Simulation Error in HFSS without a reason?
    • Michael93
    • AndyJP
      What the validation report tells you before the simulation?nTell us more about the model, the port, the materials, and the airboxn
    • VivekKamble
      Hello,nPlease check all the parameters such as excitation, Boundary conditions, Analysis setup, material assignment. Please check whether AEDT validates the design. nTry to restart the AEDT and then analyze it.nI hope this will help. Please let us know if you still face the problem.nWith best regards,nVivekn
    • Michael93
      I have tried both copper and a ferrite material. Furthermore I added a power source, which is the red box on the picture with 1A. I have no Boundaries. I have 2 meshes with 2000 elements and a solution setup with 300 kHz, 10 passes and 0.1 delta energy. Except for the power source I have transferred all settings from the working eddy current simulation to the HFSS. Only the power source had to be redefined. The validation check does not produce any errors. A restart did not help either.nnThank you for your helpnnMichaeln
Viewing 3 reply threads
