February 11, 2022 at 7:46 am
sampathkumar
SubscriberIn motor, I am simulating for the performance characteristics of induction motor.in the efficiency plot I am getting a different plot at a higher speed.
February 11, 2022 at 10:32 amRob
Ansys EmployeeWhat do you add into the model as boundary conditions etc? Higher speed means more power, but also (possibly) better heat transfer for cooling, and more drag on the moving parts. If you say which solver you're using I can move this to the correct physics group too.
February 14, 2022 at 6:11 amsampathkumar
SubscriberI am very much thankful for the reply sir....I am using motorCAD tool for simulation
February 14, 2022 at 6:41 amsampathkumar
SubscriberI am very much thankful for the reply. I am simulating the motor in the MotorCAD software tool. In MotorCAD may I know how to check for solver details
February 15, 2022 at 2:02 pmkkimiabe
Ansys EmployeeDear Sampa The difference between Motoring and Generating mode efficiency is a real-life difference, and is due to the opposite direction of the power flow, hence the current, in your equivalent EMachine circuit. To visualize this better, you can analyze the equivalent circuit model of your IM design (the circuit parameters are available in Motor-CAD EMAG module under the OUTPUT tab)and compare the input and output power for the motoring and generating modes by simply reversing the direction of the current, whilst keeping the terminal voltage polarity fixed. Depending on your RL circuit parameters, the difference of efficiency can be minor or major. Please let us know if this clarifies. Kind regards. Kia
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Error with workbench SceneGraphChart
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3862
2639
1859
1254
600
