  2.5977e-05  2.5315e-05  2.7025e-05  9.2316e-10  1.8859e-06  0:00:01    1
        1070  1.1819e-03  2.5041e-05  2.4454e-05  2.6020e-05  7.2146e-10  1.7899e-06  0:00:00    0
      Flow time = 0.03000000000000002s, time step = 60
      3940 more time steps
       done.
        iter  continuity  x-velocity  y-velocity  z-velocity           k       omega     time/iter
        1070  1.1819e-03  2.5041e-05  2.4454e-05  2.6020e-05  7.2146e-10  1.7899e-06  0:00:24   20
        1071  1.2641e-02  6.2321e-04  5.5314e-04  2.1275e-03  3.8778e-04  8.5995e-03  0:00:26   19
        1072  9.3712e-03  2.3202e-04  2.0716e-04  6.3496e-04  8.6996e-05  2.7724e-03  0:00:23   18
        1073  6.5288e-03  1.1867e-04  1.0664e-04  2.3035e-04  2.0024e-05  6.4801e-04  0:00:24   17
        1074  5.0201e-03  8.3739e-05  7.6600e-05  1.1286e-04  4.8016e-06  1.8373e-04  0:00:22   16
        1075  4.1048e-03  6.8126e-05  6.3208e-05  7.7018e-05  1.2307e-06  5.8981e-05  0:00:19   15
        1076  3.4006e-03  5.8048e-05  5.4291e-05  6.3407e-05  3.5268e-07  2.3259e-05  0:00:20   14
        1077  2.8894e-03  5.0776e-05  4.7721e-05  5.4982e-05  1.2039e-07  1.2112e-05  0:00:17   13
        1078  2.5267e-03  4.5313e-05  4.2742e-05  4.8548e-05  5.1347e-08  7.9951e-06  0:00:15   12
        1079  2.2548e-03  4.1096e-05  3.8893e-05  4.3563e-05  2.7010e-08  6.0742e-06  0:00:13   11
        1080  2.0413e-03  3.7740e-05  3.5836e-05  3.9696e-05  1.6488e-08  4.9574e-06  0:00:14   10
        1081  1.8698e-03  3.5009e-05  3.3361e-05  3.6632e-05  1.1005e-08  4.2055e-06  0:00:12    9
        1082  1.7288e-03  3.2750e-05  3.1330e-05  3.4137e-05  7.4437e-09  3.6587e-06  0:00:12    8
        1083  1.6108e-03  3.0844e-05  2.9614e-05  3.2064e-05  5.2038e-09  3.2539e-06  0:00:09    7
        1084  1.5107e-03  2.9200e-05  2.8136e-05  3.0304e-05  3.7268e-09  2.9315e-06  0:00:08    6
        1085  1.4246e-03  2.7783e-05  2.6839e-05  2.8787e-05  2.7208e-09  2.6735e-06  0:00:07    5
        1086  1.3497e-03  2.6544e-05  2.5693e-05  2.7452e-05  2.0193e-09  2.4712e-06  0:00:05    4
        1087  1.2844e-03  2.5443e-05  2.4677e-05  2.6275e-05  1.5209e-09  2.3047e-06  0:00:04    3
        1088  1.2264e-03  2.4459e-05  2.3760e-05  2.5222e-05  1.1610e-09  2.1632e-06  0:00:03    2
        1089  1.1748e-03  2.3570e-05  2.2930e-05  2.4270e-05  8.9761e-10  2.0335e-06  0:00:01    1
        1090  1.1286e-03  2.2760e-05  2.2172e-05  2.3405e-05  7.0227e-10  1.9226e-06  0:00:00    0
      Flow time = 0.03050000000000002s, time step = 61
      3939 more time steps
       done.
        1090  1.1286e-03  2.2760e-05  2.2172e-05  2.3405e-05  7.0227e-10  1.9226e-06  0:00:25   20
        1091  1.3139e-02  5.6394e-04  4.7837e-04  3.5168e-03  3.8779e-04  8.5083e-03  0:00:27   19
        1092  9.4228e-03  2.2374e-04  1.9473e-04  1.0079e-03  8.7022e-05  2.8052e-03  0:00:24   18
        1093  6.4358e-03  1.2209e-04  1.0810e-04  3.3384e-04  2.0032e-05  6.4433e-04  0:00:22   17
        1094  4.8679e-03  8.8025e-05  8.0109e-05  1.4307e-04  4.8022e-06  1.8263e-04  0:00:23   16
        1095  3.9202e-03  7.1076e-05  6.5683e-05  8.5857e-05  1.2296e-06  5.8906e-05  0:00:20   15
        1096  3.1989e-03  6.0097e-05  5.5831e-05  6.7412e-05  3.5157e-07  2.3374e-05  0:00:18   14
        1097  2.6805e-03  5.2244e-05  4.8760e-05  5.7527e-05  1.1952e-07  1.2164e-05  0:00:18   13
        1098  2.3146e-03  4.6364e-05  4.3470e-05  5.0340e-05  5.0692e-08  7.9459e-06  0:00:16   12
        1099  2.0442e-03  4.1831e-05  3.9357e-05  4.4826e-05  2.6516e-08  5.9470e-06  0:00:14   11
        1100  1.8359e-03  3.8197e-05  3.6034e-05  4.0555e-05  1.6111e-08  4.7322e-06  0:00:12   10
        1101  1.6702e-03  3.5203e-05  3.3303e-05  3.7118e-05  1.0712e-08  3.9450e-06  0:00:12    9
        1102  1.5357e-03  3.2701e-05  3.0989e-05  3.4283e-05  7.2240e-09  3.3824e-06  0:00:10    8
        1103  1.4252e-03  3.0583e-05  2.9026e-05  3.1898e-05  5.0373e-09  2.9728e-06  0:00:09    7
        1104  1.3329e-03  2.8756e-05  2.7329e-05  2.9872e-05  3.5994e-09  2.6418e-06  0:00:08    6
        1105  1.2548e-03  2.7179e-05  2.5850e-05  2.8142e-05  2.6225e-09  2.3755e-06  0:00:07    5
        1106  1.1879e-03  2.5795e-05  2.4556e-05  2.6642e-05  1.9427e-09  2.1624e-06  0:00:05    4
        1107  1.1306e-03  2.4562e-05  2.3408e-05  2.5322e-05  1.4608e-09  2.0095e-06  0:00:04    3
        1108  1.0810e-03  2.3465e-05  2.2377e-05  2.4158e-05  1.1131e-09  1.8522e-06  0:00:03    2
        1109  1.0378e-03  2.2465e-05  2.1457e-05  2.3106e-05  8.5880e-10  1.7227e-06  0:00:01    1
        1110  9.9923e-04  2.1559e-05  2.0632e-05  2.2157e-05  6.7031e-10  1.7746e-06  0:00:00    0
      ! 1110 solution is converged
      Flow time = 0.03100000000000002s, time step = 62
      3938 more time steps
       done.
        1110  9.9923e-04  2.1559e-05  2.0632e-05  2.2157e-05  6.7031e-10  1.7746e-06  0:00:28   20
        1111  1.2520e-02  6.2365e-04  5.6163e-04  4.4502e-03  3.8780e-04  8.3229e-03  0:00:29   19
        1112  9.1933e-03  2.3217e-04  2.0835e-04  1.2462e-03  8.7047e-05  2.6947e-03  0:00:26   18
        1113  6.2247e-03  1.1761e-04  1.0587e-04  3.8864e-04  2.0039e-05  6.3060e-04  0:00:23   17
        1114  4.6585e-03  8.2690e-05  7.5752e-05  1.5234e-04  4.8024e-06  1.8013e-04  0:00:23   16
        1115  3.7206e-03  6.6751e-05  6.1895e-05  8.3832e-05  1.2285e-06  5.8778e-05  0:00:21   15
        1116  2.9925e-03  5.6262e-05  5.2502e-05  6.3218e-05  3.5051e-07  2.3894e-05  0:00:18   14
        1117  2.4662e-03  4.8584e-05  4.5508e-05  5.3496e-05  1.1874e-07  1.2966e-05  0:00:19   13
        1118  2.0959e-03  4.2710e-05  4.0132e-05  4.6412e-05  5.0135e-08  8.9235e-06  0:00:16   12
        1119  1.8208e-03  3.8095e-05  3.5916e-05  4.0874e-05  2.6114e-08  7.0244e-06  0:00:14   11
        1120  1.6077e-03  3.4398e-05  3.2528e-05  3.6518e-05  1.5815e-08  5.9494e-06  0:00:12   10
        1121  1.4381e-03  3.1360e-05  2.9732e-05  3.3015e-05  1.0491e-08  5.1594e-06  0:00:12    9
        1122  1.3004e-03  2.8820e-05  2.7393e-05  3.0147e-05  7.0614e-09  4.5955e-06  0:00:10    8
        1123  1.1868e-03  2.6665e-05  2.5400e-05  2.7757e-05  4.9166e-09  4.2141e-06  0:00:09    7
        1124  1.0914e-03  2.4807e-05  2.3682e-05  2.5741e-05  3.5092e-09  3.9041e-06  0:00:08    6
        1125  1.0103e-03  2.3189e-05  2.2177e-05  2.4008e-05  2.5550e-09  3.6435e-06  0:00:07    5
        1126  9.4107e-04  2.1778e-05  2.0850e-05  2.2501e-05  1.8922e-09  3.4543e-06  0:00:05    4
      ! 1126 solution is converged
      Flow time = 0.03150000000000002s, time step = 63
      3937 more time steps
       done.
         Time = 0.189 seconds.
         Done.
         Cell count                              85736     85765     428741
         Partition boundary cell count           2127      2996      13206
         Partition boundary cell count ratio     2.5%      3.5%      3.1%
         Face count                              176239    177370    876700
         Mean face count deviation               -0.3%     0.3%
         Partition boundary face count           2312      3310      7232
         Partition boundary face count ratio     1.3%      1.9%      0.8%
      Done.
         Smoothing partition boundaries...done.
      WARNING: 1 cells with non-positive volume detected.
      Error at host: Update-Dynamic-Mesh failed. Negative cell volume detected.
      ===============Message from the Cortex Process================================
      Compute processes interrupted. Processing can be resumed.
      Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
      Error Object: #f
      Registering ReportDefFiles, ("C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\.\\drag-rfile.out")
      Calculation complete.
      (cx-gui-do cx-activate-item "Error*OK")
      (cx-gui-do cx-activate-item "Information*OK")
Viewing 45 reply threads
