LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Simulation Error “forrtl: severe (157): Program Exception – acces violation”
    • Noah
      in my simulation the following error always appears after a short time:
      Can you please help me to interpret this error message?
      Or rather, how do I solve the error?
      Greeting
    • Ram Gopisetti
      HI, if you need know how to resolve such issues, it is best if you give us the context and what you are trying to do.
      an inline images do help.
      Cheers, Ram
    • Noah
      I am trying to simulate a simple crash test where simple geometry is deformed using a drop weight.
      I am using a shell plate as a drop weight.
      See Keywords.
      LS-DYNA keyword deck by LS-PrePost
      *CONTROL_ACCURACY
      $#     osu       inn    pidosu      iacc     exacc
               1         4         0         0
      *CONTROL_BULK_VISCOSITY
      $#      q1        q2      type     btype    tstype
             1.5      0.06        -2         0         0
      *CONTROL_ENERGY
      $#    hgen      rwen    slnten     rylen     irgen     maten     drlen     disen
               2         2         2         2         2
      *CONTROL_SHELL
      $#  wrpang     esort     irnxx    istupd    theory       bwc     miter      proj
            20.0         1        -1         4        16         2         1         0
      $# rotascl    intgrd    lamsht    cstyp6    thshel
             1.0         0         0         1         0
      $# psstupd   sidt4tu     cntco    itsflg    irquad    w-mode   stretch      icrq
                         0         0         0         3                             0
      $#  nfail1    nfail4   psnfail    keepcs     delfr   drcpsid    drcprm   intperr
                                   0         0         0         0       1.0         0
      *CONTROL_TERMINATION
      $#  endtim    endcyc     dtmin    endeng    endmas     nosol
            0.03         0       0.0       0.01.000000E8         0
      *CONTROL_TIMESTEP
      $#  dtinit    tssfac      isdo    tslimt     dt2ms      lctm     erode     ms1st
             0.0       0.0         0       0.0       0.0         0         0         0
      $#  dt2msf   dt2mslc     imscl    unused    unused     rmscl     emscl      ihdo
             0.0         0         0                           0.0                   0
      *DATABASE_NODOUT
      $#      dt    binary      lcur     ioopt   option1   option2
           0.001         0         0         1       0.0         0
      *DATABASE_RWFORC
           0.001         0         0         1
      *DATABASE_BINARY_D3PLOT
      $#      dt      lcdt      beam     npltc    psetid
      2.00000E-4         0         0         0         0
      $#   ioopt      rate    cutoff    window      type      pset
               0       0.0       0.0       0.0         0         0
      *CONTACT_FORMING_SURFACE_TO_SURFACE_ID
      $#     cid        title
               2mass
      $#   surfa     surfb  surfatyp  surfbtyp   saboxid   sbboxid      sapr      sbpr
              11         8         3         3         0         0         0         0
      $#      fs        fd        dc        vc       vdc    penchk        bt        dt
             0.2      0.18       0.0                20.0         0       0.01.00000E20
      $#    sfsa      sfsb      sast      sbst     sfsat     sfsbt       fsf       vsf
             1.0       1.0       0.0       0.0       1.0       1.0       1.0       1.0
      *CONTACT_AUTOMATIC_SINGLE_SURFACE_ID
      $#     cid        title
               3Selfcontact
              11                   3         0                             0         0
             0.2       0.2       0.0       0.0       0.0                 0.01.00000E20
             1.5       1.0                           1.0       1.0       1.0       1.0
      $#    soft    sofscl    lcidab    maxpar     sbopt     depth     bsort    frcfrq
               1       0.1         0     1.025       1.0         2         0         1
      $#  penmax    thkopt    shlthk     snlog      isym     i2d3d    sldthk    sldstf
             0.0         1         2         0         0         0       0.0       0.0
      $#    igap    ignore    dprfac    dtstif    unused    unused    flangl   cid_rcf
               1         0       0.0       0.0                           0.0         0
      *MAT_MODIFIED_JOHNSON_COOK_TITLE
      MAT_107_V2A
      $#     mid        ro         e        pr      beta       xsi        cp     alpha
               17.90000E-9  200000.0       0.3       1.0       0.95.000000E81.60000E-5
      $#   e0dot        tr        tm        t0     flag1     flag2
             1.0     293.0    1673.0     293.0       0.0       1.0
      $#  a/siga       b/b   n/beta0   c/beta1      m/na
           310.0    1000.0      0.65     0.007       1.0
      $#    q1/a      c1/n q2/alpha0 c2/alpha1
             0.0       0.0       0.0       0.0
      $#   dc/dc     pd/wc     d1/na     d2/na     d3/na     d4/na     d5/na
             1.0     150.0       0.0       0.0       0.0       0.0       0.0
      $#      tc      tauc
             0.0     850.0
      *MAT_RIGID_TITLE
      Fallgewicht
      $#     mid        ro         e        pr         n    couple         m     alias
               22.00000E-5  200000.0       0.3       0.0       0.0       0.0
      $#     cmo      con1      con2
             1.0         4         7
      $#lco or a1        a2        a3        v1        v2        v3
      *PART
      $#        title
      mass
      $#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
               8         2         2         0         0         0         0         0
      *SECTION_SHELL_TITLE
      mass
      $#   secid    elform      shrf       nip     propt   qr/irid     icomp     setyp
               2         2    0.8333         2       1.0         0         0         1
      $#      t1        t2        t3        t4      nloc     marea      idof    edgset
             1.0       1.0       1.0       1.0       0.0       0.0       0.0         0
      *PART
      $#        title
      cylindershell
              11         1         1         0         1         0         0         0
      Shell_2
               1        16    0.8333         5       1.0         0         0         1
             2.0       2.0       2.0       2.0       0.0       0.0       0.0         0
      *HOURGLASS
      $#    hgid       ihq        qm       ibq        q1        q2    qb/vdc        qw
               1         8      0.03         0       1.5      0.06      0.03      0.03
      Unfortunately, this error always occurs and I do not understand what the problem is.
